Fluid mechanics, open water channel velocity - bernoulli & conservation of flow
In summary, the conversation discusses the relationship between a small bump in the base of an open water channel and the resulting dip in water level above it. This arrangement can be used to measure flow velocity, and the velocity directly above the bump is given by a formula involving the height and depth of the fluid. The conversation also mentions relevant equations and asks for help in finding the expression for v2.
mh1985
28
If in an open water channel, the approach speed of an incompressible ideal fluid, of constant depth h1, is not too large, a small bump in height H (H<< h1) in the base of the channel will cause a dip Δh (Δh << H) in the water level directly above it, such that h1 = Δh + H + h2, where h2 is the height of the fluid above the bump.
Under these conditions, such an arrangement can be used for measuring the flow velocity
Q. Assuming no losses, show that the velocity v2, directly above the bump is given by
[tex] v_2 = [\frac{2gΔh} {(\frac{h1}{h2})^2 - 1}]^\frac{1}{2} [/tex]
[tex]0.5*u^2 + gh_1 = 0.5* v_2^2 + g(h_2 + H)
g (h_1 - (H + h_2) = 1/2 (v_2^2 - u^2) = g \delta h [/tex]
We want the expression for [tex] v_2 [/tex]
[tex]v_1h_1 = v_2h_2 [/tex]------->[tex]v_1 = \frac {v_2h_2}{h_1} [/tex]
Thanks for the help!
can anyone help?
1. What is fluid mechanics?
Fluid mechanics is the study of how fluids (liquids and gases) behave when they are in motion. It involves the study of forces and movements within fluids and how they are affected by different variables such as pressure, velocity, and viscosity.
2. What is an open water channel?
An open water channel is a man-made or natural waterway that has a free surface, meaning that the water is not confined by any walls or boundaries. Examples include rivers, canals, and streams.
3. How does Bernoulli's principle relate to open water channels?
Bernoulli's principle states that as the velocity of a fluid increases, the pressure decreases. In open water channels, the velocity of the water can change due to changes in the channel's shape or direction. This results in changes in pressure, which can affect the flow of the water.
4. What is conservation of flow in fluid mechanics?
Conservation of flow is a fundamental principle in fluid mechanics that states that the total mass of a fluid entering a system must equal the total mass leaving the system. This means that the amount of water entering an open water channel must equal the amount leaving the channel, taking into account any changes in velocity or pressure.
5. How is the velocity of water in an open water channel calculated using Bernoulli's principle?
The velocity of water in an open water channel can be calculated using the Bernoulli equation, which relates the pressure, velocity, and height of a fluid. This equation can be solved for velocity by rearranging the terms and plugging in the known values for pressure and height at different points along the channel.
  • Classical Physics
