Demonstration dips his wettened fingers into molten lead
In summary, the professor was conducting a physics demonstration where he dipped his fingers into molten lead without getting burned. This is possible because the water on his fingers vaporizes to form a protective sheath. However, this should not be attempted as it can be dangerous and has caused injuries in the past. The same principle is used by dessert chefs when testing the stage of molten sugar for various candies.
thenewbosco
187
Just reading a textbook and came across this interesting question:
"a daring lab instructor in a demonstration dips his wettened fingers into molten lead (327C) and withdraws them quickly without getting burned. How is this possible?"
I was thinking simply that the water on the fingers will absorb the heat and since he withdraws his fingers quickly it won't reach his hand but this sounds a little shady...any other ideas on this?
The water vaporizes to form a protective sheath.
QUESTION: The professor readies a pan of molten lead, measuring 740 F. on the industrial thermometer, then prepares to plunge in a finger. What's he trying to prove?
ANSWER: It's Jearl Walker of Cleveland State University doing another wacky physics demo, described in "Fundamentals of Physics Extended, 5th Ed." He had read of 19th century carnival showmen dipping wet fingers into molten lead, and figured he was on to their secret: "As soon as the performer's wet flesh touched the hot liquid metal, part of the water vaporized, coating the fingers with a vapor layer. If the dip was brief, the flesh would not be heated significantly."
So Walker wetted a finger and took the plunge. "Amazingly, I felt no heat." The water had indeed vaporized to form a pro tective sheath. Growing bolder, he wetted and dipped in all the fingers of one hand, deep enough to touch the pan bottom.
"Still I questioned my explanation. Could I possibly touch the lead with a dry finger without suffering a burn? Leaving aside all rational thought, I tried it, immediately realizing my folly when pain raced through the finger." Then he dipped in a dry wiener, which blackened within seconds, lacking also the vapor protection.
NEVER, NEVER try this, warns Walker. A slight mistake can cause lead to solidify around the fingers, or send searing splashes onto the body. "I have been scarred on my arms and face from explosive vaporizations."
The cold water absorbs the heat before the fingers do. It only lasts a very brief time. Dessert chefs do something very similar when making various candies. They test what stage their molten sugar is at (softball, hardball, soft crack hard crack etc...)by dipping their hands in water and then grabbing a small portion of the molten sugar with their two fingers. They immediately take the molten sugar and put it under the water again to get the feel for the sugar. It doesn't burn you even though the molten sugar is usually well over 300 degrees.
1. What is the purpose of dipping fingers into molten lead in a demonstration?
The purpose is to showcase the high temperature and fluidity of molten lead, as well as demonstrate the properties of the metal.
2. Is it safe to dip fingers into molten lead?
No, it is not safe. Molten lead is extremely hot and can cause severe burns and other injuries.
3. How does the demonstration of dipping fingers in molten lead work?
The demonstrator typically uses a tool, such as tongs, to dip their fingers into the molten lead. The high temperature of the lead causes it to stick to the fingers, creating a thin layer that quickly solidifies.
4. What happens to the molten lead after the demonstration?
After the demonstration, the lead can be cooled and solidified again. It can then be reused in other experiments or disposed of properly.
5. Are there any safety precautions that need to be taken when performing this demonstration?
Yes, proper protective gear, such as heat-resistant gloves, should be worn when handling molten lead. The demonstration should also be performed in a well-ventilated area and with caution to avoid any accidents.
  • Computing and Technology
  • General Discussion
  • Earth Sciences
74K
