New Reply
Can light affected be affected by noise as other signals?I am not
Share Thread
Oct18-12, 02:06 PM   #1
I am not able to figure it out..if I am amplifying the light using some optical
amplifier,will there be any effects of noise in it?
Regards
zakee
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Oct19-12, 08:22 AM   #2
mfb
Mentor
Which type of noise?
An optical amplifier can have noise from unwanted photons or other sources.
Oct19-12, 11:05 AM   #3
Recognitions:
Gold Membership Gold Member
Absolutely. The types of noise depend on the conditions you have. If you have a light source where you are also getting a lot of "light pollution", IE unwanted light from other sources, that will be noise. The sensor itself will have noise during readout as well. Even without these you will have noise thanks to the random nature of when photons are emitted and received.
Oct19-12, 03:49 PM   #4
Quote by Drakkith View Post
thanks for the reply..do u have an idea how to start learning photonics..i m interested in this field but there are far too many concepts too master..i have done my undergrad in electronics and I am starting as a master's student in photonics.it wud be great if you can give me some idea where from where to start.I know basic electromagnetics but there is still too much too learn..hope to hear from you soon.
_____________________________________________________________________
" You cannot teach a man anything; you can only find it within yourself."
Oct19-12, 10:11 PM   #5
Recognitions:
Quote by zakee.fancy View Post
Got me, I haven't even started my undergrad work in optical engineering like I want to. Hit up the academic help forums is my suggestion.
Also, you can put in a permanent quote from your user control panel so you don't have to keep typing it in. It also keeps it from being quoted along with the rest of your post when someone quotes you.
New Reply
Similar discussions for: Can light affected be affected by noise as other signals?I am not
Thread Forum Replies
velocity of red light vs. blue light in water - qualitative reasoning? Classical Physics 3
Does UVA (long-wave ultraviolet) light behave more like visible light than higher-ene General Physics 0
Light has mass, and it travels at the Speed of light, so a massless object..... Special & General Relativity 2
Questions abouut:Special Relativity, Time Dilation, Light Clock, Velocity of light. Special & General Relativity 31
Why does light intensity decrease when light passes through a glass block? General Physics 7
