Spacetime and gravity: question about how they work together
In summary, the conversation delves into the concept of gravity and space-time, with a particular focus on the Earth's orbit around the Sun and the Moon's orbit around the Earth. The "rubber sheet analogy" is discussed as a flawed representation of gravitation, and the concept of geodesics in curved spacetime is mentioned as a more accurate model. The conversation also touches on the idea of escape velocity and the moon's relative mass in its orbit.
byrdawg
Hello, I have had this lingering curiosity for a while. I read through https://www.physicsforums.com/showthread.php?t=5732" thread a second ago and would like to kind of take it a step further on a tangent.
I have only read about gravity effects and space-time as such they are "fabric-like", and seen many picture as http://images.google.com/imgres?img...rg.mozilla:en-US:official&sa=N&start=42&um=1". Which to me is very easy to understand, but I have never seen this model with a secondary satellite.
Imagine our sun in the center and the Earth being the satellite in orbit, then the "ripple" in space-time that the Earth generates would be "inclined" or "tilted" as to that of the Suns "ripple". Now I am curious how this model encompasses the Moon. When the moon rounds the Earth towards the Sun the inertia and "downhill" momentum from the "tilted ripple" is not going to be the same as when the moon rounds the Earth away from the Sun ("uphill"). This would cause the Moon to rather trail into the Sun or Crash into the Earth.
I know the above is not correct, and that space-time is not actually an entity. Can someone set me straight on how the spacetime model woul encompass the moon orbiting?
This picture might be easy to understand but has little to do with the mass attraction model of General Relativity. The curved grid doesn't represent spacetime, just space. There is no time dimension shown there. See links in this post for better pictures:
https://www.physicsforums.com/showthread.php?p=2046692
Don't take the stretchy fabric model very seriously. It is a weak and flawed analogy that is barely even suitable for pop-sci documentaries.
I think one thing people forget is that, In the Earth moon scenario, they are orbiting each other.
It's just that one party is significantly more massive than the other, so it doesn't get deflected as much.
Both the Earth and the moon orbit around their common center of gravity.
To see an example of this tie two masses together and throw them.
Similar masses like two tennis balls will swing around the center of the connecting string. If you make one a baseball, the center point of the spinning will be closer to the baseball. If you make the baseball a bowling ball, the center point will be inside the bowling ball, but not at the center of the bowling ball.
The rubber sheet analogy is usefull in that it demonstrates how a vector is changed by a mass. The closer you get to a mass the more you are affected by its 'funnel'. The moon is actually falling to earth, but because it is moving at a rate perpendicular to the surface of the Earth at a speed similar to how fast it is falling, it never hits the earth.
Take a cannon ball.
If you drop it it falls at a certain speed.
If you fire it out of a cannon perpendicular to the ground, it will fall at the same speed, but will hit the Earth a distance away because of the sideways acceleration.
If you fire the cannon ball fast enough, the rate it will travel far enough around the Earth that the curve of the Earth will drop as fast as the cannon ball does.
If you fire it faster than that the Earth will drop away faster than the cannon ball does, and you have achieved escape velocity.
(all the above assuming no drag from air friction and not obsticals in the way)
The moon is just a larger cannon ball..
That is so general, it could be an analogy for anything.
The rubber sheet analogy has nothing to do with the gravity model of GR, which is geodesics in curved spacetime. It contains neither spacetime nor geodesics.
rplatter said:
Take a cannon ball.
If you drop it it falls at a certain speed.....
That is all very nice but irrelevant to visualizing curved spacetime. You can use the rubber sheet analogy to visualize the Newtonian gravitational potential:
http://en.wikipedia.org/wiki/Gravity_well#Gravity_wells_and_general_relativity
1. How does gravity affect the fabric of spacetime?
According to Einstein's theory of general relativity, gravity is the curvature of spacetime caused by the presence of mass and energy. This means that massive objects, like planets and stars, cause a distortion in the fabric of spacetime, which we experience as the force of gravity.
2. Can spacetime exist without gravity?
No, spacetime and gravity are inseparably linked. Spacetime is the 4-dimensional framework in which all objects exist, and gravity is the force that governs the movement of these objects within spacetime. Without gravity, there would be no curvature in spacetime and therefore no way for objects to interact with each other.
3. How does the presence of mass affect the curvature of spacetime?
The more massive an object is, the stronger its gravitational pull and the greater the curvature of spacetime around it. This is why larger objects, like planets and stars, have a stronger gravitational pull than smaller objects, like asteroids.
4. How do black holes fit into the concept of spacetime and gravity?
Black holes are objects with such a strong gravitational pull that they curve the fabric of spacetime to the point where not even light can escape. This means that black holes are regions of spacetime where gravity is so intense that it has a significant effect on the movement of all objects around it.
5. Can gravity be explained by other theories besides general relativity?
While general relativity is the most widely accepted theory for explaining gravity, there are other theories, such as quantum mechanics, that attempt to explain gravity at a smaller scale. However, these theories are still being studied and do not fully explain the phenomenon of gravity as well as general relativity does.
  • Astronomy and Astrophysics
