How many points do the graphs of y=x^{12} and y=2^x intersect?
In summary: But if there are any points where the derivative becomes negative, then that might be a sign that there's a third intersection.
jjou
64
(Problem from practice math subject GRE exam:) At how many points in the xy-plane do the graphs of [tex]y=x^{12}[/tex] and [tex]y=2^x[/tex] intersect?
The answer I got was 2, but the answer key says 3.
Intuitively, by the shape of their graphs, I would say two. I tried to calculate actual values for x:
[tex]2^x=x^{12}[/tex]
[tex]x\ln2=12\ln x[/tex]
[tex]\frac{\ln2}{12}=\frac{\ln x}{x}[/tex]
[tex]\sqrt[12]{2}=\sqrt[x]{x}[/tex]
I don't know what to do with that last equation.
I'm really confused though, because I can't even imagine how they would get a third intersection. Any help would be appreciated. :)
It's pointless to try to solve a transcendental equation analytically. Remember that x^12 is an even function, and note that 2^x approaches 0 as x approaches -infinity, but also remember that when x=0 that x^12 = 0, so you know that the two plots cross once for x < 0. You might guess they cross once for x>=0, but think about when x is > say 1000 and when x is say 2. Which function is larger in each case? Which is larger at x=0? Which is larger for x = -1000?
Clearly the graph of y= 2x crosses the graph of y= x12 for x somewhere between -1 and 0: 2-1= 1/2 and (-1)12= 1 so the graph of x12 is higher for x= -1 while, at x= 0, 20= 1 and 012= 0 so the graph of 2x is higher for x= 0.
Also 212= 4096 while 22= 4: the graph of x12 is higher again so the graph must intersect again between x= 0 and x= 2.
The question, then, is whether the graphs intersect a third time for x> 2; whether 2x is larger than x12 for "sufficiently large x".
One way to answer that is to look at the limit of 2x/x12 as x goes to infinity. Since that fraction itself becomes "infinity over infinity" we can apply L'Hopital's rule. Repeatedly differentiating, the numerator just stays 2x (times a power of ln(2)) while the denominator has lower and lower powers eventually becoming a constant (after 12 differentiations, we get 12!) and then 0. What does that tell you about the limit? And what does that tell you about whether 2x or x12 is larger for very large x?
Thanks! This makes sense. So...
[tex]\lim_{x\rightarrow\infty}\frac{2^x}{x^{12}}=\lim_{x\rightarrow\infty}\frac{(\ln2)2^x}{12x^{11}}=...=\lim_{x\rightarrow\infty}\frac{(\ln2)^{12}2^x}{12!}=\infty[/tex]
Which means that for very large x, 2^x does eventually exceed x^12, which gives us the third intersection point.So, one last question -
Is this a good general strategy for this type of problem (if I were to get a similar one on the actual exam): First sketch the graph and see what obvious/immediate intersection points I can find. Then use the limit idea for [tex]x\rightarrow\infty[/tex] and [tex]x\rightarrow-\infty[/tex].
Will this ensure that I find all of my intersection points?
Thanks so much! :)
Not necessarily. For example, it there were 3 more intersections between x= 2 and infinity, the same changes in which is smaller and which is larger would be true. You might try looking at the derivative of f- g. If that is always positive, then that can't happen.
1. What is the intersection of two functions?
The intersection of two functions is the point or points where the graphs of the two functions intersect. This means that the x and y values of the intersection point satisfy both equations simultaneously.
2. How do you find the intersection of two functions?
To find the intersection of two functions, you need to set the two equations equal to each other and then solve for the common variable. This will give you the x-coordinate of the intersection point. You can then substitute this value into either equation to find the y-coordinate.
3. Can two functions intersect at more than one point?
Yes, two functions can intersect at more than one point. This happens when the two functions have multiple solutions for the common variable when set equal to each other.
4. What does it mean if there is no intersection point between two functions?
If there is no intersection point between two functions, it means that the graphs of the two functions do not cross or touch each other at any point. This could be because the functions are parallel or have no common solutions.
5. How can the intersection of two functions be used in real life?
The intersection of two functions can be used in many real-life scenarios, such as finding the break-even point in business, determining the optimal combination of resources in economics, or finding the solution to a system of equations in math and science. It can also be used to analyze the relationship between two variables in a given situation.
