Cyclic Group Generators <z10, +> Mod 10 group of additive integers
In summary, the conversation discusses the concept of generating sets in a group, specifically Z10. It is noted that <z10, +> is the Mod 10 group of additive integers and that the set {3} is a generator for this group. The question arises about the set {2,5} and whether or not it is a generator for Z10. It is explained that while neither 2 nor 5 is a generator on their own, the set {2,5} does generate Z10. This is because combining the elements of this set using the group operation yields all of the elements of Z10.
DUDEEGG
So I take <z10, +> this to be the group
Z10 = {0,1,2,3,4,5,6,7,8,9} Mod 10 group of additive integers and I worked out the group generators, I won't do all of them but here's an example :
<3> gives {3,6,9,2,5,8,1,4,7,0}
on the other hand
<2> gives {2,4,6,8,0} and that's it! but my book says prove that 2 and 5 are generators...these two I thought we not generators...what am I doing wrong?
Are you sure that you are reading the question correctly? As you have noted, neither 2 nor 5 is a generator of ##Z_{10}##. However, the set ##\{2,5\}## does generate ##Z_{10}##.
Likes 1 person
Can you give me more info about {2,5} generating Z10? feel like I must be misunderstanding how to Generate Z10. Thanks for the help :)
We say that ##\{2,5\}## is a generating set for ##Z_{10}##. Here is the definition:
http://en.wikipedia.org/wiki/Generating_set_of_a_group
Briefly, if ##S## is any subset of a group ##G##, then we define ##\langle S\rangle## to be the smallest subgroup of ##G## which contains ##S##. To be more precise, ##\langle S\rangle## is the intersection of all subgroups of ##G## which contain ##S##. We call ##\langle S\rangle## the subgroup generated by ##S##, and we say that ##S## is a generating set for ##\langle S\rangle##.
In the special case where ##S## contains one element, say ##S = \{x\}##, we usually write ##\langle x \rangle## instead of ##\langle \{x\}\rangle##.
Applying these notions to your question, we want to prove that if ##S = \{2,5\}##, then the smallest subgroup of ##Z_{10}## which contains ##S## is ##Z_{10}## itself. In other words, we want to prove that ##\langle S\rangle = Z_{10}##.
To prove this, note that since ##S## contains ##2##, it must be true that ##\langle S\rangle## contains ##\langle 2\rangle##. (Why?) Likewise, since ##S## contains ##5##, it must hold that ##\langle S \rangle## contains ##\langle 5\rangle##. What can you conclude?
Likes 1 person
A group, G, is generated by a set, S, of members of G if and only if by combining the members of S using the group operation, we get every member of G. The set {3} gives, as you say all members of Z10 because 3= 3, 3+ 3= 6, 3+ 3+ 3= 9, 3+ 3+ 3+ 3= 12= 2 (mod 10), 3+ 3+ 3+ 3+ 3= 15= 5 (mod 10), 3+ 3+ 3+ 3+ 3+ 3= 18= 8 (mod 10), 3+ 3+ 3+ 3+ 3+ 3+ 3= 21= 1 (mod 10), 3+ 3+ 3+ 3+ 3+ 3+ 3+ 3= 24= 4 (mod 10), 3+ 3+ 3+ 3+ 3+ 3+ 3+ 3+ 3= 27= 7 (mod 10), and 3+ 3+ 3+ 3+ 3+ 3+ 3+ 3+ 3+ 3= 30= 0 (mod 10).
{2} does not generate Z10 because 2= 2, 2+ 2= 4, 2+ 2+ 2= 6, 2+ 2+ 2+ 2= 8, 2+ 2+ 2+2+ 2= 10= 0 (mod 10), 2+ 2+ 2+ 2+ 2+ 2= 12= 2 (mod 10) and now it starts over. We do NOT get 1, 3, 5, 7, or 9.
{5} does not generate Z10 because 5= 5, 5+ 5= 10= 0 (mod10), 5+ 5+5 = 15= 5 (mod 10) and it just repeats. We do not get 1, 2, 3 4, 6, 7, 8, or 9.
But {2, 5} contains all of those and 2+ 5= 7, 2+ 2+ 5= 9, 2+ 2+ 2+ 5= 11= 1 (mod 10), 2+ 2+ 2+ 2+ 5= 13= 3 (mod 10) so that we have all of 1, 2, 3, 4, 5, 6, 7, 8, 9, and 0.
Likes 1 person
HallsofIvy EGGGZELLENT Thx :) u2
jbunniii
1. What is a cyclic group generator?
A cyclic group generator is an element within a cyclic group that can generate all other elements in the group through repeated addition.
2. How does Mod 10 group of additive integers work?
This is a cyclic group that consists of all integers from 0 to 9, with the operation of addition modulo 10. This means that after adding two integers, the result is divided by 10 and the remainder is taken as the final answer.
3. What is the order of the cyclic group Mod 10?
The order of a cyclic group is the number of elements within the group. In this case, the order is 10 since there are 10 integers from 0 to 9 in the group.
4. How do you find the cyclic group generator for Mod 10?
The cyclic group generator for this group can be found by selecting any integer from 1 to 9 that is relatively prime to 10. This means that the only common factor between the integer and 10 is 1. For example, 3 is a cyclic group generator for Mod 10 since 3 and 10 do not share any common factors.
5. What is the significance of cyclic group generators in mathematics and cryptography?
Cyclic group generators play an important role in both mathematics and cryptography. In mathematics, they are used to study abstract algebra and group theory. In cryptography, they are used to generate large prime numbers, which are essential for secure encryption algorithms.
  • Linear and Abstract Algebra
