Destruction of virtual particles and virtual particle pairs
In summary: Einstein's theory of special relativity states that the speed of light is the same for all observers, no matter the distance between them. This means that if you see a photon for the first time, you'll also see the photon's partner disappear.This would seem to clearly imply that only really tiny BHs experience Hawking Radiation. Doesn't seem to make any sense.
Maximise24
33
I'm trying to understand the process that destroys particles very shortly after they "appear". I have read that they are usually annihilated by a virtual antiparticle, much in the same way as can happen to real particles. However, is this always the case? And if so, is it an intrinsic property of these particles to appear in pairs and why exactly is this?
In other words: could a virtual (anti)particle be created on its "own", without a partner, for example because of the Heisenberg time-energy uncertainty relation, simply because it exists too briefly for it to have any real energy? Apparently, a virtual pair can be split up (Hawking radiation), but can they also be created that way?
Creation and absorption of any particle, virtual or not, must obey the conservation laws. A photon can be created alone, but an electron cannot because it is a negatively charged particle, and a positively charged particle (positron) must be created at the same time.
Energy must always be conserved too. Not just on the average, or over a long time, it must be exactly conserved whenever a particle is created or absorbed. If the new particle carries away energy, one of the other particles must lose the same amount to make up for it.
FYI, there is an analogy regarding Hawking Radiation that says it is caused by virtual particle pairs popping into existence just outside the event horizon of a black hole, wherein one of the pair falls in and the other heads off into space, and the one that falls in always reduces the mass of the BH, thus evaporating it via Hawking Radiation.
BUT ... Hawking himself has said that this is JUST a way of talking about it in English and that actual particle-pair production is NOT the true reason for Hawking Radiation.
It's easy to think the picture is that of an itty bitty particle being created "just outside" the horizon of a great big black hole. In fact, Hawking radiation is a global effect (so you can't say where it happens) and it only happens when the size of the particle is comparable to the size of the hole. Furthermore it's not just energy that disappears into the hole. If the emitted particle is electrically charged, the electric charge of the hole must change so as to compensate, just as if an antiparticle had fallen in.
Bill_K said:
... it only happens when the size of the particle is comparable to the size of the hole.
That's correct. As the hole gets smaller, the process goes faster. For astronomical size holes the rate is quite negligible!
So you're telling me there are particles the size of supermassive black holes? Is this some kind of joke?
No no, the effect is appreciable only for SMALL black holes. And yes, large (i.e. long de Broglie wavelength, very low energy) particles.
With a 4-vector of (0,0,0,0)? How is that a "photon"? How is that anything?
To clarify: The "size" of a photon is given by its wavelength in that description, and the size of massive particles by their de-Broglie wavelength.
The OP asked whether virtual particles have to be created in pairs. I answered that a photon can be created alone, by which I meant without creating a second particle. For example an electron can emit and reabsorb a virtual photon.
Okay, connected to other particles, a single photon can appear. But then you also get interactions like ##W^- \to e^- \bar{\nu_e}##, where an electron appears without a positron.
So, if I understand correctly, virtual particles can appear "on their own" (provided they do not break any conservation laws) in connection to other real particles, but not, say, in a vacuum, where there will always be a virtual antiparticle created with it?
Yes. The connection to real particles is necessary for energy/momentum conservation.
1. What are virtual particles and virtual particle pairs?
Virtual particles are particles that exist in the quantum vacuum, constantly popping in and out of existence. They are called "virtual" because they cannot be directly observed. Virtual particle pairs refer to a pair of particles, one virtual and one real, that are created simultaneously and then annihilate each other shortly after.
2. How are virtual particles and virtual particle pairs related to the destruction of particles?
The destruction of particles can occur through the process of virtual particle pairs. When a virtual particle and its antiparticle are created, they can collide and annihilate each other, releasing energy. This energy can then be used to create new particles or to destroy existing particles.
3. Can the destruction of virtual particles and virtual particle pairs be observed?
No, the destruction of virtual particles and particle pairs cannot be directly observed. This is because they exist in the quantum vacuum and have a very short lifespan, making them undetectable by our current technology.
4. How does the destruction of virtual particles and virtual particle pairs contribute to the laws of physics?
The destruction of virtual particles and particle pairs is a fundamental aspect of quantum mechanics and is essential to our understanding of the laws of physics. It helps explain the behavior of particles at the subatomic level and has implications for various phenomena, such as the Casimir effect and Hawking radiation.
5. Is the destruction of virtual particles and virtual particle pairs a reversible process?
Yes, the destruction of virtual particles and particle pairs is a reversible process. Just as particles can be created through the conversion of energy, they can also be destroyed, and the energy released can be used to create new particles. This is known as particle-antiparticle annihilation and is a fundamental principle in particle physics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
