Conservation of Momentum and Dissipation of Kinetic Energy - AP Problem
In summary: On part d, Fn=g(mass)i) Mog ii) g(Ct+Mo) mass as a function of time times acceleration of gravity iii) g(CT=Mo) since the railroad car is no longer filling up.What is the mass of the sand that falls? Is it Ct+Mo?g(Ct+Mo) + g(Ct+Mo)so 2g(Ct+Mo) for iiand iii:2g(CT+Mo)
meganw
97
An open top railroad car (initially empty and of mass M.) rolls with negigible friction along a straight horizontal track and passes under the sprout of a sand conveyor. When the car is under the conveyor, sand is dispensed from the conveyer in a narrow stream at a steady rate delta-M/delta-t=C and falss vertically from an average height h above the florr of the railroad car. The car has an initial speed v. and sand is filling it from time t = 0 to t = T. Express your answers to the following in terms of the given quatities and g.
a) Determine the mass M of the car plus the sand that it catches as a function of time t for 0 < t < T.
b) Determine the speed v of the car as a function of time t for for 0 < t < T.
c) i.) Determine the initial kinetic energy of the empty car.
ii.) Determine the final kinetic energy K final of the car and its load
iii.) Is kinetic energy conserved? Explain.
d.) Determine the expressions for the normal force exerted on the car by the tracks at the following times
i.) before t=0
ii.) for for 0 < t < T.
iii.) after t=T
Conservation of Momentum: m1(v1i) +m2(v2i) = m1(v1f) + m2(v2f)
I got part A by using Calculus: CT + Mo
But I have a question about part b. I was going through the homework archives on this website and I found a previous poster said that:
v(t) = momentum / the mass as a function of time:
v(t) = p/m(t) = m0v0/(m0 + Ct).
My question is:
Why does v(t) = momentum / the mass as a function of time?
And is the reason why can you use m0v0 (the initial momentum) as the momentum for V(t) for the entire time from o<t<T because momentum is conserved throughout the entire time interval?
Thanks! :)
If you consider the "car + enclosed sand" as a system, what is its momentum? Does it change?
The car + the sand as a system makes the momentum= rate of mass (velocity)
Ahhhhhh I see! A little math makes velocity=momentum/rate of mass, thanks! :)
For part c iii I got that when I set the inital and final kinetic energies equal to each other:
Mo^2Vo^2/2(CT+Mo)=Mo(Vo)^2/2
0 =CT
So I'm guessing that means Kinetic Energy is not conserved because CT must be a nonzero since its mass of sand falling into the railroad car.
Is this work correct? Thank You! :)
0 =CT
OK. But rather than set initial and final KE equal, just compare them. KE is not conserved. (The sand collides with the moving car--essentially an inelastic collision.)
Careful here. Don't neglect the height from which the sand falls.
I'm confused. Why does the height matter is we care about the Normal Force?
I'll ask you this: If you step gently on a bathroom scale, what does it read? But what if you jumped down onto it from some height, would it read any different?
Hint: Consider the change in vertical momentum.
I'm still confused. I don't know how to apply this...although now I understand that the normal force would be greater, I don't know the physics to change this..
What force must the car exert on the falling sand to stop its vertical motion?
So would it be
ii) g(Ct+Mo) + Fg of the sand falling? Whats the mass of the falling sand? Is it Ct+Mo?
g(Ct+Mo) + g(Ct+Mo)
so 2g(Ct+Mo) for ii
and iii:
2g(CT+Mo)
Force = rate of change of momentum. What's the rate of change of the vertical component of the sand's momentum as it hits the car?
I found something on the internet that said:
http://img221.imageshack.us/img221/3060/formulaforfkz8.png
I don't understand how they came to that conclusion. Any explanation would be great! =)
Which step in that chain do you not understand? The first step is key: Force equals the rate of change of momentum.
Okay, I think I see what they did. Thank you!
1. What is the conservation of momentum?
The conservation of momentum is a fundamental principle in physics that states that the total momentum of a closed system remains constant. This means that in a system where no external forces act, the total momentum before an event or interaction is equal to the total momentum after the event or interaction.
2. How does the conservation of momentum relate to the dissipation of kinetic energy?
The conservation of momentum and the dissipation of kinetic energy are closely related. When a collision or interaction occurs, the total momentum of the system remains constant, but the kinetic energy may decrease due to energy being transferred to other forms, such as heat or sound. This decrease in kinetic energy is known as dissipation.
3. What is an AP problem related to conservation of momentum and dissipation of kinetic energy?
An AP (Advanced Placement) problem related to conservation of momentum and dissipation of kinetic energy would likely involve a scenario where two or more objects collide or interact, and students would need to use the principles of conservation of momentum and energy to solve for unknown quantities, such as velocities or masses.
4. How can we apply the principles of conservation of momentum and energy in real-life situations?
The principles of conservation of momentum and energy are applicable in many real-life situations, such as car accidents, sports, and rocket launches. These principles help us understand and predict the behavior of objects in motion and can be used to design and improve technologies and systems.
5. What happens to the kinetic energy in an elastic collision?
In an elastic collision, the kinetic energy is conserved. This means that the total kinetic energy of the system before the collision is equal to the total kinetic energy after the collision. However, the kinetic energy may be distributed differently among the objects involved in the collision, but the total remains the same.
