Understanding the Mechanics of Gravity: How and Why It Works
  • Thread starter Ryan Lucas
  • Tags
    Gravity
In summary, the conversation discusses the mechanics of gravity and the concept of positive and negative charges and their attraction. The conversation delves into the theories of General Relativity and the role of mass in distorting space-time, leading to the attraction between objects. However, while there are theories and explanations for how gravity works, the exact mechanism behind it remains unknown. The conversation also addresses the difficulty in explaining complex scientific concepts to those with different levels of understanding.
  • #36
Danger said:
I've come up with my own 'thought model' because the rubber sheet thing is pretty much 2 dimensional...
I think the three dimensional model picture is actually representing a slice of the black hole in two dimensions.
thats just my guess, I never read anything like that anywhere, so correct me !
  • #37
Anomalous said:
1) If that is true then how come every body lied to me uptill now that light has no mass. Or r U taking me for a ride ?
2) So U don't agree that the ray light should regain its original green path of direction. BTW for that not to happen the space will have to be in kinda worm holes state but predictable stable ones.
3) So U don't agree that the natural cordinate system of space is changing ?
i.e. U don't agree that a 10 centimeter object can be actually longer in distorted space when compared to normal space ?
I am not a Frog. Frogs don't ask such questions.
1) I quoted whatever was told by Einstein. Trust me I have read it in a good book.( shall I quote the book?..)
2) Bending of light is just like refracton , in a sense , the object is not visible at its correct place.Go to a good site, learn more about bending of light around stars and black holes.You will get more knowledgeable. Or visit http://casa.colorado.edu/~ajsh/distort1big_gif.html
3)Ofcourse when some object "dends" the spacetime curve , it forms a sort of dent , as a result the meaning of straight line chanches, that is, what used to be the shortest possible path to go from A to B , has no become a bit longer.That is Geometry is distorted.Please read my previous post clearly, about bending of spacetime fabric by sun . So the sun is a bulky mass, and it bends the curve quite dramatically such that our knowledge of staraight lines, shapes seems vague.Taking an example of black holes , the spacetime curves are so much distorted that 'spacetime distance' and 'time' reverse their roles and just as on Earth , we cannot avoid next monday , near black holes, we cannot avoid r---->0 . ...
Tell me if you have more doubts..
  • #38
Why no one here reply to my post !
Please read the link which i posted in my first post !
  • #40
Ok don't confuse , it is not that only one of light/space bends, it is that light bends under the influence of distorted space.See the link I gave you, does the light retraces its path..?... the image shows that it does not, so this means that it is not only that the space bends but also that light also takes part in the whole process ... and this contribution of light is due to the enrgy it carries.
Another way, imagine it like this, once the light has bent, instead of returning to the same path, it starts traveling again in straight line but this time in another direction as compared to the direction it was traveling before.
Its all like a road, when you drive a vehicle , and you find that the road is curving ahead, you steer in the direction of the road curve ,once you have turned to the left/right, you continue again in straight line without retracing your original path.Now the vehicle which 'could' reach its destination in some time, takes more time...!
  • #41
it is very poor that there is nobody who can reply to my posts :
i will repeat them :
I think our understanding of gravity is completely wrong !There is no doubt that we must search for another theory which involves at least quantum-mechanics !
We must know all interactions of all forces to each other to be able to explain and understand gravitation completely!A theory which would explain it really is the Heim-Theory !I will set a link to a site where you can read everything about it!Certainly a 80 site script you can find there too.Maybe i will open a new thread for this theory!
So i am new here i don't know exactly where i should post this theory !
But now here is the link :
http://www.heim-theory.com/Contents/contents.html
Have anybody ever heard here from the mass formula of heim ?
Greetings
Antigravitation
  • #42
antigravitation said:
I think U should make your point in a separate thread, as U may be off topic here , hence ignored
  • #43
Greetings
Antigravitation
Ok..as per your request, I have added the link to my fav. , I will read it and present my views.
  • #44
antigravitation, the heim theory looks quite interesting. i love to look at new theories, because i have little faith in the current theories. unfortunately, the computer I am on does not have acrobat reader, so i am unable to view the files. the computer at my job = not cool. :yuck: when i get home, ill take a look at your theory and post back on it. I am looking forward to it. :smile:
  • #45
Nobody knows the detailed mechanism
Ryan Lucas said:
In school we are taught that gravity is a force of attraction between two bodies. This is very vague, and it bothers me that a broader knowledge of gravity is not "common knowledge". Could someone please explain in deatail the mechanics of gravity, how and why it works?
"If an apple falls, does the moon also fall"
Isaac Newton
The theories of forces explain that there is a contribution to free motion and that contribution is "a force".
Exactly what is a force or how it act? Nobody know that. In fact, it would be very difficult to reduce the concept of force to some more fundamental.
There is an "attempt" to explain the concept of force in terms of field, and other more modern in terms of interchange of virtual particles. Both of those attempts are (contrary to usual beliefs) conceptually ineffective and experimentally restrictive.
Moreover, note that both are based in unobserved things.
1) The idea of a force is an interchange of virtual photons (QED) is valid like approximation and not explain really nothing (in fact one recover basically the same questions). There is the "same" mistery that with original Coulomb law
2) The idea of a force like a curvature of spacetime (GR) is also valid like approximation and not explain really nothing. There the "same" misterium that with original Newton law. How Earth know force caused by Sun is transformed to new mistery How Earth know curvature caused by Sun!
  • #46
"Matter tells the fabric how to curve, and curved fabric tells matter how to move"
I know gravity can also affect light but what is the explanation for gravity slowing down time also?
  • #47
Reality vs Math terms.
Ryan;
As Juan stated, science has not reduced the concepts of forces to a cause and effect set of fundamental paradigms. Once this is done, I'm sure all of us will get a simple and complete answer to your question and much more. We might want to start by not performing such a literal translation of the QM and GR mathematical terms into reality terms. Do we really believe that space (the void) warps or that real time reacts to motion? Dose anyone believe that there are dimensions beyond the three physical dimensions? If science continues to promote these mathematical terms as real phenomena, it may be quite some time before you get the answer your looking for. :smile:
  • #48
Well referring to the modern physics, there r 4 forces in this universe...
The electromagnetic force, the weak force, the strong force and the gravitational force..
The electromagnetism explains the magnets attraction forces, the weak explains the neutrinos interactions and the beta decay in nuclear physics, the strong forces explains why a nucleus doesn't break a part...
Gravity in a curved space, explains why the earth, moon and sun orbit around themselves and around things bigger than they r...Noting an important fact that gravity is no longer a pulling force, no it's a pushing one, it's the space around the apple that pushed it to the ground not an invisible magnet in the heart of the Earth who did so...
Also we know know that light isn't just a wave, light has a particle nature too, and that's how it can be affected by a strong gravitational force, and the gravitational force working within the sun works as a reflecting lens that someitmes we r being decieved with the images we see for other galaxies...
  • #49
Gravity as I understand it
As far as I know, Gravity is a byproduct of interaction between Matter and Space-Time. The presence of Matter distorts Space-Time so that traditional Uclidean Geometry no longer holds -- i.e. straight line is no longer a straight line, but a bent one. Light follows Geodesic path, meaning that it follows a length-minimizing path in a distorted Space-Time.
QM suggests that there should be Graviton particle, much like Photon, that serves to explain the Gravity Field, but I believe this hasn't been verified (I could be wrong). As far as I'm concerned, these particles just as well be described as unit of energy confined to tiny Space-Time (measured in terms of Plancks constant).
Recent developments in String and Brane Theories suggested that Gravity might be something that leaks into our dimension from other higher dimensions. This is somewhat far-fetched, but it does address the concern that Gravity is so much weaker than other fundamental forces of nature.
My own take on Gravity, not that I'm qualified to theorize, is that it is caused by disruption of expanding Space-Time by presense of Matter. As many of you know, there's a recent development that suggests Dark-Energy responsible for repelling the Universe (i.e. Universe as we know it will expand forever inspite of Gravity). I believe that Matter is simply a form of energy confined in a Hyperspace that counteracts the expansive force of Dark-Energy. This disruption of Dark-Energy is perceived as Gravity in our 3 + Time-Space dimension we live in.
This is only my rendition of Gravity, so take it with a grain of salt.
  • #50
Icebreaker said:
Wouldn't it be interesting if matter weren't in spacetime, but rather, is spacetime?
True matter is space-time. Since all particles occupy space-time it's reasonable to believe they are one and the same.
  • #51
Of course light has a mass, haven't u heard of the photoelectric effect(which is why einstein have had his nobel prize) light can interact with matter, light has a mass represented in the form of the photons, photons are energy, and Einstein proved mathematically that at the speed of light mass and energy are the same because E=mc²...
And every object that has a mass can be influenced by gravity..
  • #52
Why does everybody think gravity to be a weaker force than the other four fundamentals? granted it cannot hold bodies with the same unquenchable grip as strong nuclear force but I've also never heard of electromagnatism defying the exclusion principle like gravity does in the collapse of a neutron star.
Off topic: does anyone have a clue where i can find out about current theories surrounding singularities and black holes here? I've just decided that singularitys must have either volume or infinite gravity and i want to see if this holds true with current beleif (or a current belief)
  • #53
Light has 0 mass. Gravity does not affect light directly, it affects the space-time dimensions that light is traveling through. When people refer to light bending in the presence of a massive object this is only a perceived effect. From the lights frame of reference it is traveling in a straight line.
  • #54
Isaac Newton
The quick answer is according to quantum theory everything, both matter and forces are comprised of 2 families of particles Fermions and Bosons respectively this theory has been very successful so far in explaining matter and the other 3 forces - electromagnetism and the weak and strong nuclear forces. Forces affect matter by the interaction of boson particles. The particles related to gravity have been identified theoretically and given a name - gravitons, but to date physicists have been unable to detect them.
  • #55
here's a ref for you http://cosmology.berkeley.edu/Education/BHfaq.html
  • #56
I'm too speculative and too far beyond physical review's current level of research, but I say that gravity and electromagnetism are the same force and the same strength. :)
  • #57
Hehehe good luck proving that one Enos :D
But bloody hell you have a good point :bugeye: we just don't have the means to produce strong enough magnets to replicate the gravitational effects of a body the size of a planet ...
And maybe if a proton was gravitationally charged in the same way its electromagnetically charged then it could hold something as small as an electron in check over something as small as the Planck constant ...
I like ur thinking dude :P just going to have a hard time proving it
(Ps thanks for the link Art ... i still havnt looked but itll probably be worthwhile :smile: )
  • #58
I just hope I'm right. I'll know for sure in time.
  • Other Physics Topics
  • Thermodynamics
  • Classical Physics
  • Mechanics
  • Art, Music, History, and Linguistics
  • Classical Physics
