Center of gravity and Center of mass different?
In summary, the conversation discusses the difference between center of gravity and center of mass. They explore scenarios where they may be different, such as when gravity varies over an object or when there is no gravity present. The students also discuss different definitions of center of gravity and how it relates to torque and gravitational force. Ultimately, they conclude that in most cases, center of gravity and center of mass are used interchangeably, but there may be instances where they differ.
Macdman11
Center of gravity and Center of mass different??
I was developing a test for my students and always look for a difficult question as the only bonus question. I came across the question in the book, "When are center of gravity and center of mass different?". I thought about it before looking at the book's answer; and I thought most likely when gravity varies over the object and the book agreed. Then the students argued that it could happen if there is no gravity on the object. Since CoG is the average location of an object's weight, and the object isn't massless, wouldn't the CoM & CoG be different?
Think about it, would something that doesn't have mass even have a CoM or a CoG?
An object floating in space with no gravity still has a center of gravity. (I guess center of mass would be more appropriate.) The CoM would immediately become apparent if a force were applied such as thrust from an engine or some other external force. Also, if the object had a spin, it would rotate about the CoM.
In the absence of gravity, would CoG have any meaning? (CoM would be perfectly well defined, of course.)
In common usage, center of gravity and center of mass are used interchangeably, since a uniform gravitational field is assumed. But here we are distinguishing the two and not assuming uniform gravity.
I really thought "CG" was only used colloquially these days but I'm sure people will shower me with learned references where it's used.
Hehe, clever students. I guess it depends on how you define centre of gravity. The definition I like best is that the centre of gravity is the point around which there is zero torque due to gravity, which is the solution to this equation (where capital R is the possible solution):
[tex]\int \rho (\vec{r} - \vec{R})\wedge \vec{g} \ dV = 0 [/tex]
So if there is zero gravitational field, then any position in space is a solution, and so the solution is not unique, and in fact includes all space. I guess this is intuitive from the definition above, because if there is no gravity, it cannot create a torque around any point.
That makes me think of something - are we guaranteed that the centre of gravity is unique? When the gravitational field is zero everywhere, then it is not unique, but is there some mathematical law that says the solution to R in the integral above should be unique if the density and gravitational field are not zero everywhere?
Edit: there is also the complication of 'self-gravity' of the object, as rudolfstr brought up. But I think assuming zero 'self-gravity' is OK for this problem, even though it is not strictly possible in the real world.
If gravity isn't uniform across an object is it possible for it to have more than one center of gravity?
I thought about it a bit longer and if we use the definition "The centre of gravity is the point around which there is zero torque due to gravity", then simply due to what torque is, we will never get a unique 'centre of gravity'. Even if the gravitational field is uniform, the centre of gravity is a line of solutions, going through the centre of mass. From the equation I wrote above, if we rearrange, we get:
[tex]\vec{R} \wedge \int \rho \vec{g} \ dV = \int \rho \vec{r} \wedge \vec{g} \ dV [/tex]
This is now just a cross product of the form [itex]\vec{R} \wedge \vec{A} = \vec{B}[/itex] where R is the thing we are trying to find. So if A and B are zero vectors, then any R will be a solution. If B is zero, then R is just cA (where c is any real number, i.e. we have an infinite number of solutions, parallel to A). And if A and B are non-zero vectors, then as long as we can find one R, then the set of all possible solutions is R + cA
So your favorite definition of "centre of gravity" is one that doesn't actually define a centre? What is wrong with using the point, at which all the object's mass concentrated would give the same net gravitational force as the extended object experiences?
If you place a ring around a planet such that the net gravitational force on the ring is zero, then you can assume this zero force acting anywhere you want on the ring. But aside from the cases where net gravitational force on the object is zero, you get a unique center of gravity.
Newton's shell theorem proved that objects graviti is the same as if the whole mass was concentrated in its centre of mass. So in that respect there is no difference between COM and COG. Now as to the behavior of object in the gravitational field, the force on it depends only on distance. The question is now, is it always the distance of COM of the object? Will two differently shaped objects with the same mass always have absolutely same acceleration taking into account minute changes in the field? I believe they will.
Newton's shell theorem applies only to spherical objects.
Not in a non-uniform field.
All this assumes that the gravitational field is Uniform.
The Centre of Mass is independent of gravity so it is more consistent (the first moment of any object).
The point where the gravity from a nearby point mass 'acts' on a rod, will vary with the orientation of the rod so that is not something that could be relied upon. Where is the CM of the Earth-Moon system? Somewhere below the Earth's surface. If you take a 1kg mass and place it near the surface of the Moon, where does the mass of the Earth plus Moon 'act from' when interacting with the 1kg mass. Where is the 'Centre of Gravity? Certainly not just below the Earth's surface.
Sloppy terminology can lead to all sorts of errors.
That's not quite the right definition. You're missing a key part. Take a point that is on your line but is not the center of mass. Now rotate the object a bit. Now you'll get a different line, and your point won't be on it. You'll instead get a torque about that chosen point.
You forgot to add the qualifier "for any orientation of the object". In a uniform gravity field, that qualifier does make the center of gravity unique, and it is the center of mass.
This definition doesn't work in a non-uniform gravitational field.
That definition doesn't work in a uniform gravity field. The center of gravity is indeterminate per this definition in a uniform gravity field because every point qualifies as the center of gravity. This definition is not unique in a non-uniform gravity field; the location of the center of gravity changes as an object changes orientation.
This definition is used occasionally for space-based applications. For example, a space elevator would need its center of gravity rather than its center of mass at geosynchronous altitude.
That's only true for objects with a spherical mass distribution. It's not true in general. A couple of examples: The Earth and the Moon.
The Earth has a non-spherical gravitational field thanks largely to its equatorial bulge. That non-spherical gravitational field is essential for how our sun synchronous satellites work. Place a satellite in such an orbit and the orbital plane will rotate by just the right amount over the course of a year so as to maintain near-ideal lighting conditions underneath the satellite. http://trs-new.jpl.nasa.gov/dspace/bitstream/2014/37901/1/04-0327.pdf .
My other example is the Moon. The Moon's gravity field is rather lumpy thanks to a number of mass concentrations (mascons) on the near side of the Moon. This lumpy gravity field can make for some rather bizarre orbits. http://science.nasa.gov/science-news/science-at-nasa/2006/06nov_loworbit/
That is true, we can fall back to the center of mass in that case. We could generalize the definition, such that self gravity is considered too. Wouldn't that always yield a unique center of gravity, even without external fields and in uniform fields?
Why would you define it that way? Using that definition: It is not unique (only in exceptional circumstances). And it is not a point around which the torque due to gravity is zero (only in exceptional circumstances). Unless I am missing something...
My definition works in a non-uniform gravitational field. My definition is that the torque around the centre of gravity is zero. So if I actively rotate the object, its centre of gravity will change such that it remains at a point around which there is zero torque. I say my definition. But it isn't mine, of course. We are all standing on the shoulders of giants.
It is not unique in a trivial case, where it is not relevant. Only in a non-uniform fields you need to distinguish between center of mass and center of gravity.
If I understood you correctly on the last page, your definition for the centre of gravity is:
[tex]\int \rho \vec{g} \ dV = M \vec{g}_{(cg)} [/tex]
Where I use the subscript cg to mean the gravitational field evaluated at your 'centre of gravity'. So, if we use the above equation to define the 'centre of gravity', you can see that there will generally be more than one possible value for the 'centre of gravity'. Also, this definition is not useful, because the 'centre of gravity' will not generally be a point around which there is zero torque due to gravitational forces.
I think that maybe you were thinking of the law which says that a spherically symmetric mass distribution produces a gravitational field that is the same as one where all the mass was contained at the centre of mass. But this law is completely unrelated, and does not help us with a definition of a centre of gravity.
My definition says that the centre of gravity is the line of points around which there is zero torque on the object due to gravity. The intuitive way to think about this definition is if you have an object in a non-uniform gravitational field, and you want to keep it from moving by applying a contact force at a single point, then you would have to apply the contact force somewhere along the line of points which make up the 'centre of gravity'. Otherwise, gravity will cause the object to begin to rotate.
I think that you can think of the centre of gravity as the following:
Since we all seem to agree on where the centre of mass would would be, I will start there.
Maybe the centre of gravity would be calculated(if it ever became possible) by forming an infinite amount of vectors from the centre of mass out to all the conceived edges of the field of gravity, and adding these all together as vectors, which would lead to the centre of gravity. The implications are that if there is a non uniform field of gravity, then the centre of gravity is likely way off from the centre of mass.
Maybe?
I'm a year 11 student doing physics, and became extremely interested in this debate. Please be nice when you shoot me down for making some huge mistake in this concept of mine.
What is the difference between center of gravity and center of mass?
The center of gravity (CoG) is the point where the weight of an object is evenly distributed and acts as a single force on the object. It takes into account the distribution of mass and the effects of gravity. The center of mass (CoM) is the point where the mass of an object is evenly distributed and acts as a single point of mass. It takes into account only the distribution of mass and does not consider the effects of gravity.
Why is it important to know the difference between center of gravity and center of mass?
Understanding the difference between CoG and CoM is important in various fields such as engineering, physics, and sports. It helps in predicting the stability and motion of objects, designing structures and vehicles, and determining the balance and agility of athletes.
Can the center of gravity and center of mass be at the same point?
Yes, the center of gravity and center of mass can be at the same point if the object is in a uniform gravitational field. In this case, the CoG and CoM will coincide at the geometric center of the object.
How is the center of gravity and center of mass calculated?
The center of gravity can be calculated by dividing the total torque of an object by its total weight. The center of mass can be calculated by dividing the sum of the mass of each part of an object multiplied by its respective position by the total mass of the object.
What factors can affect the center of gravity and center of mass of an object?
The shape, size, and distribution of mass in an object can affect its center of gravity and center of mass. External factors such as gravity, air resistance, and fluid dynamics can also influence the location of the CoG and CoM. Additionally, any changes in the mass or distribution of mass within an object can also alter its center of gravity and center of mass.
  • Other Physics Topics
  • Classical Physics
  • Classical Physics
