| New Reply |
Simple combinatorics gone wrong... |
Share Thread | Thread Tools |
| Feb6-13, 09:04 AM | #1 |
1. So consider an 8 megapixel picture (res: 3264x2448).
Now, it seems rather simple but I just can't figure out how to calculate the entire number of possible shots/photographs one can take within that resolution, assuming each pixel can have 16777216 different values/colors. 2. Relevant equations 3. The attempt at a solution So I realize the number has to be absolutely monstruous, so here's what I've tried so far (3264*2448)!*2^24 Meaning, the entire possible positions all the pixels can assume times all the different values each individual pixel can have. |
| Feb6-13, 09:10 AM | #2 |
It seems your solution is correct for a JPG image but for a GIF you limited to 256 colors per image. Each color may range from 0 to 16million as a GIF uses an 8 bit value that indicates which color register from the color palette to use.
One problem I see is that you'll get shots all in one color or half one color half another... Do you want to define what a photo is? like it must have a minimum of X colors per photo? Next what about color changes that are imperceptibly small? Do you want to instead say that while RED can range from 0 to 255 in value we'll limit it down to a subset of {0, 16, 32, 48, 64 ... 255} in other words 64 color choices. |
| Feb6-13, 09:18 AM | #3 |
Recognitions:
| Feb6-13, 09:36 AM | #4 |
| Feb6-13, 09:38 AM | #5 |
| Feb6-13, 09:42 AM | #6 |
Recognitions:
| Feb6-13, 09:42 AM | #7 |
Since jpeg is a lossy format a lot of those combinations ought to evaluate to the same output. I could be wrong. |
| Feb6-13, 09:56 AM | #8 |
| Feb6-13, 10:03 AM | #9 |
Okay, got it. The solution is a number whose log is 115 805 766.
Thanks, guys. |
| New Reply |
| Thread Tools | |
Similar Threads for: Simple combinatorics gone wrong...
| Thread | Forum | Replies | ||
| Simple combinatorics about an 8 MegaPixel shot | General Math | 7 | ||
| Simple combinatorics problem | Set Theory, Logic, Probability, Statistics | 3 | ||
| Elementary combinatorics problem - why am I wrong? | General Math | 4 | ||
| Simple Combinatorics: What are odds of picking same number? | General Math | 5 | ||
| simple combinatorics q | Set Theory, Logic, Probability, Statistics | 5 | ||
