What are the three types of objects described by science?
In summary: i'm not sure. sorry i was on a god kick this mornin. i believe in a god. i believe in science. as a species could we become smart enough to insure the conditions for life happen...i'm not sure.
John Jones
36
Science describes three types of object. The first two are those that can be hidden - material objects, and those that are necessarilly hidden - quantum objects. Thus, we have an independent source supporting Popper's* view that science is the domain of the empirically falsifiable, as hidden objects are a source of falsification and are the objects of science. Empirical is, in effect, the domain of the hideable.
There are other types of objects that are not hideable, hence not empirical or subject to falsification or Popperian doubt. Such objects are numerous, they include colours, sounds, and smells.
The third class of object of science is the supernatural object. This is a non-Popperian postulate of science that has been designed. There are two reasons for this design.
1) to discredit mystical practices and ideas,
2) to establish causal relationships on the basis of non-empirical associations.
The supernatural object is not a mystical object. The mystical object belongs to the class of objects that vanish and appear without empirical redress. On the other hand, the derogatory supernatural object of science changes its form between the mystical object, and the empirical or hideable object, and vice versa; for example, the idea that gods physically cause thunder.
The other, causal/associative, supernatural object of science also changes form supernaturally but finds a role in justifying certain studies of science, such as psychiatry where brain is said to cause mind in what is at root a supernatural causation.
Science, then, supports three types of object. Two of these are the hideables, the third is the supernatural object of which science describes two types.
(* Popper:
But I shall certainly admit a system as empirical or scientific only if it is capable of being tested by experience. These considerations suggest that not the verifiability but the falsifiability of a system is to be taken as a criterion of demarcation. In other words: I shall not require of a scientific system that it shall be capable of being singled out, once and for all, in a positive sense; but I shall require that its logical form shall be such that it can be singled out, by means of empirical tests, in a negative sense: it must be possible for an empirical scientific system to be refuted by experience. (1959)
Science really does have nothing to say on the supernatural. I think you are making this far more abstract than an explanation of science needs to be.
Empirical science works to build predictive models with explanatory power. We take an observation of a phenomenon, build a hypothesis, perform experiments and conclude from the results.
By definition science deals with the natural. Supernatural is a word that does not make sense in science, if it exists it can be studied and understood.
i teach my son how to use logic so he is prepared to deal with most problems. for the rest we have a god. scientific method will only take you so far, then you have to rely on the unknown to deal with the unknown. i find science to be lacking. it can tell me the process by which i see a photo but fails to explain why i feel a crushing nostalgia at the sight of it. what's worse it doesn't even try. it can't be quantified so it doesn't exist. that is an approach which doesn't sit well with me. on the other hand in times of dire need a god has come through for me. I've been given shabby theories about statistical anomalies, delusion or even coincidence. i don't need an explination. i asked and it was taken care of. i have yet to get that from science.
This is totally untrue. The entire field of psychology is devoted towards the study of human behaviours like this, behavioural and cognitive neuroscience is investigating such phenomenon also. Simply because science does not have an answer yet does not mean that the subject cannot be scientific so we must rely on illogical mystical feelings. An unknown is an unknown
sorry i was on a god kick this mornin. i believe in a god. i believe in science. as a species could we become smart enough to insure the conditions for life happen again. say after a bounce or crunch or perhaps heatdeath? that would satisfy my definition of god and science would do the trick to accomplish it.
Hello John,
When did "Science" say this?
And, by the way, I am counting 4, maybe 5, types on your list:
the (2) "hideables", the (1) "unhideable", and the (1) supernatural (with two subtypes?).
What does it mean to be hideable, and what makes colors, sounds, and smells not hideable?
By 'we' I assume you mean you and your family? Certainly doesn't apply to me.
Nonsense. What does that even mean?
In what way?
Why must science be able to tell you this? That isn't the purpose of it. Why do people keep discounting science because it doesn't know something? (See signature for my exact thoughts on that matter.)
Regardless, there are many, many people in a host of fields attempting discover exactly what you describe there.
whats worse it doesn't even try.
Yes it does, as above.
Huh?
You can apply scientific method to anything - from your findings you come to conclusions - people repeat and confirm / disprove your conclusions. If the tests don't 'find' anything, that doesn't mean science just gives up. It just doesn't have anything to say on the matter at that time - without evidence, science doesn't say anything.
As above, it doesn't exist.
Electric supply, medicine, water supply, gas supply, transportation, etc etc etc - let's not play games, if it wasn't for science the modern world wouldn't exist. We get a lot (if not everything) from science and it's ridiculous to say you haven't had anything from science in a "asked and received" kind of way.
I'll not comment on the god side of things, suffice to say it isn't a welcome discussion of mine.
Math Is Hard said:
Hello John,
Before I comment on the OP, I'd also like to have this clarified.
Because your text doesn't use capital letters I find it very disconcerting to read, almost straightaway. It's very distractiing to finding out what you want to say.
I will look at it again.
I said what science had to say about the supernatural. Honestly, look at it again.
Math Is Hard said:
Hello John,
When did science say this? Science hasn't said it. It wouldn't be empirically testable. Science can't say it.
Science doesn't deal with the non-hideables, like colours and sounds. These are non-hideable in that they vanish when the hideable is hidden. On the other hand, the hideable -materials - don't vanish when they are hidden.
There are more than four or five types of object. I am able to consider only one of four or five of these types, but won't introduce it here.
Then, look at the OP, look at the OP.
Science doesn't have anything to say about the supernatural. End of story.
Science cannot form an 'opinion' without something to form it with. Without evidence (anecdotes are not evidence) it cannot say anything, so it doesn't.
Uh what? Science most certainly does deal with those items.
You still haven't clarified what those terms mean. Repeating them over and over in a circular description doesn't help.
RE Bolded: What you said there = "they can't be hidden because they disappear when the hideable is hidden" - what the heck does that mean? If something disappears when something else is hidden, it most certainly is "hideable". Of course, without clarification of the phrases you use, I'm taking hideable to mean "you can hide it".
I have, the above stands.
I was asking about your opening comment where you stated:
I want to know where that came from.
Also, JJ, in your OP you said;
Which could be contracted to say;
The third class of object of science .. the supernatural object .. has been designed .. to discredit mystical practices and ideas ..
A supernatural object has been designed to discredit mystical practices and ideas ?
I don't get it. And designed by who or what ?
I suggest you may have to be a little less quixotic for others to engage in your points of interest.
Look! Wait! what's that?
The Lock-ness Monster? :tongue:
Hideable means you can hide it. You cannot hide a colour. Colour is not a property of the hideable object. When the the room is dark the red object is not red, nor was it any colour.
It was me. I said that science had 3 types of object.
why isn't the multiquote button still not working.
John Jones, you should do some reading so that the vocabulary, terminology and concepts you use are more in line with those that you wish to discuss things with.
You're kind of way out there and not making a lot of sense.
I already gave an example of science's discreditation of mystical practices and ideas, and named the type of objert that they, science, had created to help them do it - they created the supernatural object.
Who is "they"?
Science?
Science ... people ... created the supernatural?
What are you reading?
Likes maria x
DaveC426913 said:
Who is "they"?
Science?
"Science" is the name of a breakaway cult. Just as society is the name of what's left. People.
I think you're on the wrong forum.
Science is the name of a method of inductive inference, the scientific method. Science talks about two things: theories and experimental data. There is no mention in the scientific method of "types of objects" or "hideable" anything.
a galaxy expanding away faster than the speed of light will eventually be outside our observable universe. with no way to observe it or experiment with it, it just becomes a point of speculation. no longer in the realm of science because of our limiitations. the same goes for the origins of our universe. theories on this are just speculation as we lack the means to recreate these conditions. at some point scientific method surrenders to the unknown.
Try and argue, not ban.
You presented your belief in science. Is that your topic? Give it a try. Say more.
No it isn't. It's not science that is inductive but ordinary common sense. Science is the name of a movement that calls induction its own.
We're done here. Thanks all.
1. What are the three types of objects described by science?
The three types of objects described by science are living organisms, non-living objects, and abstract concepts.
2. How are living organisms described in science?
Living organisms are described by their characteristics, behaviors, and interactions with their environment. This includes their anatomy, physiology, genetics, and evolutionary history.
3. What are some examples of non-living objects described by science?
Examples of non-living objects described by science include rocks, minerals, water, and other inanimate objects. These objects are studied through various scientific fields such as geology, chemistry, and physics.
4. How are abstract concepts described in science?
Abstract concepts, such as time, space, and energy, are described through mathematical models and theories. These concepts are used to explain and understand the natural world and are constantly being refined through new scientific discoveries.
5. Can objects be classified as both living and non-living in science?
No, objects cannot be classified as both living and non-living. Living organisms have certain characteristics, such as the ability to grow and reproduce, that non-living objects do not possess. However, some objects, like viruses, can blur the line between living and non-living and are still being studied and debated in the scientific community.
  • General Discussion
  • Art, Music, History, and Linguistics
  • Other Physics Topics
  • Quantum Interpretations and Foundations
  • Beyond the Standard Models
10K
