| New Reply |
Properties of Plank wood & bridge question |
Share Thread |
| Oct27-12, 06:31 PM | #1 |
Hello everybody,
For a group project, we are supposed to propose several designes for a plank bridge over a river. I've tried to find this material's (plank wood) strength properties, or a stress-strain diagram to no avail. Do you know where I can find it? Also, is it reasonable for a wooden bridge to be 2-3km long? Do we need supports over the river to make it safe and practical? Your help is greatly appreciated! Thanks |
| Oct27-12, 07:12 PM | #2 |
There is no such thing as "plank wood" - there are white oak planks, red oak planks, white pine planks.... and so on.
Plus, what you've given us is vague. Start with the Forest Products Laboratory website - Wood as an Engineering Material http://www.fpl.fs.fed.us/products/pu...00&header_id=p But you need to have a clue as to what wood species you are going to use. |
| Oct27-12, 08:16 PM | #3 |
Recognitions:
This is what a bridge just over 2km long might look like ... ![]()
| Oct31-12, 01:36 AM | #4 |
First things first. If you have decided your construction will be based on wood, you can find the approximate material properties in Michael Ashby's book on Materials Selection (http://www.amazon.com/Materials-Sele.../dp/1856176630).
The properties you are looking for are the following: Flexural strength, buckling strength and tensile strength for a 'wood-like' material. Also, it is literally impossible that you can build a 2-3 km structure out of a single plank of wood that is supported only at the ends - if it somehow escapes bending under its own weight it will still easily be swayed by winds. Maybe I am giving you more complicated advice than you need, so just look up Ashby's book first. It deals with several nice examples regarding how to select a material for specific objectives. |
| Nov2-12, 01:22 PM | #5 |
If your plank has a large enough area moment of inertia you could use one plank and not have excessive swaying... but good luck finding a tree that size...
| New Reply |
Similar discussions for: Properties of Plank wood & bridge question
| Thread | Forum | Replies | ||
| Bullet passing through block of wood. Find max height of the wood. | Introductory Physics Homework | 3 | ||
| Mechanical properties of Yew wood | Materials & Chemical Engineering | 19 | ||
| Building a bridge outta balsa wood- three arches or one? | General Physics | 0 | ||
| Balsa Wood Bridge | General Physics | 2 | ||
| Balsa Wood Bridge | Introductory Physics Homework | 1 | ||
