Would it work: mosquito killer
  • Thread starter tgkprog
  • Tags
    Work
In summary, the idea is a device that has two cushions backed by some plastic that claps every few seconds. The idea is that this will kill mosquitoes in time, when they randomly fly into the range.
msquito killer idea would work
  • yes
    Votes: 1 16.7%
  • yes its already there (post details)
    Votes: 0 0.0%
  • no
    Votes: 5 83.3%
  • Total voters
  • Poll closed .
tgkprog
what do u think of the idea : a device that has 2 cushions backed by some plastic that claps every few seconds ... and hopefully kills mosquitoes in time, when they randomly fly in the clap range.
the cushions are so the device does not make noise.
a better model would change its position and a top end would have a sensor to sense moquitoes and clap only when they are near.
i don't have actual design but it would be a neat product
Is the device randomly clapping? Not sure how frequently a mesquito might fly into it, but perhaps a device that might sense visually that a mesquito flew into it before snapping shut? Not sure if that would be an easy thing to sense, though.
I rather doubt the practicality, but it could be a fun device to have kicking around at picnics. You might increase your odds by rigging a cylinder to release minute amounts of carbon dioxide between the paddles.
Lol, youd be better of getting a material they can peirce through wrap it over the top of a container filled with poison, then heat the wrapped material to a specific degree that they are mostly attracted to and set it out, theyd all zoom to it thinking it was of animal sort and try to get blood... dead. Or you could buy a zapper :P
Great idea, clapping robots with image processing are sure to replace insecticides in the next decade or so :approve:
Do they chase mosquitoes by flying around the room as well? We could have a pack of robotic drones hunting in teams for effective clapping results.
Qaiphyx said:
...Or you could buy a zapper...
I have a bug zapper that seems to be quite effective, it has a spot for a cartridge on the bottom of it that takes some sort of nondescript "mosquito attractant." Whatever is in that attractant, it seems to work because I have seen the zapper kill skeeters by the hundreds (maybe even thousands?) in a given night.
I can't imagine a "clapper" that slams shut would be particurally effective unless somehow paired with some sort of attractor like has been mentioned; I do imagine I would find it somewhat less entertaining than a zapper though :smile:
can u tell me what brand of zapper u use? and do u know iof they are effective against mosquitoes? i live in India - we have a few sprays here - not very good and stink up the place. we do have these electric liquid things that slow burn but they to are less effective after a few days and there are reports that they are not 100% safe for humans ...
Thank u for all ur responses
randomly clap - i thought that will have to be experimented with - random/ cycles / with a mosquito attracting odour ... if its safe
I don't think the clapper is too practical.
My experience with a mosquito/fly killer in Taiwan is a container with a brightly lit luminescent lamp in the middle, surrounded by a metal mesh of high voltage electricity (which is then surrounded by an interlocking grid for safety measures.)
You place the container in a room, turn off all the lights, and the insects would be attracted towards the bright light. They are small enough to pass through the safety grid, but are electrified to dust just as they approach the lamp by the electrified wires around it. That's pretty much it. Every household pretty much has one.
Or, if you want to get more high-tech, perhaps you can, in addition to the central vertical lamp, install a pheromone/hormone attractant targeted to a specific type of pest, so it'll also work in daylight?
One thing to keep in mind is that solid paddles might not work at all. The reason that flyswatters have holes in them is to prevent the compression wave from blowing the bug out of the way before it gets hit.
does not work for mosquitoes. future gens get the idea.
yeah this is a good point, thank you. now to look for someone to build a prototype!
Uh, uh, dude; you thought it up, you build it.
To save unnecessary parts and complexity, you might as well just have one fixed component that the other claps against. There's no reason to have both moving.
hmm yes that's an idea - or 2 - only 1 moving and do it my self great
Maybe can start with a fly swartter attached to paddle, so easy to replace if it breaks but it will have to be fast. i wonder if it was attached to a rigged juice mixer motor and allowed to rotate - at one point there by a stationary paddle that it hits and then bends and completes a circle - easier than making a motor that has to move in opposite directions
FYI. 1-octene-3-ol is the most likely attractant.
ty about 1-octene-3-ol
i wanted to make a safe for environment product instead of some spray but it might need this to attact them
fyi I'm looking for someone to build this ... am not good with building stuff. hopefully will find someone have told a hardware guy who repairs my comps about it and he said he will get back to me
1. How does the mosquito killer work?
The mosquito killer typically works by emitting a chemical or substance that either attracts mosquitos or repels them. Some mosquito killers use ultraviolet light to attract mosquitos and then trap them, while others use a chemical spray to kill them on contact.
2. Is the mosquito killer safe for humans?
It depends on the type of mosquito killer being used. Some chemical sprays may contain ingredients that can be harmful to humans, especially if ingested. It is important to carefully read and follow the instructions on the mosquito killer product label to ensure safe usage.
3. How effective is the mosquito killer?
The effectiveness of a mosquito killer depends on various factors such as the type of product, the concentration of active ingredients, and the environment in which it is being used. Some products may be more effective in certain areas or against certain types of mosquitos, so it is important to research and choose the right product for your specific needs.
4. Will the mosquito killer harm other insects or animals?
Again, this depends on the type of mosquito killer being used. Some products may be harmful to other insects or animals, while others may be specifically designed to only target mosquitos. It is important to read the product label and use the mosquito killer as directed to minimize any potential harm to non-targeted species.
5. Can the mosquito killer be used in all environments?
Mosquito killers may not be suitable for all environments, especially if there are certain types of plants or animals that may be negatively affected by the product. It is important to research and follow the guidelines for use in specific environments, such as indoor vs outdoor use, to ensure maximum effectiveness and safety.
  • Electrical Engineering
  • Quantum Interpretations and Foundations
  • General Engineering
  • Aerospace Engineering
  • Mechanical Engineering
