Exploring the Mystery of Earth's Rotation
  • Thread starter woundedtiger4
  • Tags
    Earth
In summary: The best answer to the OP's question is that the Earth is rotating now because (a) it was rotating shortly after it formed, and (b) it has only transferred some of that initial rotational angular momentum to the Moon's orbit.
woundedtiger4
188
Hi all,
I am not a physics student but I always used to think that Earth rotates because of an inertia that occurred after big bang. But then someone told me that it's wrong. Now, I don't know that why Earth rotates :(
hi woundedtiger4! :smile:
the Earth rotates because (like all the other planets) it formed from the material that surrounded the sun, and that was rotating
i'll let someone else take up the story from there :smile: …​
If you take a cloud of particles in free fall moving in random directions, they will have a total linear momentum and a total angular momentum (relative to an observer).
As they coalesce, both will be conserved.
then why do we always see the same side of the moon?
The Moon is tidally locked to the Earth. It rotates, but the period of rotation is the same as its orbital period around the Earth, so we only get to see one side.
Simple, but simply wrong. Google the term "angular momentum problem." Why the planets rotate is not a simple matter of conservation of angular momentum.
A better explanation, at least for the gas giants, is that protoplanets orbit slightly faster than the gas and dust in the portions of the protoplanetary disk near those planets. The orbital rate of a planet is [itex]\sqrt{G(M_s+m_p)/r^3}[/itex] while for a spec of dust it is just [itex]\sqrt{GM_s/r^3}[/itex]. The protoplanet clears a path through the disk, and as it does so, it spirals in toward the nascent star. The planet encounters more material on its starward side as opposed to its outward side. This density gradient is what generates most of the planet's rotational angular momentum. It is not a simple matter of conservation of angular momentum.
Why the inner planets rotate is still problematic, and an even bigger problem is why the Sun is rotating so slowly.
To elaborate, the Moon was not always tidally locked. This is a common phenom that happens with moons of planets over their lifetime (billions of years), as the planets works to slow its moons' rotation. Many planets in the solar system have tidally locked moons.
1. Why does the Earth rotate?
The Earth rotates because of its initial momentum from the formation of the solar system and the laws of physics. As the solar system was forming, the Earth was made up of gas and dust particles that were swirling around the sun. As these particles collided and merged, the Earth's rotation began. This rotation has been maintained due to the Earth's inertia and the conservation of angular momentum.
2. What causes the Earth to rotate?
The Earth rotates because of the Earth's initial angular momentum, which was created during the formation of the solar system. In addition, the gravitational pull of the sun and other planets also contributes to the Earth's rotation. As the Earth orbits the sun, the gravitational pull of the sun slightly alters the Earth's rotation, causing it to rotate slightly faster.
3. Does the Earth's rotation affect its shape?
Yes, the Earth's rotation does affect its shape. The Earth is not a perfect sphere, but rather, it is slightly flattened at the poles and bulging at the equator. This is due to the centrifugal force caused by the Earth's rotation. The rotation causes the Earth's equator to bulge out slightly, while the poles are flattened.
4. How long does it take for the Earth to make one full rotation?
The Earth takes approximately 24 hours to make one full rotation, which is why we have day and night. This rotation is also known as a solar day and is measured by the time it takes for the sun to return to its highest point in the sky. However, due to the Earth's orbit around the sun, a sidereal day, which is based on the Earth's rotation in relation to the stars, is about 23 hours and 56 minutes.
5. Will the Earth ever stop rotating?
No, the Earth will not stop rotating. As long as the Earth has inertia and there are no major external forces acting upon it, it will continue to rotate. However, the Earth's rotation is gradually slowing down due to tidal forces from the moon and other factors, but this process is extremely slow and will not affect the Earth's rotation in our lifetime.
  • Mechanics
