Lifetime of electrons and protons outside the nuclues.
In summary, the theoretical bound on a proton's lifetime outside the nucleus is around 1032 years, but it could be shorter or longer.
MathematicalPhysicist
371
For neutron we all know, it has the 15 minutes of fame before it decays, what is the theoretical bound on proton's lifetime outside the nucleus, and to what it should it be dacayed to?
As far as I can tell electron is a point particle and cannot be dissolved into other parts, are there any bounds on its lifetime?
Electrons are absolutely stable. For an electron to decay means that either there is a lighter charged particle or that charge is not conserved. Neither one has any evidence in favor of it, and there's a lot of evidence against it.
Protons, as far as we know, are stable: measured lifetimes are around 1032 years, with some model dependence.
Whoops. That is an lower limit on the proton. There is no "measured lifetime" of the proton.
But you cannot say that hadron are stable. If there is a potential disintegration, there is a potential lifetime. I also agree that the lifetime is so long that they are considered "stable".
is the average time defore neutron decays (defined as the lifetime), which means that some of them decay much before, while others will take "forever" to decay".
Cheers
Yes, sloppy writing on my part. I should have said 'at lease 1032' years.
It makes me think, how can you construct a proton from quarks, if presumably quarks cannot get detached from eathother?
How can the age of a proton be determined?
The maximum age of all protons in the universe is about 13.7 billion years. The minimum radioactive lifetime for decay into a positron and a pi-zero meson can be determined by putting 50,000 tonnes of ultrapure water in a big tank 1000 meters underground and watch for Cerenkov radiation from pi-zero decay into two 67-Mev gammas using over 11,000 photomultipliers. See
http://en.wikipedia.org/wiki/Proton_decay#Experimental_evidence
...and see nothing.
This is still an empirical fact. So, we should be able to translate the lack of any observed violation of charge conservation into a lower bound on the electron lifetime - even if we expect that the electron's lifetime is infinite. In fact, the particle data group's 2008 book lists the lower bound on the mean electron lifetime as [itex]4.6 \times 10^{26}\ \mathrm{yr}[/itex].
Actually, the best measurement is from "electron disappearance", which is ~1.5x more stringent.
However, the masslessness of the photon sets extremely stringent indirect limits. (An exactly massless photon requires exactly conserved charge)
Are there any good theories about why a neutron lasts about as long as donuts left in the break room while a proton is for ever?
Any good theory should, first of all, describe neutron decay - an experimental fact. An electro-weak theory does it. The proton decay has not been observed so far, and any good theory should predict thus a very small or zero probability of proton decay. Are you not satisfied with the electro-weak model predictions?
Sorry - should have said simple theory.
It seems that such a large difference in behaviour between up-up-down and up-down-down quarks should have an explainable reason - rather than something buried deep in the maths of some gauge group?
I think it is a question of the ground and excited sates of a compound system, if you like.
Don't be so quick to knock the simplicity of groups. There are problems where a little group theory turns a multipage problem into a two-liner.
That said, there is a simple reason: a neutron is heavier than a proton, so it can decay into a proton, but not vice versa.
1. What is the lifetime of electrons and protons outside the nucleus?
The lifetime of electrons and protons outside the nucleus is believed to be infinite. This means that they do not decay or break down over time. However, in certain extreme conditions such as high energy collisions, electrons and protons can be converted into other particles.
2. Why do electrons and protons have an infinite lifetime?
Electrons and protons are considered to be fundamental particles, meaning they cannot be broken down into smaller components. They are also the building blocks of matter and play an important role in the stability of atoms. Therefore, they have an infinite lifetime because they are necessary for the existence of matter.
3. Can the lifetime of electrons and protons be affected by external factors?
No, the lifetime of electrons and protons is not affected by external factors such as temperature, pressure, or electric fields. These particles are extremely stable and do not interact with their surroundings in a way that would change their lifetime.
4. How do scientists study the lifetime of electrons and protons outside the nucleus?
Scientists study the lifetime of electrons and protons through experiments and observations using advanced technologies such as particle accelerators. By colliding particles at high energies, scientists can observe how electrons and protons interact and potentially decay into other particles.
5. Is there any evidence that suggests the lifetime of electrons and protons can change?
Currently, there is no evidence to suggest that the lifetime of electrons and protons can change. Numerous experiments and observations have consistently shown that these particles have an infinite lifetime. However, as our understanding of the universe evolves, new discoveries may shed light on the possibility of changes in particle lifetime.
