Please help transistor amplifier
In summary: So, if you choose Ie=1mA, you only have 25Ω to play with, which means you want rl to be very large value, which means you want to use a Darlington transistor.In summary, if you want to design a CE amplifier with a gain of 50, you can use two stages, each with a gain of x10 and x5 respectively. Alternatively, you can use one stage with a gain of 50, but it may be more difficult to design and may not be as reliable. It is important to consider the input and output impedances of the circuit in order to achieve the desired voltage gain.
  • #71
Jony130 said:
Yes for Vcc = 10V and hfe = 150
THIS is the same example without re2, but you add in serie re2
i mean this laste circuit, and the first example without R2 has the same value value of r1 and r2 is r1=22k, and r2=4.7K and power supply 10V ,
and this is correct R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ
of this R1 = (Vcc - Vb)/( 10*Ib) = 22KΩ
OK
Av = Rc/re = gm*Rc = Ic/26mV*Rc = (Ic*Rc)/26mV
50[V/V] = (Ic*Rc)/26mV
from this
(Ic*Rc) = 1.3
I choose Rc = 1K
So
Ic = 1.3/1K = 1.3mA
But as you can see this approach is not very good because give as low voltage swing.
We need to use Re1 or use a different type of a circuit. But lest as add Re1 resistor.
Now Av = Rc/(re+Re1)
And for Rc = 1K we can use this
Ic = 0.5Vcc/Rc = 5V/1K = 5mA
So re = 26mV/5mA = 5.2Ω
And
Re1 = Rc/Av - re = 1K/50 - 5.2Ω = 20 - 5.2Ω = 14Ω
This circuit is also not very good because low Re1 means that Hfe spread and temperature change will have significant impact on bias point stability. This is why I use Ve = 1V and add Re2 to reduce the voltage gain to 50[V/V]
thnx
  • #72
I don't understand the question?
  • #73
you show me first this example
OK
from this
(Ic*Rc) = 1.3
I choose Rc = 1K
So
Ic = 1.3/1K = 1.3mA
And
after you show the second example
Also we can split Re resistor with a capacitor. And use Re1 = 14Ω and Re2 = Ve/Ic - re1 = 1V/5mA - 14Ω ≈ 180Ω
And now we can select R1 and R2
Vb = Ve + Vbe = Ic*(Re1+Re2)+ Vbe = 5mA* (180 + 14) + 0.65V = 1.62V
If we assume Hfe = 150
Ib = Ic/hfe = 5mA/150 = 34μA
R2 = Vb/(10*Ib) = 4.7KΩ
is this the same like in example 1 and example 2
i mean this second example, and the first example without R2 has the same value value of r1 and r2 is r1=22k, and r2=4.7K and power supply 10V ,
and is this correct R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ
do you understand you show 1 example in 2 party, first without re2 second with re2, so this one example, do you understand
  • #74
Averagesupernova said:
Michael, are you asking why Zin and Zout are important to know?
yes i ask you, i want to know
  • #75
This two equation holds only if Ve > 0.6V
R2 = Vb/(10*Ib)
  • #76
R2 = Vb/(10*Ib)
i ask you for gain av 50 without re, and you show me example
OK
from this
(Ic*Rc) = 1.3
I choose Rc = 1K
So
Ic = 1.3/1K = 1.3mA
And
ah joney i make you tired, is possibe to write me in one party not separate all this here, like in first example with re2, you explain me very good, but this is not in one party , i can understand better PLEASE
  • #77
OK
For this diagram the voltage gain is equal to
Av ≈ Rc/(re+Re1)
Rc = 0.1*RL = 0.1*10K = 1K
And
This circuit is not very good because low Re1 means that Hfe spread and temperature change will have significant impact on the bias point stability. This is why I use Ve = 1V for good bias stability.
To overcome this problem of a low value for Re1 = 14Ω and Ve = 70mV (Ve = Re1 *Ic = 5mA*14Ω = 70mV).
I add anther Re resistor in series with Re1.
Now we have
Ve = Ic * Re1+Re2 and we want Ve = 1V so
Re2 = Ve/Ic - Re1 = 1V/5mA - 14Ω ≈ 180Ω
And I use C2 capacitor to "remove" Re2 from gain equation for AC signal.
Av = Rc||RL/(re + Re1)
  • #78
Jony130 said:
OK
Av ≈ Rc/(re+Re1)
And
Now we have
JONEY THANK YOU, i understand everything, just this one no
R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ, where come 11, how come this 11 can you explain me thnx
  • #79
First think first.
The one of the methods to become independent of hfe changes is to select voltage divider resistor (R1 and R2) in such a way that base current don't load our voltage divider to much. The maximum base current is equal to Ib_max = Ic/Hfe_min where Hfe_min is a minimum value for Hfe in data sheet.
And we select voltage divider current so that I_divader > Ib_max
In our example voltage divider current is I2 current .
But as you can see the current that flows through R1 resistor is equal to divider current plus base current.
Additional if we assume that divider current is ten times greater than base current.
I2 = 10 * Ib
the R1 resistor current I1 becomes
I1 = I2 + Ib = 10*Ib + Ib = 11*Ib
And this is why
R1 = (Vcc - Vb) / (10*Ib + Ib) = (Vcc - Vb)/(11*IB)
and
R2 = Vb/(10*Ib)
  • #80
Jony130 said:
First think first.
I2 = 10 * Ib
And this is why
and
R2 = Vb/(10*Ib)
this is a bit difficult to me, and how much is ib to your example, can you explain in similary way because i find difficult, sorry joney i try to understand but is difficult, ah value of ib is 1 is correct
  • #81
joney please can you explain this, i know you explain to me but i don't understond, this 11 and the value of ib HOW YOU CALCULATE 11AND IB PLEASE joney you help a lot to design amplifier. i am simple an beginner
ib is 0,034
johy this i know R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ
(10*Ib + Ib) IS (10*IB(0.034)+0.034)=(0.34*IB)
but 11 i don't know can you explain me please CAN YOU ANSWER ME
  • #82
ib is 0,034
but 11 i don't know can you explain me, can you show me another example of ths 11 please CAN YOU ANSWER ME
  • #83
Do you understand first kirchhoffs law ?
Do you know how loaded voltage divider work?
  • #84
joney i know i think
and i do like i see in some book voltage divider like this
for example we need base current of 50MICRO
AND base voltage of 1.7V so now
for example if is 10vcc
r2 1.7v base/50micro is come 34ohm
r1 must have 8.3V/50MICRO is come 166ohm
so 10VCC/200=5MICRO
so the current in serie is the same, maybe i do somewhere mistake
i am curios to know your calculation how you get 10 and 11 in voltage divider, this is something new to me, but can you show another with example so i can understand, you show also the first example with gain of 50 do you rembember also there i see
R2 = Vb / ( 5 * Ib) = 30K
R1 = ( Vcc - Vb) / ( 6 * Ib) = 150KΩ
wher how you get 5 and 6, and second example r2 10 and r1 11, can you show me example just one the second i find self, i know you can do it, just with example in some easy way please joney i whait yesterday all day message from you, because i want to learn it, and i learn good how to select desired voltage and i am happy, but this no
valu of 11 and 10
joney plase show me example in easy way so i can understand thnx for reply...
  • #85
so 10VCC/200=5MICRO
Simply you forget about base current which loads the voltage divider in your calculations.
So to reduce this loading effect on output voltage we need increase the current that is flow through voltage divider or output current should be a small fraction of the voltage divider current.
So when we design voltage divider we assume that voltage divider current is larger then the load current.
Normally Divider current is 5 to 30 times larger then the load current.
So if we want 1.7V and load current is equal to 50μA and we choose voltage divider current 10 times larger then load current we have this
R2 = 1.7V/(10*Iload) = 1.7V/(10*50μ) = 1.5V/500μA = 3.4K
And from I Kirchhoff's Law we see that R1 resistor current is equal:
I_R1 = 10*Iload + Iload = 11*Iload = 550μA
So
R1 = (10V - 1.7V)/(550μ) = 15K
  • #86
So
o sorry joney i make you tired, i understand now, so if load current is 50μ we chose voltage divider current 10 larger then the load current, and we have
R2 = 1.7V/(10*Iload) = 1.7V/((this is 10 time larger)10*50μ(base current)) = 1.5V/500μA = 3.4K this i understand
but this i don't understand
10*Iload(50μA)+Iload(50μA)=11(how we get 11 now)*Iload(50μA)=550μA
i don't understand that 11 how we get? 10*Iload(50μA)+Iload(50μA)=0.55 not 11 sorry i don't know where i make mistake, where come this 11, i don't know how to calculate, i know 11*Iload is 550μA
thnx for answer
  • #87
Solve this pure math problem
B = 10A + A
Also from KCL we see that R1 must provide current for R2 resistor and also the current for the load.
So if Iload = 50μA and we pick voltage divider 10 times load current we have this:
I_R1 = Iload + 10 times load current = 11 times load current = 11*50μA = 550μA
  • #88
B = 10A + A
i am with calculator in my hand, i make mistake with my calculator but i don't understand i do it 0.050+10*0.050=0.55 how to do it ? CAN YOU TELL ME PLEASE HOW TO CALCULATE WITH CALCULATOR,
  • #89
Can you tell me how to calculate with calculator joney
  • #92
Joney i know you know how to do it with calculator, can you tell me because i have in my hand calculator, i can find nothing in google the same result please...
  • #93
Simply use your brain instead of a calculator.
And if you still don't know how you should quit EE and start learn math.
  • #94
JONEY i use me brain, why you don't tell me to calculate with my calculator, you just help me, i thank you for help, just tell me a little bit, and i use a calculator, you help so much, help also this one
  • #95
But I don't understand what is your problem?
I_R1 = 50uA + 10*50uA = 50 + 500 = 550uA = 0.55mA = 0.00055A
  • #96
joney i know this from begin to calculate this is easy, but my problem was other you forget,
i ask you for this
thnx for answer
joney this 11 is my problem
  • #97
OMG
Look here
We have this equation
B = 10*A + A = 11*A
The first part tell as that we have a ten apples and we need add one more apple.
So we end-up with eleven apples .
  • #98
Jony130 said:
OMG
Look here
B = 10*A + A = 11*A
ah you mean so
10*0.0.5+0.0.5=
10+0.5+0.5=11
you mean like this
  • #99
ooh joney boy, i make again mistake of is right, ooo thank you try a lot to explain me
  • #100
In our cases we have 11 apples
B = 10*A + A
And apples are equal to 50uA of load current.
So we substitute for A = 50uA
B = 10*50uA + 50uA = 550uA
And this is equal to 11*A = 11*50 = 550uA
the 11 tell as that the R1 current is 11 times large the load current.
  • #101
B = 10*A + A
thank you joney for losing time for me and help i go to sleep tomorow work have a nice sleep
  • #102
thank you ver much joney now i start to understand
  • #103
hi joney, may i ask you something
if we take 10 large then load(50micro)this is all time formula
for i_R2=10*LOAD and I_R1 = 10*Iload + Iload = 11*Iload = 550μA
and
if we take 5 large then load(50micro)this is all time formula
for i_R2=5*LOAD and I_R1 = 5*Iload + Iload = 11*Iload =
is correct?
and can you tell me which book, do you know some book where i can learn good electronics?
advice
now i am reading electronics principles 7 by malvino
  • #104
is correct?
Check your algebra skills because your answer is wrong.
B = 5A + A = ??
advice
I don't know any good book. Try buy a book in your native language.
  • #105
B = 5A + A = ??
is 6 i know now,
but the best books are in engish
  • Electrical Engineering
