Problem with light simultaneity
In summary, the conversation discusses Einstein's thought experiment with the train and the concept of events happening only when they are seen. It also explores the difference between seeing an event and the event itself. The answer to the thought experiment is that there is more than one answer, but regardless of what is seen, it is known that the lights hit at the same time. The conversation also brings up the idea of adding another person in the train and how it affects their perception of the event.
senorhosh
Ok so in Einstein's thought experiment with the train, everything makes sense except...
Einstein is stating that an event doesn't happen until someone SEES it. But isn't there a difference between SEEING an event happen and the event happening regardless of whether someone sees it or not?
The answer to his "thought experiment" is that there is more than one answer: the 2 lights strike at once and the front hits train before the back. But the second answer is merely just what the observer in the train SEES. Regardless of what he sees, we all KNOW that the lights hit at the same time.
Ie: let's say physicist wants to set up an experiment.
He is in the train and attaches flashlights in the front and back of the train. They are timed to go on at the EXACT SAME TIME. The physicist knows this and waits. Then he sees the front light before he can see the back light. KNOWING that the flashlights were set to go off at the same time (and testing the equipment an indefinite amount of times), he uses the different times to conclude that ONE light is faster than the other.
How do this be accounted for? Just because someone SEEs a light later doesn't mean it turned on later..
NO, he doesn't say anything like that! I don't know where you got that idea.
The whole point is that the physicist knows that light does NOT travel faster in one direction than another so knows that the "conclusion" above must be false.
Pardon me. Which of Einstein's thought experiments involving a train is this thread discussing?
It does if the lights are equidistant.
This is not correct. This physicist on the moving train will see the two flashes at the same time (assuming he's in the middle of the train). But a physicist on the ground will see the two flashes at different times. Which one is right?
And if the physicist on the ground set up a similar experiment, he would see both flashes at the same time while the physicist on the moving train would see them at different times. Which one is right? Does that make any difference to your understanding of Eisntein's traig experiment.
I am also interested in exploring the difference between SEEING an event and the EVENT ITSELF (please see https://www.physicsforums.com/showthread.php?t=460929) - if the dogma police will allow it, that is...
What do you figure happens after you add another person in the train who sees both lights at the exact same time? Who is right? one person sees both lights at the exact same time and another person sees them go off at different times.
Einstein's thought experiment (discussed in section 8 and section 9 of his book Relativity: The Special and General Theory) is about when the events of the lightning strikes are reconstructed to have happened in each frame, not just when they are seen. For example, if in 2010 I see the light from an explosion 10 light-years away in my frame, and in 2020 I see the light from an explosion 20 light-years away in my frame, then I will retroactively conclude both events happened at the same date (2000) in my frame, even though I saw the light from the events at different times.
1. What is the problem with light simultaneity?
The problem with light simultaneity is that it challenges our understanding of time and space. According to classical physics, the speed of light is constant and independent of the observer's frame of reference. However, this contradicts our everyday experience where we perceive events happening at different times depending on our position in space.
2. How does special relativity explain the problem of light simultaneity?
Special relativity, developed by Albert Einstein, explains the problem of light simultaneity by proposing that the speed of light is the same for all observers, regardless of their relative motion. This means that time and space are relative and can be perceived differently by different observers.
3. Can the problem of light simultaneity be solved?
The problem of light simultaneity cannot be solved in the traditional sense because it is a fundamental aspect of the universe. However, it can be understood and explained through mathematical models and theories, such as special relativity.
4. How does the concept of time dilation relate to light simultaneity?
Time dilation, another key principle of special relativity, states that time passes slower for objects moving at high speeds. This means that two observers moving at different speeds will experience time differently, leading to a difference in their perception of light simultaneity.
5. What are some real-world consequences of the problem of light simultaneity?
The problem of light simultaneity has important consequences in fields such as astronomy and navigation. For example, GPS systems must account for the time differences between satellites and receivers due to their different relative speeds in order to accurately determine locations on Earth.
9K
