20% of Antibodies not specific?
In summary: The article concerns validation of a method to measure the spatial distribution of expressed proteins by siRNA. The article does not mention validation of reagents.
gravenewworld
1,132
Nice little paper about properly validating your reagents:
http://www.ncbi.nlm.nih.gov/pubmed/22361696Why is it in academia absolutely no one validates their reagents like antibodies while in industry it is absolutely required?
Rather than admitting their results are due to nonspecific binding, I've seen some papers where academics attribute their results to say something like another unknown isoform of the protein that they're studying.
Why is it that the peer review system has completely and utterly failed to to address this type of terrible science? What's worse is that once results that come from an antibody that might not be specific is published, many other labs go out and start using the same antibody to study the protein(s) in question.
What a complete an utter joke a lot of science being done now has become. Manufacturers are notorious for being lazy when it comes to validating their antibodies, academics simply take it for granted that they are supposed to work. Maybe it is time our universities do high quality science with validation like industry?
Biology news on Phys.org
I always validate my antibodies and indeed I've found many commercial antibodies to be non-specific. I don't recognize your statement that in academia no one validates their reagents. What I wonder is whether the paper you cite has validated the specificity of the siRNA :biggrin:
<snip>
I won't have access to the full article until Tuesday (access thru work), but based on the abstract, I don't understand why you say the article concerns validation of reagents. I read the abstract as validation of a method to measure the spatial distribution of expressed proteins by siRNA (alternatively, validation of the siRNA method as per Monique).
Why do you say "validates their reagents like antibodies"?
I don't find the paper impressive and they appear to ignore the fact that knockdown might not be efficient or has off-target effects. The idea to use siRNA to verify protein localization is not new.
The statement that absolutely no one validates their reagents is ridiculous, it makes me wonder what field you are into have such a view. The statement that in industry the validation is absolutely required is not valid either since I mentioned that commercial antibodies can also be a-specific. I would applaud it if these antibody selling companies would validate their products.
To play Devil's advocate, there are other uses for antibodies than immunofluoresence and often the antibodies that work well for immunofluorescence do not work well for these other applications (such as Western blotting). So, these 20% of commercially available antibodies that don't seem to work well aren't necessarily worthless (although from experience, I've come across plenty of commercially available antibodies that don't seem to work well for any purpose).
Sure- most manufacturers even suggest 'optimal' applications (for primary antibodies: ELISA, WB, IP, IF, etc.), see http://igene.invitrogen.com/isearch/antibody.do
It's also true that *negative* controls should *always* be performed to check against non-specific binding (for example). Lastly, since experimental systems vary so widely all protocols: immunohistochemistry, siRNA, transfection, etc, must be carefully optimized: what works on one cell type may not work on another.
The OP did not understand the content of the linked article.
1. Why are 20% of antibodies not specific?
There are two main reasons why 20% of antibodies may not be specific. One reason is that the antibody may bind to different targets, resulting in cross-reactivity. Another reason is that the antibody may have low affinity for its intended target, meaning it does not bind strongly enough to accurately detect it.
2. How can we determine if an antibody is specific?
There are several methods used to determine antibody specificity, including Western blotting, enzyme-linked immunosorbent assay (ELISA), and immunohistochemistry. These techniques involve exposing the antibody to different targets and measuring its binding affinity and selectivity.
3. What are the consequences of using a non-specific antibody?
Using a non-specific antibody can result in false positive or false negative results, leading to inaccurate data and conclusions. This can also waste time and resources, as well as potentially harm research progress.
4. How can we improve the specificity of antibodies?
There are several strategies that can be used to improve the specificity of antibodies. These include optimizing the antibody's production and purification process, using rigorous validation methods, and selecting antibodies with known high specificity from reputable sources.
5. Can non-specific antibodies be used in research?
Non-specific antibodies can still have uses in research, such as for identifying general protein expression or as a control in experiments. However, it is important to acknowledge and account for their lack of specificity in data interpretation.
  • Biology and Medical
14K
  • STEM Career Guidance
  • STEM Academic Advising
  • Quantum Interpretations and Foundations
