sneaky666
- 66
If I had Z=Y^3 where Y is a standard normal distribution. How would I approx. calculate the probability of Z<=1 ?, I would understand it if it was Z=Y^2 which is chi-square...
A normal distribution is a type of probability distribution that is commonly used to model real-world data. It is bell-shaped and symmetrical, with the majority of the data falling within one standard deviation of the mean.
To calculate the probability from a normal distribution, you need to know the mean and standard deviation of the data set. You can then use a mathematical formula or a statistical table to find the probability of a specific value or range of values occurring within the distribution.
The normal distribution is used in statistics to describe and analyze continuous data that follows a bell-shaped pattern. It is commonly used in hypothesis testing, confidence intervals, and many other statistical analyses.
No, the normal distribution is most appropriate for continuous data that follows a bell-shaped pattern. It should not be used for categorical or discrete data.
The mean and standard deviation are important parameters of a normal distribution as they determine the shape, center, and spread of the data. The mean represents the center of the distribution, while the standard deviation indicates how much the data is spread out from the mean.
