Proving solutions of an ODE of the form y''+by'+cy=0
  • Thread starter nemma14778
  • Tags
    Form Ode
In summary, the set of solutions for an ODE of the form y''+by'+cy=0 forms a vector space, as shown by verifying axioms 1,4,5, and 9 of the definition of a vector space. The proof involves showing that for any two solutions u and v, their linear combination c1u + c2v is also a solution. This can be achieved by applying variation of parameters and showing that y is a solution if and only if it is a linear combination of a basis of the solution space.
nemma14778
The set of solutions of an ODE of the form y''+by'+cy=0 forms a vector space. To convince yourself of that, prove that axioms 1,4,5 and 9 of the definition of a vector space hold for this set of solutions. (You may want to check the others as well, but no need to present their proof.)
I started to prove the first axiom as follows:
Axiom #1: If u and v are objects in V, then u + v is in V.
If we let c1u and c2v be two solutions to our second order differential equation, then c1u + c2v must be a solution for the second order differential equation for any constants c1 and c2.
F(y) = 0 = (c1u+c2v)’’ + b(c1u+c2v)’ + c(c1u+c2v)
0 = c1u’’+c2v’’ + bc1u’+ bc2v’ + cc1u+cc2v
0 = c1u’’ + bc1u’ + cc1u + c2v’’ + bc2v’ + cc2v
0 = c1(u’’ + bu’ + cu) + c2(v’’ + bv’ + cv)
0 = c1F(u) + c2F(v)
0 = c1(0) + c2(0) = 0 + 0 = 0
0 = c1F(u) + c2F(v)
I don't see any question here. Also I don't know what axioms 1,4,5,9 are in your text. However, in your argument above you want to start with u and v, not c1u and c2v. I think you will find that your argument will show that u and v are solutions then so is c1u + c2v, which may solve more than one of your required properties.
I do not understand any of that stuff. Any way if one wanted to verify existence uniqueness without apeal to general theorems a standard method is to apply variation of parameters to deduce that y is a solution if and only if it is a linear combination of a basis of the solution space. This also makes it easy to show te solution space is a vector space.
1. What is an ODE?
An ODE, or ordinary differential equation, is a mathematical equation that involves a function and its derivatives. It is used to model various phenomena in science and engineering.
2. How do you solve an ODE of the form y''+by'+cy=0?
There are several methods for solving ODEs, including separation of variables, variation of parameters, and using the characteristic equation. The specific method used will depend on the specific ODE and its initial conditions.
3. What does the solution of an ODE represent?
The solution of an ODE represents the possible values of the function that satisfy the equation. In other words, it represents the behavior of the system described by the ODE.
4. Can an ODE have multiple solutions?
Yes, an ODE can have multiple solutions. This is because the solution of an ODE is not unique and can depend on the initial conditions and the method used to solve it.
5. How is the solution of an ODE verified?
The solution of an ODE can be verified by plugging it back into the original equation and checking if it satisfies the equation. It can also be verified by graphing the solution and comparing it to the behavior of the system being modeled.
10K
  • Differential Equations
