How Do Coulombs and Amperes Measure Electricity?
In summary, a coulomb is a unit of electric charge and is defined as the charge transported by a steady current of one ampere in one second. It is equivalent to 6.24150965(16)×10^18 protons or electrons. The ampere, on the other hand, is a base unit of electric current and is defined as the amount of current that produces an attractive force of 2e-7 N per metre of length between two current-carrying wires separated by 1 metre. One proton has a charge of 1.602176565(35)×10^−19 C, which is the reciprocal of the magnitude of one coulomb.
polaris90
45
What is exactly one Coulomb? Wikipedia says "One coulomb is the magnitude (absolute value) of electrical charge in 6.24150965(16)×10^18 protons or electrons." It also says " It is defined as the charge transported by a steady current of one ampere in one second"
But also 1 proton has a charge of 1.602176565(35)×10^−19 C.
How is that?
Also what about the Ampere?
"the ampere is a measure of the amount of electric charge passing a point in an electric circuit per unit time with 6.241 × 10^18 electrons, or one coulomb per second constituting one ampere."
I'm not very clear on what a Coloumb is, can anybody explain?
thanks
think water: a coulumb is a measurement like a liter of water and
an ampere is a measurement like water coming out of a hose at N liters per second.
The reason for the one coulomb magnitude being what it is is because the convention was established long before we knew about electrons and protons as being the fundamental carriers of electric charge.
How is that?
Hint: take the reciprocal of either number. What do you get?
The coulomb is the fundamental unit of electric charge, so in that sense, it has a somewhat arbitrary definition, just like other base units do. (The kilogram is just defined as the mass of some platinum cylinder in a lab in France).
Actually, however, the coulomb is a derived unit in the SI system, not the base unit. The ampere is actually the base unit (along with the metre, kilogram, and the second), and a coulomb is defined as 1 ampere*1 second. In other words, the coulomb is the amount of electric charge that flows past in one second when you have an electric current of 1 ampere flowing.
So what is the definition of 1 ampere? Since it is a base unit, it should just have an arbitrary definition that is standard and universally adopted (just like for the kilogram). In this case, I think the ampere was chosen as the amount of electric current that is measured to produce an attractive force of 1 Newton between two current-carrying wires whose currents are in opposite directions.
(Anytime you have an electric current, you have a magnetic field. For two parallel, current carrying wires whose currents are moving in opposite directions, the opposing magnetic fields generated for each wire will produce an attractive force between the wires).
EDIT: I just checked, and the definition is that the two wires have to be separated by 1 metre, and the force produced is supposed to be 2e-7 N per metre of length (not 1 Newton as I stated before)
Coulombs and Amperes are both units of measurement used in the study of electricity and magnetism. They are used to measure the amount of electrical charge and current, respectively. 1 Coulomb (C) is defined as the amount of electrical charge transported by a steady current of 1 Ampere (A) in 1 second. In simpler terms, it is the amount of electrical charge that flows through a circuit in 1 second. This is equivalent to about 6.24 x 10^18 protons or electrons.
The fact that 1 proton has a charge of about 1.602 x 10^-19 C may seem confusing, but it is simply a small unit of measurement for charge. Just like how a kilometer is a larger unit of measurement for distance than a meter, a Coulomb is a larger unit of measurement for charge than a proton. It takes a large number of protons to make up 1 Coulomb of charge.
Similarly, the Ampere is a unit of measurement for electric current. It is defined as the amount of electric charge that passes through a point in an electric circuit per unit time. This means that 1 Ampere is equal to a flow of 6.24 x 10^18 electrons (or 1 Coulomb) per second.
In summary, Coulombs and Amperes are both units of measurement used to quantify the flow of electricity. 1 Coulomb is a measure of electrical charge, while 1 Ampere is a measure of electric current. They are related to each other through the definition that 1 Ampere is equal to 1 Coulomb per second.
What is the difference between coulombs and amperes?
Coulombs and amperes are both units used to measure electric current. Coulombs measure the quantity of electric charge, while amperes measure the rate at which electric charge flows.
How are coulombs and amperes related?
Coulombs and amperes are related by the equation Q = I x t, where Q is the electric charge in coulombs, I is the electric current in amperes, and t is the time in seconds. This equation shows that the amount of electric charge is directly proportional to the electric current.
Can coulombs and amperes be negative?
Yes, both coulombs and amperes can be negative. Negative coulombs represent a deficit of negative charge, while negative amperes indicate a flow of electric current in the opposite direction.
What are some real-world applications of coulombs and amperes?
Coulombs and amperes are used in many electrical devices and systems, such as batteries, circuits, and power lines. They are also important in understanding and controlling the behavior of electric charges in various materials and substances.
How were coulombs and amperes discovered?
Coulombs and amperes were first formulated and defined by French physicist Charles-Augustin de Coulomb and French mathematician André-Marie Ampère in the late 18th and early 19th centuries. They conducted experiments and developed mathematical theories to explain the behavior of electric charge and current.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
