- #176
Dale
Mentor
- 35,300
- 13,522
That is easy. There is NO physical interpretation of ANY coordinate system (incl. SC and all of the other coordinate systems that we have discussed); what has physical interpretations are the invariants.harrylin said:I got drawn into this topic of black holes because of what appears to be an issue about physical interpretation of Schwarzschild's coordinate system
The purpose of any coordinate system is simply to make calculations possible or even easy. In some coordinate systems the calculation of specific invariants becomes particularly easy, but even then it is the physical invariants which are easily calculated from the coordinates which have a physical interpretation, not the coordinates themselves.
Yes, as long as it is clear that "never" is a coordinate-dependent statement meaning "not at any finite SC coordinate time". Unfortunately, that is rarely clear.harrylin said:That sounds reasonable to me, and then no informed person would object if someone else says that a crossing of a black hole horizon never happened; if I'm not mistaken that's simply according to our standard time convention on Earth (perhaps the ECI frame is based on Schwarzschild).
This is why I recommend that you read the Carroll's lecture notes. It seems to me that you don't yet understand the basic relationship between coordinate charts and manifolds. Essentially, you seem to not get the fact that a coordinate chart need not cover the entire manifold, and indeed, some simple manifolds are impossible to cover in a single chart (see p. 38). Whether or not a specific chart covers a given point has nothing to do with whether or not that point is in the manifold. The numerous examples of Rindler and Zeno coordinates in flat spacetime should make that abundantly clear.harrylin said:However, it remains paradoxical to me, in the sense that in my experience such things always led to contradictions. Different from SR's relativity of simultaneity it seems to imply a possible disagreement if events will occur or not
Please read the Carroll notes again. You cannot have understood that chapter and not understand this concept.harrylin said:And in the context of this topic, there may be an issue of consistent physical interpretation: there has been talk of an "internal Schwarzschild solution" according to which an object crosses the horizon, and which is combined with it as a single solution. Is that correct? So far I don't understand how such a combined solution can give a consistent physical interpretation of events.
