Why does the rope move with only 5N force applied?
In summary, the conversation discusses a video on pulleys where the narrator uses an example of pulling a rope with 5 Newtons for 2 meters to make a weight of 10 Newtons raise 1 meter. There is a discussion about whether 5 Newtons is enough to move the weight, and it is concluded that while 5 Newtons can keep the weight moving at a constant speed, slightly more than 5 Newtons is needed to start the weight moving. The conversation also addresses the importance of understanding the difference between X = 5 and X > 5 in this scenario.
DocZaius
365
Hello,
I am having trouble understanding an example shown on youtube regarding pulleys.
http://www.youtube.com/watch?v=vSsK7Rfa3yA#t=3m0s
In the example in the video above (I linked to the time when the example starts), the narrator uses an example where he pulls a rope with 5 Newtons for 2 meters, making a weight of 10 Newtons raise 1 meter. He is demonstrating mechanical advantage.
http://en.wikipedia.org/wiki/File:Pulley1a.svg
That is the basic setup, with W = 10N
However my understanding is that if 5 Newtons is applied to the end of that rope, the system will be in equilibrium. In the picture above, the implication seems to be that if the end of the rope has W/2 applied to it, there is no movement.
So how can the person in the video be pulling on that rope with a force of 5 Newtons and make the rope move at all?
Thanks.
Hello DocZaius! :smile:
DocZaius said:
… my understanding is that if 5 Newtons is applied to the end of that rope, the system will be in equilibrium. In the picture above, the implication seems to be that if the end of the rope has W/2 applied to it, there is no movement.
You're right, it will take slightly more than 5N to start the rope moving …
but once it is moving, it can be kept moving at constant speed without any net force, so 5N is enough. :wink:
tiny-tim said:
Hello DocZaius! :smile:You're right, it will take slightly more than 5N to start the rope moving …
So if I understand you correctly, the author of the video must have been pulling the end of the rope with a force X > 5N. And we must then use that X (which is NOT equal to 5) in the rest of his calculations.
Is that right? If this is correct, I feel it can be confusing and misleading to a student to be given X = 5N when X MUST be greater than 5N.
This is much ado about nothing. I see no decimal points there, so quibbling over whether you need 5N or 5.0000000000000000001N isn't useful.
DocZaius said:
… the narrator uses an example where he pulls a rope with 5 Newtons for 2 meters, making a weight of 10 Newtons raise 1 meter. He is demonstrating mechanical advantage.
I haven't watched the video, but you haven't quoted anything from it that contradicts the correct statement that, using this pulley, you can move a weight of 10 N with a force of 5 N.
I understood from your previous reply than 5N isn't enough. You need slightly more than 5N.
My interpretation of your previous reply is that once you attach a weight of 5N at the end of the rope, all it takes is a force greater than 0 pulling on the end of that rope (in addition, of course, to the 5N weigh you just attached) for the 10N weight to move up.
If this interpretation is incorrect, please tell me where I go wrong. If this interpretation is correct, then it seems to me you can't move that 10N weight up with a force of exactly 5N.
I think the difference between X = 5 and X > 5 is quite important and in this particular case, seems to be the difference between a 10N weight moving up and a 10N weight not moving up.
You can move it with 5 N. You can't start it moving with 5 N.
Thank you for that clarification. Seems to me that a student might have said (and been correct) that if all the instructor is doing is applying exactly 5N to the end of that rope, that rope isn't moving. Then as an aside, the instructor maybe would have said that for a split second he pulled very slightly harder than 5 N and then went back to pulling with exactly 5N for the remainder of the distance. He then would say he ignores that very tiny force at the beginning and resumes his calculations. This approach seems not entirely correct (since that initial extra force is ignored) but seems more correct than a constant 5 N scenario.
No, if all the instructor is doing is applying exactly 5N to the end of that rope, that rope isn't accelerating. But it certainly can be moving.
Btw, you still haven't quoted what the video actually says, that you disagree with.
I am back to confused again. It can be moving with exactly 5N?
Imagine for the following picture that W=10 N and that a 5 N weight is attached at the end of the rope. No other forces - the weight attached is exactly 5N. This is the initial setup. What happens? Is there any movement?
I thought there wouldn't be, but your "can be moving" statement puts that into doubt again.
Please note that the above scenario I just proposed is not the scenario in the video (since in the video there is movement). I am only asking about this scenario to see if I understand a more basic situation correctly (one in which the pulley system does not move).
Until I have the behavior of the pulley system down correctly, I will hold off on what I think is incorrect about the video, since my claim would be based on my own mistakes.
If the initial setup is stationary, it will remain stationary. If the initial setup is moving, it will continue to move with the same speed.
There will be no acceleration.
In your original example, if the instructor is applying exactly 5N to the end of the rope, then the rope isn't accelerating. But it certainly can be moving.
OK, it is as I thought regarding the 5N weight's effect on the system with an initially stationary setup.
Then back to my problem with the video. I cannot quote something from the video as you request, since my problem lies with what is not said. The instructor never accounts for the reason the rope is initially moving. He never says the initial setup is moving (shouldn't we assume an initial setup is not moving if it is not explicitly stated otherwise?). He never says he initially pulls with a force greater than 5N (to accelerate it), to then go back to exactly 5N (to keep it moving at the same speed).
One is left to wonder, why is the rope initially moving without any accounting for it?
The reason I bring this up is that many students would assume a force of 5N was enough to accelerate it. They will watch the video and think "pulling that rope with 5N accelerated that rope since the instructor stated no other interaction made with the system" when as you say, 5N only keeps it moving at its speed.
1. What is the "Problem with Pulley" video about?
The "Problem with Pulley" video is a demonstration of a physics problem involving a pulley system, where a weight is attached to one end of a rope that is threaded through a pulley and attached to a support. The video shows how the weight moves when different forces are applied to the rope, highlighting the complexities and challenges of understanding pulley systems.
2. What is the purpose of the "Problem with Pulley" video?
The purpose of the "Problem with Pulley" video is to illustrate the concept of mechanical advantage and the challenges of understanding and solving problems involving pulley systems. It also serves as a visual aid to help students or viewers better understand the principles of pulleys and how they work.
3. Who created the "Problem with Pulley" video?
The "Problem with Pulley" video was created by a team of scientists and educators who specialize in physics and engineering education. The team worked together to develop and film the video in order to provide a clear and engaging demonstration of a common physics problem.
4. What can I learn from the "Problem with Pulley" video?
The "Problem with Pulley" video can teach viewers about the principles of pulley systems, including mechanical advantage, the relationship between forces and motion, and the challenges of solving complex problems involving multiple forces. It also highlights the importance of understanding and applying physics concepts in real-world scenarios.
5. Are there any follow-up resources or activities related to the "Problem with Pulley" video?
Yes, there are several resources and activities that can be used in conjunction with the "Problem with Pulley" video to further explore and understand the principles of pulleys. These may include worksheets, online simulations, or hands-on experiments with pulley systems. Additionally, there may be other videos or tutorials available to expand upon the concepts presented in the "Problem with Pulley" video.
21K
  • Other Physics Topics
