Frequency components in a singnal.
In summary, the channels on a FM broadcast radio station have a bandwidth that lets them be captured on all the frequencies in the band.
Peon666
108
From a book:
"The waveform is distorted because of different amounts of attenuation and phase shift suffered by different frequency components of the signal"
Question:
If there are different frequency components in a single, how do the ratio channels operate on a single frequency. A channel, for example, operates on the frequency 101. How can this happen when the signal contains components of differing frequencies?
Thanks.
Peon666 said:
From a book:
Question:
Thanks.
The channel has some bandwidth, so that gives rise to different frequency components being in even a narrow-band signal.
The bandwidth of each US FM broadcast radio station is 200kHz, in the band from 87.8 MHz to 108.0 MHz.
http://en.wikipedia.org/wiki/FM_broadcasting
So, when we say ration station 106 (for example), we're talking about the Bandwidth. And Bandwidth means that this station/channel can be captured on all the frequencies in this band, right?
Another related question: When we say that a certain broadband/DSL connection has a bandwidth of say, 1 Mbps, what does that mean?
Thanks.
No, when you say FM radio station 98.5, that is the channel centered on 98.5MHz, with a bandwidth of 200kHz.
Thanks.
That means that the channel has enough bandwidth to support 1 million bits per second being transmitted through it (with an acceptably low bit error rate).
Thanks.
I bit confused about this. Does this mean that the channel is best transmitted at 98.5, but it can be transmitted, with a bit low quality, in the range of 200 kHz bandwidth?
Thanks.
Peon666 said:
Thanks.
Thanks.
No, the transmitted FM signal is centered at 98.5MHz, with signal components (due to the frequency modulation) that extend out +/- 100kHz above and below the center frequency. Check out this info on modulation, and its relation to channel bandwidth:
http://en.wikipedia.org/wiki/Modulation
Thanks a lot! It was really helpful! Taking first course in Analogue Communication. :)
1. What are frequency components in a signal?
Frequency components in a signal refer to the different sinusoidal waves that make up the overall signal. These waves have different frequencies and amplitudes, and when combined, they create the complex waveform of the signal.
2. How are frequency components measured?
Frequency components can be measured using a spectrum analyzer, which displays the amplitude of each frequency component in a signal. The frequency components can also be determined by performing a Fourier transform on the signal.
3. Why are frequency components important?
Frequency components play a crucial role in signal processing and analysis. They can provide information about the underlying physical processes that produced the signal and can be used to identify specific patterns or features in the signal.
4. How do frequency components affect the quality of a signal?
The presence or absence of certain frequency components can greatly affect the quality of a signal. For example, if high-frequency components are missing, the signal may sound distorted or muffled. Additionally, the relative amplitudes of the frequency components can also affect the quality of a signal.
5. What is the relationship between frequency components and signal bandwidth?
The bandwidth of a signal is directly related to the range of frequencies present in the signal. A wider range of frequency components results in a larger signal bandwidth, while a narrower range of frequency components results in a smaller signal bandwidth.
  • Electrical Engineering
