How do you derive this alternate form of the gamma function?
In summary, the integral expression for the Gamma function can be written in two forms: the first being (x^(n-1))*e^-x integrated from 0 to infinity, and the second being (x^(2n-1))*e^(-x^2) integrated from 0 to infinity. This can be achieved by making a simple change of variables, substituting 't' for 'x' in the second integral.
Zatman
86
[itex]\Gamma[/itex](n) = int(0 to infinity)[(x^(n-1))*e^-x]dx
Show that it can also be written as:
[itex]\Gamma[/itex](n) = 2int(0 to infinity)[(x^(2n-1))*e^(-x^2)]dxI have no idea how to go about this. I have tried integration by parts of each to see if anything relates, but how can you get from an exp(-x) to and exp(-x^2) term?
Any help would be appreciated.
(PS apologies, I am unfamiliar with writing formulae using latex)
A simple change of variables will do the trick. Take another look at the integrals and see if you can figure out what substitution you should make.
(Maybe it will help you see it if you use the variable 't' instead of 'x' in the second integral)
Right, I was getting confused because I thought the x in each was the same.
But that makes sense, thank you. :)
1. What is the purpose of deriving an alternate form of the gamma function?
The gamma function is a mathematical function that represents the generalization of the factorial function to non-integer values. Deriving alternate forms of the gamma function can provide a more efficient way of calculating the function and can also help in solving complex mathematical problems in different fields such as physics, statistics, and engineering.
2. How is the alternate form of the gamma function derived?
The alternate form of the gamma function is derived using the properties and identities of the gamma function, such as the reflection formula and Euler's reflection formula. It involves manipulating the original form of the gamma function using these identities to obtain an equivalent but more simplified form.
3. What are the benefits of using the alternate form of the gamma function?
The alternate form of the gamma function can be easier to work with and can provide more accurate results than the original form. It can also help in simplifying complicated integrals and solving certain types of equations that involve the gamma function.
4. Are there any limitations to using the alternate form of the gamma function?
While the alternate form of the gamma function may be more convenient in certain situations, it may not always be applicable. Some problems may require the use of the original form, and the alternate form may not provide the desired solution. Additionally, the alternate form may not be as well-known or widely used, making it less accessible for some researchers.
5. How is the alternate form of the gamma function used in real-world applications?
The alternate form of the gamma function has various applications in fields such as statistics, physics, and engineering. For example, it is used in calculating probabilities in statistical distributions, solving differential equations in physics, and analyzing complex systems in engineering. It is also used in various mathematical models and algorithms to improve efficiency and accuracy.
  • Calculus
  • Calculus
