Number of bolts required for a flanged coupling?
In summary: Why is this person so special? Is it because he is a mentor? I don't get it. The rules are supposed to be the same for everyone. If a person is not allowed to reveal the entire solution to the problem before giving the OP a chance to solve it themselves, then it should be the same for everyone. If not, then the rules are not fair, are they?
jacoja06
Hi everyone.
This question is giving me a real headache (literally). It should be simple, but I’ve spend probably the last 4-5 hours trying to figure it out. The left side of my brain is redundant.
The following specifications are used for the design of a flanged coupling between two coaxial shafts:
Speed: 650rpm
Power transmitted: 550 kW
Bolt diameter: 12mm
Pitch-circle diameter: 200mm
Material: Mild steel
Factor of safety: 4
Determine the number of bolts required, assuming the bolts are equally loaded.
Ultimate Shear Strength of mild steel = 360 N/mm^2
Shear stress (MPa) = Force (Newtons) / Area (mm^2)
Factor of safety = Ultimate Shear Strength / Shear Stress
I cannot get anything down at all. And I also cannot understand why they have given me Speed and Power. Is there maybe some way to work out the force for the shear stress equation?
Also for your information, this is question 27.11 from Val Ivanoff’s Engineering Mechanics.
Any help would be much appreciated!
welcome to pf!
hi jacoja06! welcome to pf! :smile:
jacoja06 said:
… I also cannot understand why they have given me Speed and Power. Is there maybe some way to work out the force for the shear stress equation?
go back to basic definitions …
power = energy/time = work/time (same thing)
= force x distance/time
= force x distance x angle/time :wink:
Thanks for the reply and welcome! :)
So using that formula;
P = F x distance/time
550kw = F x (650rpm x ((2 x pi)/60))
F = 484.81N?
you've missed out the radius :redface:
Oh, sorry... I didn't put the time in seconds in my last post. I was supposed to put;
550kw = F x (650rpm x ((2 x pi)/60)/60)
So;
550kw = F x (68.0678rad/60)
F = 484.81N
Where would the radius come into the equation?
Hint: Torque = Force * Distance
You've also got an extra factor of 60 in your RPM conversion. Remember 1 min = 60 sec
To solve the larger problem, how many bolts, you are trying to transmit a certain torque from one shaft to another at the coupling. You are given a standard size bolt to use, along with the material characteristics. How is the torque going to be transmitted? What type of stress will be set up in the bolts?
Thanks, steamking.
I think he distance part is confusing me the most at the moment. There isn't any specified distance I can use to find the force.
jacoja06 said:
Thanks, steamking.
The pitch-circle is the circle concentric with the shaft where the bolt holes are located.
total torque to be transmitted => T=9550P/N (N-m)
=> 9550*550/650 = 8080N-m
force on the coupling= 8080/0.250 =40400 N
assuming its a mild steel of yield strength 240MPa and shear strength of 120 MPa,with a factor of safety of 4 the design shear strength is 30Mpa
we have area of each bolt = Pi*12*12/4 =113.04mm2
total load that a single bolt can take = 113*30 = 3390N
so you will need 40400/3390 = 12 bolts.
I hope this clarifies your question and i stand to be corrected if I'm wrong.
speed and power helps you to find the torque... you can use the equation I specified above, or you can also use this
Power =(2*Pi*N*T)/60
also, we design machines with factor of safety as a function of yield strength rather than UTS. :)
Sorry! the force on the coupling would be 8080/0.125 (consider the radius... not diameter. silly error :) )
follow the same methodology
My view on this problem:
Bolt material: SANS 1431 GR 300WA (Mild steel). It is assumed that the minimum specified ultimate strength is 400 MPa and a proof strength of σ4.8 = 320 MPa which gives a shear yield strength of: 0.577x320 MPa = 185 MPa
Shaft speed: N = 650 RPM
Power transmitted: P = 550 kW
Bolt diameter: D = 12 mm
PCD = 200 mm
Factor of safety: SF = 1.2
The bolts will have to withstand two types of loading:
Pre-tensile loading from fastening torque
Shear loading from transferring required power
Recommended bolt torque: 40 Nm
This gives internal bolt force of:
F=T⁄0.2D
F=40⁄(0.2×(0.012))
F=16.67 kN
Tensile axial stress per bolt:
σ_1=F⁄A
σ_1=16670⁄((π×〖(9.85)〗^2)⁄4)
σ_1=219 MPa
Predict number of bolts required will be 8.
Shear stress:
P=F×v
with
v=ωr
v=N(2π⁄60)r
v=650(2π⁄60)(0.1)
v=6.806 m/s
this gives
550000=F×6.806
F=80.811 kN
Hence
F_(per bolt)=80811⁄8
F_(per bolt)=10.1 kN
Shear per bolt
τ_(per bolt)=F⁄A
τ_(per bolt)=10101⁄((π×(9.85)^2)⁄4)
τ_(per bolt)=132.56 MPa
If friction is neglected these stresses work together to give a Von Mises equivalent stress (In plane stress) of:
σ_vm=√(〖σ_1〗^2+〖3(τ)〗^2 )
σ_vm=√(〖219〗^2+〖3(132.56)〗^2 )
σ_vm=317.3 MPa
This gives a Safety factor of:
SF=σ_4.8⁄σ_vm
SF=320⁄317.3
SF=1.008
This indicates that when 8 bolts are to be used, it will be able to transfer the loads with a safety factor of 0.8% which is not adequate for the operation.
Newly predict that the number of bolts required will be 12:
Hence
F_(per bolt)=80811⁄12
F_(per bolt)=6734 N
Shear per bolt
τ_(per bolt)=F⁄A
τ_(per bolt)=6734⁄((π×(9.85)^2)⁄4)
τ_(per bolt)=88.37 MPa
σ_vm=√(〖219〗^2+〖3(88.37)〗^2 )
σ_vm=267 MPa
SF=σ_4.8⁄σ_vm
SF=320⁄267
SF=1.2
This indicates that when 12 bolts are to be used, it will be able to transfer the loads with a safety factor of 20% which will be adequate for the operation
Ideally the torque should be transmitted through friction alone
With
F=T⁄r
And
N=F⁄μ÷4
With friction coefficient of 0.3 the amount of internal bolt force needed to transmit the power through friction alone is then:
F=80811 N
And
N=80811⁄0.3÷12
N=22.45 kN per bolt
SF=16.67⁄22.45
SF=0.75
Provided that the bolts are torqued to the recommended value of 40 Nm the connection would not be able to transmit the torque through friction alone.
For the ideal working, increase the number of bolts so that the power would be transmitted through friction alone, say 16 bolts...
I see that this is an old thread, just thought my feedback would do some good...
I have received nasty Warnings in the past from PF about revealing the entire solution to the OP without giving them an adequate chance to solve it themselves, and have had my replies removed from the thread. How come no one is receiving Notifications in this thread?
Hi Chestermiller! :smile:
I'm not a mentor, but I'll guess that it's because the OP asked the question over a year ago, and …
Chestermiller said:
… without giving them an adequate chance to solve it themselves …
… probably has solved it himself by now! :wink:
Yes I guessed that this is very old so the solution would have been found, seeing that you say that I gave the entire solution I believe my equations is correct?
Just came upon the thread and saw no solution has been found that seems correct for me, and i tried giving a solution.
Chestermiller, did not even know about the NASTY WARNINGS, but will keep it in mind for the future, thanks...
You already have much good help in finding the simple solution, but it should be noted that in my experience shaft imbalance often becomes the dominant factor in real rotating flange design. Either because of a manufacturing error or because of a potential mechanical failure.
1. How do I determine the number of bolts needed for a flanged coupling?
To determine the number of bolts required for a flanged coupling, you will need to know the size and class of the coupling, as well as the diameter and pressure rating of the pipe being connected. There are also equations and charts available to help with this calculation.
2. Can I use fewer bolts than the recommended number for a flanged coupling?
No, it is not recommended to use fewer bolts than the recommended number for a flanged coupling. The number of bolts is determined based on the strength and stability needed for the connection. Using fewer bolts can lead to a weaker connection and potential failure.
3. Is there a standard number of bolts for all flanged couplings?
No, the number of bolts required for a flanged coupling will vary depending on the size, class, and pressure rating of the coupling. It is important to follow the manufacturer's recommendations for the specific coupling being used.
4. Can I use bolts of a different material for a flanged coupling?
It is recommended to use bolts made of the same material as the flanged coupling for optimal performance and compatibility. However, if necessary, bolts of a different material may be used as long as they meet the same strength and size requirements.
5. Are there any safety precautions I should take when installing bolts for a flanged coupling?
Yes, it is important to follow proper safety precautions when installing bolts for a flanged coupling. This includes wearing appropriate protective gear, using the correct tools, and following proper installation procedures to ensure the bolts are tightened to the correct torque and evenly distributed around the coupling.
9K
11K
