Why Does the Wizard Slip at 7.35 Seconds on a Rotating Platform?
  • Thread starter VinnyCee
  • Tags
    Slip Time
In summary, the wizard, who has a mass of 80 kg and sits 3 m from the center of a rotating platform, experiences an increase in speed from rest by 0.4 m/s^2 due to the rotation. The coefficient of static friction between his clothes and the platform is 0.3. To determine the time required for him to slip, we use the equations for forces and kinematics to find that the time is 7.39 seconds.
VinnyCee
489
The wizard has a mass of 80 kg and sits 3 m from the center of a rotating platform. Due to the rotation his speed is increased from rest by [itex]\dot{v}\,=\,0.4\,\frac{m}{s^2}[/itex]. If the coefficient of static friction between his clothes and the platform is [itex]\mu_s\,=\,0.3[/itex], determine the time requiredto cause him to slip.
http://img150.imageshack.us/img150/1639/problem13784pt.jpg
Here is what I have, it is off by 0.4 seconds though:
http://img150.imageshack.us/img150/8531/problem1378fbd4za.jpg
[tex]\sum\,F_y\,=\,N\,-\,W\,=\,m\,a_y\,\Rightarrow\,N\,=\,W[/tex]
[tex]N\,=\,784.8N[/tex]
[tex]\sum\,F_x\,=\,f_s\,=\,m\,a_x\,\Rightarrow\,\mu_s\,N\,=\,m\,a_x[/tex]
[tex]a_x\,=\,\frac{\mu_s\,N}{m}\,=\,\frac{(0.3)\,(785\,N)}{80\,kg}\,=\,2.94\,\frac{m}{s^2}[/tex]
[tex]t_{slip}\,=\,\frac{a_x}{\dot{v}}\,=\,\frac{2.94\,\frac{m}{s^2}}{0.4\,\frac{m}{s^2}}\,=\,7.35[/tex]
The book has 7.39s and the units don't match!
You are neglecting the kinematics of this problem. Your work is perfect to the point where you have found the force of friction. Which can sustain a maximum acceleration of u*g. (2.94 m/s^2)
Now think of the in plane components of acceleration. The problem states that he is initially accelerating at 0.4 m/s^2. Because he has no initial velocity this must mean that this acceleration is purely tangential. Notice that this component of acceleration is always tengential to the path the wizard. But remember, as the velocity increases to be non-zero we obtain a centripetal component of acceleration that will always act radially inwards with magnitue v^2/r.
Now if we apply basic kinematics v = vdot*t and by application of the pythagorean theorem the acceleration as result of both the centripetal and tangential accelerations is then.
a = sqrt([(vdot*t)^2/r]^2 + vdot^2)
notice the first term corresponds to the centripetal acceleration
the second term corresponds to the tangential acceleration
since F = ma , it must then follow that
u*(g/m) = sqrt([(vdot*t)^2/r]^2 + vdot^2)
now we simply solve for t.
You can check your dimensions and will find here that by solving for t we will have it such that dim[t] = T
Also, this will yield an answer of 7.39 s when using your numbers along with g = 9.8 m/s^2.
Good Luck!
Note: I am assuming that the platform is rotating with a constant angular velocity and that the wizard is starting from rest at time t=0.
Your calculations are correct, but there may be some rounding errors that result in the slight difference in time. Additionally, the book may have used a different value for the acceleration due to gravity (9.8 m/s^2) which could also account for the difference in time.
Also, it is important to note that the coefficient of static friction is dependent on the normal force, so as the wizard's speed increases, the normal force will also increase, resulting in a higher frictional force and a longer time before he slips. Therefore, the time to slip may not be exactly 7.39 seconds and could vary slightly depending on the specific situation.
1. What is "Wizard's Slip Time: 7.35s"?
"Wizard's Slip Time: 7.35s" refers to a specific time measurement in a hypothetical scenario where a wizard is able to manipulate time and slip through it for 7.35 seconds.
2. How was the time of 7.35 seconds determined?
The time of 7.35 seconds was determined through scientific calculations and theoretical models based on the concept of time manipulation by a wizard. It is a hypothetical scenario and not an actual measurement.
3. Can a wizard actually slip through time for 7.35 seconds?
As of now, there is no scientific evidence or proof that a wizard or any other entity can manipulate time in such a precise manner. It is purely a hypothetical concept and not a proven phenomenon.
4. What is the significance of 7.35 seconds in this scenario?
The time of 7.35 seconds is significant as it represents a specific and precise time measurement in the hypothetical scenario of a wizard manipulating time. It is used to illustrate the concept and make it more relatable to the audience.
5. How does "Wizard's Slip Time: 7.35s" relate to real-life science?
Although the concept of a wizard manipulating time is not supported by science, the idea of time manipulation itself is a subject of interest in the scientific community. The hypothetical scenario of "Wizard's Slip Time: 7.35s" can be used to explore and discuss the scientific theories and possibilities of time manipulation.
