Calling kinetics experts: rate law from conductivity isnt possible?
In summary, the rate law for the primary halogenoalkane aqueous alkaline hydrolysis reaction cannot be determined using conductivity data. Attempts to curve fit the data show that it does not follow a recognizable integrated rate law plot. Additionally, an initial rates approach does not give a simple multiple of the calculated rate constant. This supports the idea that conductivity data from ion-exchanges cannot be used to investigate reaction kinetics.
Miffymycat
47
Calling kinetics experts: rate law from conductivity isn't possible!?
Consider the usual primary halogenoalkane aqueous alkaline hydrolysis reaction
RX + OH- --> ROH + X-
We know the rate law is first order in RX and OH-. We could separately represent the drop in OH- conductivity as an exponential decay with a constant half-life (ΛoOH-e-kt) and the rise of X- conductivity as the inverse function of this (0.5ΛoOH-(1-e-kt), taking the conductivity of X- as 0.5x that of OH-.
In practice, using excess RX, the measured (or modeled) solution conductivity during hydrolysis is obviously the sum of the ion conductivities at any point in time. The mixture conductivity drop-off appears to be an exponential-type decay, but attempts to curve fit (albeit only in Excel) show it is not, nor does it fit a recognisable integrated rate law plot. One can therefore not obtain a rate constant or order from this progress curve, which is frustrating - unless I'm mistaken! {Its not the case for aqueous hydrolysis as this produces ions from neutral molecules rather than an exchange of ions and the graphs work fine}.
Furthermore, taking an initial rates approach and plotting initial (ΔΛ/t) vs Λfinal (over several initial concentrations, rather than a single Λ vs t curve as above) gives a straight line, but whose slope does not appear to be a simple multiple of the calculated k for OH- decay on its own. The stoichiometry is 1:1, so the rate of [OH-] decline = rate of [X-] growth, and I imagined the slope would therefore be k x ratio of ion conductivities ... but it's not. Its a smaller number.
Any thoughts please?
Chemistry news on Phys.org
Perhaps I am missing something, but
[tex]Ae^{-x} + \frac A 2 (1-e^{-x}) = \frac A 2 (1 + e^{-x})[/tex]
doesn't look like something that can be fit to just e-x.
Agreed, and seems to support the idea that conductivity data from "ion-exchanges" can't be used to investigate reaction kinetics.
Any ideas on the significance of the slope for the linear plot?
I never said that. You can use the conductivity, you just have to fit it to the right equation.
I understand your frustration with trying to obtain a rate law from conductivity data in the hydrolysis reaction you described. However, it is important to keep in mind that conductivity is just one piece of information in a complex reaction system. It is not always possible to obtain a rate law solely from conductivity measurements.
In this case, the hydrolysis reaction involves multiple steps and intermediates, and the conductivity data may not accurately reflect the rate of the overall reaction. Additionally, the presence of excess RX and the stoichiometry of the reaction can also affect the conductivity measurements.
It may be helpful to consider other methods for obtaining a rate law, such as measuring the concentration of reactants and products over time using techniques like titration or spectroscopy. These methods can provide more accurate data for determining the rate law.
Overall, it is important to approach scientific problems with an open mind and consider multiple factors before drawing conclusions. I encourage you to continue exploring different methods and seeking input from other experts in the field to better understand the kinetics of this reaction.
1. What is conductivity and why is it used in kinetics experiments?
Conductivity is the measure of a substance's ability to conduct electricity. In kinetics experiments, it is used to study the rate of a chemical reaction by measuring the change in conductivity over time. This allows scientists to determine the rate law, which describes the relationship between the reaction rate and the concentrations of reactants.
2. Why is it not possible to determine the rate law from conductivity measurements?
Conductivity measurements only provide information about the overall change in conductivity during a reaction, but they do not give specific information about the concentration of individual reactants. In order to determine the rate law, the concentrations of each reactant must be known and measured separately.
3. Are there any alternative methods for determining the rate law?
Yes, there are other methods for determining the rate law, such as using spectrophotometry or measuring the pressure change in a reaction. These methods allow for the direct measurement of reactant concentrations, making it possible to determine the rate law.
4. How can conductivity measurements still be useful in kinetics experiments?
Although conductivity measurements cannot directly determine the rate law, they can still provide valuable information about the progress of a reaction. By monitoring changes in conductivity over time, scientists can observe the overall trend in the reaction and use this information to make predictions about the reaction rate and mechanism.
5. What are some limitations of using conductivity in kinetics experiments?
One major limitation is that conductivity measurements are only applicable to reactions that involve ions, as only ions can conduct electricity. Additionally, changes in conductivity can be influenced by factors such as temperature and impurities in the reactants, which can affect the accuracy of the results. It is important for scientists to consider these limitations when using conductivity in kinetics experiments.
  • Chemistry
  • Materials and Chemical Engineering
  • Mechanical Engineering
