Why isn't electricity flowing through this wire?
In summary: The current in an element like a resistor obeys the following:[Voltage (one end) - Voltage (other end) ] / resistance = currentSo as you can see if the voltages are the same you get zero current. Look up "Current Divider" on Wikipedia.
remedemic
In the top circuit, electricity doesn't flow through section 2, but it does in section 1.
In the bottom circuit however, electricity flows through both sections 3 and 4. Why does
simply adding a resistor stop the flow of electricity in 2?
Much appreciated!
current will flow through the easiest path ( without resistance) or with less resistance and as the wire doesn't have any resistance, all the current will flow through it.
In the top circuit, if I add a resistor to section 1 that has less resistance than section 2, electricity will still flow through both, won't it?
yeh it will, but the one with more resistance will have less current flowing through it.
SO, why isn't there just less current (instead of zero current) in section 2 compared to section 1 since it has more resistance?
Thanks for the help by the way, I greatly appreciate it.
it's just how it is, because current has to flow through both of the sections and that most current will flow through the section with less resistance.
im understanding it now. Thank you very much sir.
glad you understood it, your welcome.
You are right, there is SOME current in section 2. The ratio of the currents is the same as the ratio of the resistances; 10cm of wire might have a resistance of 0.006Ω so if R3 is 100Ω and 0.1A is flowing through the circuit, 0.1A x 0.006 / 100 = 6μA will be flowing through R3.
yup, but the main point is that the resistor in section 2 is effectively being shortcircuited
Dave
The problem here is one of starting assumptions. If the assumption of the problem is that there is no resistance in the wires (a common assumption), then all of the current has to go through the short. But in real life, there is a finite resistance even in a wire, so a certain amount of current will flow through each branch.
If you measure the voltage at 2 points on a wire without resistance you get the same result. By short circuiting the resistor in section 2 you are making both ends the same voltage.
Look up "Current Divider" on Wikipedia. It will explain what is going on quantitatively. If you have a mind for math, this may help you understand better.
1. Why isn't there any electricity flowing through this wire?
There could be several reasons why electricity is not flowing through a wire. One common reason is that the wire is not properly connected or is broken. Another possible reason is that the power source is not working or the circuit is not complete.
2. What can cause a wire to stop conducting electricity?
A wire can stop conducting electricity if there is a break in the wire, which can be caused by physical damage or wear and tear. It can also stop conducting if the material of the wire has a high resistance, preventing the flow of electricity.
3. How can I check if a wire is carrying electricity?
The easiest way to check if a wire is carrying electricity is to use a multimeter, which measures the flow of electricity. You can also use a test light, which will light up if there is electricity flowing through the wire.
4. Can a wire carry electricity even if it's not connected to a power source?
No, a wire cannot carry electricity without a power source. The power source provides the energy needed for the electricity to flow through the wire. Without a power source, the wire will not have any electricity to carry.
5. How can I fix a wire that isn't conducting electricity?
If the wire is broken or damaged, it will need to be replaced. However, if the wire is not conducting electricity due to a loose connection, you can fix it by securely connecting the wire. If the issue is with the power source, it may need to be repaired or replaced by a professional.
  • Electrical Engineering
