New Reply
Problem reading thermodynamic tables
Share Thread Thread Tools
Feb2-13, 01:17 PM   #1
Hi!!
I have trouble understanding this:
Given Temperature:
If pressure < saturation pressure => Overheated Vapor
If pressure > saturation pressure =>Compressed Liquid
Why does this happen??
Thanks in advance!!
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Feb2-13, 08:55 PM   #2
Recognitions:
Gold Membership Gold Member
At a given temperature, you can have both pure vapor and pure liquid present together in equilibrium if the pressure is equal to the equilibrium vapor pressure at that temperature. If you try to increase the pressure by reducing the volume of a fixed amount of liquid and vapor, you won't be able to do it. You will just cause some of the vapor to condense and form more liquid. However, eventually, you will cause all the vapor to condense. After that you will be able to increase the pressure, since only liquid will be remaining.
If you try to decrease the pressure by increasing the volume of a fixed amount of liquid and vapor, you won't be able to do ti. You will just cause some of the liquid to evaporate and form more vapor. However, eventually, youwill cause all the liquid to evaporate. After that, you will be able to reduce the pressure, since only vapor will be remaining. This will be referred to as superheated vapor.
New Reply
Thread Tools
Similar Threads for: Problem reading thermodynamic tables
Thread Forum Replies
JANAF thermodynamic tables General Physics 1
Thermodynamic steam tables Classical Physics 2
Thermodynamic tables General Engineering 1
Carbon Dioxide Thermodynamic tables Classical Physics 2
How to read Thermodynamic property tables? General Engineering 4
