Calculating Uncertainty of Aquired Evaporation Rate
In summary, the speaker is trying to calculate the uncertainty in their evaporation rate for a lake using the formula E=C.U(ess-ea)/P. They are unsure how to incorporate the uncertainty in wind speed and vapor pressure into their calculation. They consider using the propagation of uncertainty method and suggest finding the difference in E values at maximum and minimum wind speeds and applying the percent difference in vapor pressure to E. The total uncertainty in E is calculated by combining the two ranges of uncertainty.
Hanatwork
Hi! I am Calculating the uncertainty in an Evaporation Rate i obtained from measurements around a lake using E=C.U(ess-ea)/P where C is constant 135mm/day at 1.5m above lake surface, U is average wind speed, P air pressure hPa, ess saturation vapour pressure @lake surface temp (Ave), ea is air vapour pressure =11.65 hPa.
E= 2.48mm/day. The uncertainty is to be found from an obtained uncertainty in the vapour pressures (ea1-ea2/ea1= 4.47%) and the standard deviation of the wind speed observations:
U= 2.12 +/- 1.26 m/s
Im unsure on how to use the standard deviation of wind speed data (1.26) and the previous obtained vapour P uncertainty (0.0447) to obtain an uncertainty for E?
I thought it might be calculating E at max and min U (by standard deviation) and finding the difference, and then maybe multiplying that by the uncertainty of vapour pressures (4.47%)? but this felt wrong as just a guess.
CAN ANYONE PLEASE OFFER SOME ADVICE ON HOW I FIND THE ANSWER? Thanks heaps for any help! :)
Hello! It sounds like you are on the right track in your approach to calculating the uncertainty in your evaporation rate. To incorporate the uncertainty in wind speed and vapor pressure, you can use the propagation of uncertainty method.
First, calculate the uncertainty in E due to the uncertainty in wind speed. This can be done by calculating E at the maximum and minimum wind speeds (2.12 + 1.26 = 3.38 m/s and 2.12 - 1.26 = 0.86 m/s). Then, find the difference between the two E values (3.38 mm/day - 0.86 mm/day = 2.52 mm/day). This difference represents the range of uncertainty in E due to wind speed.
Next, calculate the uncertainty in E due to the uncertainty in vapor pressure. To do this, you can use the equation you provided: (ea1 - ea2)/ea1 = 4.47%. This represents the percent difference in vapor pressure, which can be applied to E as well. So, you can calculate E at ea1 and ea2 (using the same equation you provided) and find the difference between them. This difference represents the range of uncertainty in E due to vapor pressure.
Finally, to find the total uncertainty in E, you can combine the two ranges of uncertainty by adding them. So, the total uncertainty in E would be 2.52 mm/day + (4.47% of E) = 2.52 mm/day + (0.0447 x 2.48 mm/day) = 2.53 mm/day. This means that your final result for E would be 2.48 +/- 2.53 mm/day.
I hope this helps! Please let me know if you have any further questions. Good luck with your calculations!
1. What is the purpose of calculating uncertainty of acquired evaporation rate?
The purpose of calculating uncertainty of acquired evaporation rate is to determine the range of possible values that the evaporation rate could fall within, taking into account the errors and variations in the measurement process. This helps to assess the reliability and accuracy of the acquired data.
2. How is uncertainty of acquired evaporation rate calculated?
Uncertainty of acquired evaporation rate is typically calculated using statistical methods, such as the standard deviation or confidence intervals. These methods take into account the precision and accuracy of the measurement equipment, as well as any sources of error or variation in the measurement process.
3. What factors can contribute to the uncertainty of acquired evaporation rate?
There are several factors that can contribute to the uncertainty of acquired evaporation rate, including variations in measurement equipment, environmental conditions, and human error. Other factors may include the complexity of the system being measured and the limitations of the measurement techniques.
4. How can uncertainty of acquired evaporation rate affect the interpretation of experimental results?
Uncertainty of acquired evaporation rate can significantly impact the interpretation of experimental results. If the uncertainty is high, it may indicate that the data is not reliable or accurate enough to draw meaningful conclusions. Additionally, uncertainty can also affect the precision and accuracy of any calculations or models based on the evaporation rate.
5. How can uncertainty of acquired evaporation rate be reduced?
To reduce the uncertainty of acquired evaporation rate, it is important to use precise and calibrated measurement equipment, minimize sources of error and variation in the measurement process, and conduct multiple measurements to account for any fluctuations. Additionally, using more advanced measurement techniques and increasing sample size can also help to reduce uncertainty.
  • Mechanical Engineering
  • Other Physics Topics
  • General Discussion
  • Beyond the Standard Models
