Levi-Civita connection and pseudoRiemannian metric
In summary: If you want to use the distance function between points in a metric space, you need to use a connection preserving the metric tensor.
TrickyDicky
3,507
27
One of the properties of the unique Levi-Civita connection is that it preserves the metric tensor at each point's tangent space, allowing the definition of invariant intervals between points in the manifold. I'd be interested in clarifying: when the metric preserved by the L-C connection is a PseudoRiemannian metric, the PseudoRiemannian manifold is a:
-pseudometric space
-metric space
-none of the above
Every manifold (with or without pseudo-Riemannian metric or connections) is a metric space. So on every manifold you can define a metric such that the topology coincide with the metric topology.
This has nothing to do with the pseudo-Riemannian metric.
But maybe you have something else in mind?
Ok, but the fact is that thru the unique connection in GR spacetimes a particular structure of distance functions between events is developed specially for null curves and geodesics, based on the light cone structure defined by the pseudoriemmanian metric in the space tangent at each event, very different from the distance functions in metric spaces and from which very important physical consequences are derived.
Invariant intervals have nothing to do with the Levi-Civita connection. This is a trivial property of the metric tensor in and of itself. The Levi-civita connection preserves inner products along arbitrarily extended curves when the vectors in the inner product are parallel transported, which is much stronger. Note the inner product is not preserved along arbitrary curves if the transport is done differently e.g. Lie transport will not preserve the inner product, even if we substitute in the Levi-Civita connection, unless the curve is an integral curve of a Killing field.
-pseudometric space
-metric space
-none of the above
All topological manifolds are metric spaces as has already been stated. This has nothing to do with your previous statements.
I know every manifold is metrizable, you are missing my point.
I'm trying to get an understabding on how Exactly the distance functions in spacetime are compatible with the metric space structure.
How for instance a lightlike interval, or an arbitrary null Curve in spacetime M fits in the requurements of the distance functions of metric spaces?
To be more specific, how is the distance in a lightlike geodesic that can be zero between 2 distinct points can be defined if the spacetime is a metric space in which the distance between 2 distinct points cannot be zero?
You need a connection preserving the metric tensor if you want to use properties of the metric(trivial or not) between points in a general spacetime, don't you?
I mean, the lightcone structure is only defined locally at a point's tangent space or is also defined globally in a curved lorentzian manifold ?(I leave out Minkowski spacetime since it is itself a vector space).
Do you mean to define a distance function
[tex]d(x,y) = \textrm{inf}\{\textrm{Length}(\gamma)~\vert~\gamma:[a,b]\rightarrow M~\text{smooth and}~\gamma(a) = x,~\gamma(b)=y\}[/tex]
for ##x,y\in M##? And whether ##M## becomes a (pseudo-)metric space under this ##d##?
The definition and properties of ##d## still don't require a connection though.
I'm asking if the pseudoRiemannian metric defines some distance function in a pseudoRiemannian manifold. I'm only mentioning the connection because it preserves the metric tensor.
Can you tell us the distance function you're considering?
I think you are confusing "metric space" and "metric tensor". They are separate concepts which just happen to share the same name "metric". As I understand it, the metric space structure of a manifold is the topology inherited via coordinate charts from Euclidean [itex]\mathbb{R}^4[/itex]. It's needed to define "continuity", "differentiability", "smoothness", etc, but isn't used for distance measurements via the metric tensor.
You mean the right thing, but I want to be pedantic here. A manifold has (a priori) only a topological structure (and a smooth structure which is not interesting here). Not every topological space induces a metric space, but in a manifold that is the case. So we can show that there exists a distance function such that the topology generated by that distance function (meaning, the topology generated by the open balls ##\{x\in M~\vert~d(x,a)<r\}##) is the original manifold topology.
I can already see this thread is going to be confusing because the word metric is used in two senses. So, I propose the following terminology:
1) A metric always means a metric tensor.
2) A distance function on a set ##X## is a function ##d:X\times X\rightarrow \mathbb{R}## such that ##d(x,y)=0## if and only if ##x=y##, ##d(x,y) = d(y,x)## and ##d(x,z)\leq d(x,y) + d(y,x)##. (Analogous definitions for pseudo-distance function)
3) A distance space is a pair ##(X,d)## where ##X## is a set and ##d## is a distance function on ##X##. (Analogous definition for pseudo-distance space).
So I propose never to use the word "metric space" in this thread, or never to use the word "metric" when it actually means a distance function.
So the OP asks us whether a pseudo-Riemannian manifold is
a) A distance space
b) A pseudo-distance space
c) Neither
The question that I want to ask for the OP is which distance function ##d## he is considering concretely.
I said it [itex]ds^2=g_{\mu\nu} dx_\mu dx_\nu[/itex] in a curved pseudoRiemannian manifold with [itex]g_{\mu\nu}[/itex] a pseudoRiemannian metric tensor, allowing distances along curves to be determined through integration, in the specific case of a null curve.
I'm just trying to clear up the differences wrt the Riemannian case of the pseudoriemannian generalization and how it would affect if at all the metric space structure of the Riemannian case, because when M is any connected Riemannian manifold, then we can turn M into a metric space by defining the distance of two points as the infimum of the lengths of the paths (continuously differentiable curves) connecting them, but I wonder how can we define this for null curves in a curved pseudoRiemannian manifold.
OK, so you don't have a specific distance function in mind. Your question is whether we can define a suitable (pseudo)-distance function from the metric tensor in the way that we can do this in Riemannian manifolds. Right?
Exactly.
No. The metric is defined at all points of space-time and is completely independent of a connection. A connection (in this setting defined on sections of tangent bundles) is a way to transport vectors from one point to another along curves and is independent of a metric. They have two completely unrelated roles.
It's defined globally based on how it varies from point to point as the metric varies from point to point. The metric is a field it isn't just defined at a single point. It defines a different light cone at each point and if the space-time is time orientable then the light cone variation will be smooth. The local light cone structure is trivial so physics wouldn't be interesting in curved space-times if all we had was local light cone structure.
Thanks for your clarifications WN.
I'm only concerned here with the unique L-C connection, that is related to the metric only in the sense that it is the only one compatible with it for torsionless manifolds. But you are right, in this thread the connection has basically been a distracting element. I shouldn't have even mentioned it. Sorry about that.
Right. And my question was how do the distances obtained globally with the pseudoriemannian metric, specifically in the case of null curves get along with the manifold being a distance(metric) space?
Given a piecewise smooth curve ##\alpha:[a,b]\rightarrow M##. We can define the length of the curve as
[tex]\int_a^b \sqrt{|g_{\alpha(t)}(\dot{\alpha}(t),\dot{\alpha}(t)|}dt[/tex]
See for example O'Neill "Semi-Riemannian Geometry". Thing is that this will violate the triangle inequality.
And in the case of the null curve the identity of indescirnibles is also violated.
Right. But that is something I feel is a minor problem. The triangle inequality is much worse.
This is a good thing.
It might, but it seems to clash with considering the pseudoRiemannian manifold a metric space. Wich I don't know if it is a good, bad or indifferent thing to be honest.
This is stated in Wikipedia:"If one drops the positive definiteness requirement of inner product spaces, then one obtains a pseudo-Riemannian metric tensor, which integrates to a pseudo-semimetric distance function".
A pseudo-semimetric space is one where distances can be defined that violate the triangle inequality d(x,z) ≤ d(x,y) + d(y,z) and the identity of indescirnibles d(x,y) = 0 iff x = y, the main problem here is that these pseudo-semimetric spaces are not even Hausdorff which I think it's not good. So it would be interesting to know how exactly a pseudoRiemannian manifold gets away not really being a pseudo-semimetric space but a metric space in the end.
The only way I see is by appealing to the fact GR concentrates on the local topology and geometry. But this approach only preserves all the physics that is related with curvature, since curvature is a local invariant, and leaves out a lot of physics usually considered predicted by GR.
We have been around and around this circle before. For example, consider this important comment from a thread just over a year ago:
micromass said:
So even without a smooth structure or a metric tensor, we already have that our manifold is metrizable. Again: the metric of the metric space might not be physical or might not have anything to do with a metric tensor!
"So even without a smooth structure or a metric tensor, we already have that our manifold is metrizable. Again: the metric of the metric space might not be physical or might not have anything to do with a metric tensor!"
We all agree the topological manifold is metrizable. The issue is how we deal with the distance functions we define from a pseudoRiemannian metric tensor.
You seem to be suggesting that pseudoRiemannian manifolds can be both metric and pseudo-semimetric space at the same time, I don't know if that is posible at all. But I think the fact the triangle inequality is violated obstructs the possibility of it being a metric space.
So the PseudoRiemannian manifold is a metric space sure.
Now you have defined some distance function ##d## which makes the manifold into a pseudo-semi-metric space.
They key part is however that this distance function ##d## has nothing to do with the original topology on the manifold. It's not even sure that it is physically very important.
So the situation is much alike this. Consider the set ##X=\{0,1\}##. Define the metric ##d(x,y) = 1## if ##x\neq y## and ##d(x,y) = 0## elsewhere.
However, we can also define the pseudometric ##e(x,y) = 0## for all ##x,y##.
Are you surprised that the set ##X## can be made both in a metric and a pseudometric space? Of course not, since there is no connection between the ##d## and the ##e##. Nothing say that they should be related.
The same thing happens with our manifold. Our pseudo-semi metric is just some function on the manifold. It is not clear to me why you expect this to be somehow related to the original topology of the manifold?
Ok, as I was saying I was not even aware the possibility existed that being metric or pseudometric spaces weren't mutually exclusive. It looks a bit arbitrary but that's just my subjective impression.
Well, not exactly, the Wikipedia reference talks about pseudometric spaces not being Hausdorff, that's all. Of course being Hausdorf for manifolds is an arbitrary requirement made by definition to avoid pathological cases, and I guess in retrospect that is done because all metric spaces are Hausdorff.
Also from Wikipedia:"The difference between pseudometrics and metrics is entirely topological."
I understand that when in doubt the original topology of the manifold, that is the usual topology, prevails.
What I don't understand is how so much physics is derived from the topology of the pseudo-semimetrics of pseudoRiemannian manifolds when it is mathematically unfounded if the manifold is a proper metric space.
I'm not convinced at all that the topology of the pseudo-semimetric space is very applicable in physics at all!
And what do you mean that it's unfounded that the manifold is a proper metric space?
They have absolutely no relation to what we deal with in GR. The topologies we deal with are the manifold topology inherited from the smooth structure or Hawking's path topology. Other standard topologies exist but none of them have anything to do with the metric induced topology you're talking about.
No, I meant the putative physics derived from the pseudometric geometric topology would be unfounded if the pseudoRiemannian manifold was a truly metric space.
But WN says all the GR physics is based on the standard manifold topology. I would have to look for examples where I think this would not be the case so that I can correct my judgment.
  • #31
But actually nobody has attempted so far giving an explanation about how null geodesics with their distance ds=0 are compatible with the standard topology with d(x,y) = 0 iff x = y. If they need not be compatible it makes seem unnecessary to impose a metric space structure on the manifold, it's like anything goes.
  • #32
Are not null hypersurfaces for instance objects derived from the pseudoriemannian metric pseudometric properties and their induced topology?
  • #33
This section from Kevin Brown's Reflections on relativity book(hopefully a valid source, these pages have been profusely commented in PF ) on mathpages http://mathpages.com/rr/s9-01/9-01.htm argues as evident that the physics of Minkowski spacetime (the simplest pseudoRiemannian manifold of Lorentzian signature, having vanishing curvature) comes from its particular pseudosemimetric induced topology, which he says it's not even a topological space topology.
The article also states :"It is, of course, possible to assign the Euclidean topology to Minkowski spacetime, but only by ignoring the non-transitive null structure implied by the Lorentz-invariant distance function. "
If one ignores this structure it seems to me that when we go to the case with curvature much of the physics related with this structure like event horizons and their associated black holes or conformal null infinity are left baseless.
  • #34
Also extracted from mathpages in relation with a posible way of ignoring the topology induced by the Lorentzian pseudosemimetric that implies considering the spatial and temporal parts of spacetime as having each an absolute meaning by themselves:"In the case of a spacetime theory, we need to consider whether the temporal and spatial components of intervals have absolute significance, or whether it is only the absolute intervals themselves that are significant."
I see two problems. First of all this seems contrary to the spirit of the relativity theory, and besides in the general case it is only possible for static spacetimes, and we know our universe is not static even if it can be approximated partially by static models. What do you guys think?
  • #35
They're not compatible. In fact, while it is possible to impose a metric space structure on the manifold, the distance function will be very much unphysical. It will be completely useless in physics. So yes, all what matters is the topology and not the metric space structure.
  • Differential Geometry
