Deep brain stimulation good for Parkinson's: study
  • Medical
  • Thread starter baywax
  • Tags
    Brain Study
In summary, deep brain stimulation involves electrodes stimulating the middle of the brain with pulses generated by a battery pack surgically placed like a "pace maker" in the patient's chest. The results for Parkinson's sufferers has been tremendous where 71 percent of patients are better off (to the point of no tremors for an average of 6.4 hours straight during the day) compared to the 31 percent effectiveness of drugs targeting the disease. Deep brain stimulation improves movement skills and quality of life in patients with advanced Parkinson's disease better than other medical treatments, but it also carries with it a higher risk for complications, a new study says.
baywax
Deep brain stimulation involves electrodes stimulating the middle of the brain with pulses generated by a battery pack surgically placed like a "pace maker" in the patient's chest.
Deep brain stimulation is a surgical procedure that involves the implantation of electrodes that send electrical currents to specific regions in the brain. This electrical stimulation can reduce involuntary movements and tremors, which are common Parkinson's symptoms.
http://www.ctv.ca/servlet/ArticleNews/story/CTVNews/20090106/parkinsons_treatment_090106/20090106?hub=Health
The complications include how the electrical activity generated for the implanted electrodes can disrupt the heart in patients. This is proving beneficial, however, for people up to ages like 70 who may even be in an advanced stage of the condition!
Edit: This is an American achievement by the way!
Study performed by Frances M. Weaver, Ph.D., of Hines VA Hospital, Hines, Ill., and colleagues.
http://www.sciencedaily.com/releases/2009/01/090106161510.htm
Biology news on Phys.org
About 50,000 Americans are diagnosed with PD each year, but getting an accurate count of the number of cases may be impossible because many people in the early stages of the disease assume their symptoms are the result of normal aging and do not seek help from a physician. Also, diagnosis is sometimes difficult and uncertain because other conditions may produce symptoms of PD and there is no definitive test for the disease. People with PD may sometimes be told by their doctors that they have other disorders, and people with PD-like diseases may be incorrectly diagnosed as having PD.
http://www.ninds.nih.gov/disorders/parkinsons_disease/detail_parkinsons_disease.htm
I don't know how many of these people are going to be motivated enough to have holes drilled in their skulls, risking infection, to stop what they probably see as simply the aging process. Many individuals would probably forego this operation thinking it was a government ploy to wiretap their brains, or because it really is a major operation.
The above link has a lot of information on this neurological condition.
I once saw a spastic individual on a television show who had a deep brain stimulation device. He looked absolutely normal with the device activated, but once he turned it off he lost all control and couldn't even communicate. It's an amazing technique, but not something trivial.
Here's the Michael J. Fox (CDN!) Foundation for Parkinson's Research.
http://www.michaeljfox.org/newsEvents_parkinsonsInTheNews_article.cfm?ID=260
There are reports of the stimulation interfering with decision making.
DBS implants affect the region of the brain called the subthalamic nucleus (STN), which also modulates decision-making.
"This particular area of the brain is needed for what's called a 'hold-your-horses' signal," Frank said. "When you're making a difficult choice, with a conflict between two or more options, an adaptive response for your system to do is to say 'Hold on for a second. I need to take a little more time to figure out which is the best option.'"
The STN, he said, detects conflict between two or more choices and reacts by sending a neural signal to temporarily prevent the selection of any response. It's this response that DBS seems to interrupt. DBS acts much like a lesion on the subthalamic nucleus. Frank's hypothesis predicted that DBS would negate the "hold-your-horses" response to high-conflict choices. Surprisingly, it actually sped up the decision-making process, a signature, he said, indicated of impulsive decision making.
The tendency toward impulsive behavior in Parkinson's patients is well-documented but only dimly understood. How is the STN involved in decision-making and why should things go awry when you stimulate it"
(same link as above)
What is deep brain stimulation?
Deep brain stimulation (DBS) is a surgical procedure that involves implanting electrodes into specific areas of the brain. These electrodes deliver electrical impulses to targeted areas, which can help alleviate symptoms of certain neurological disorders, including Parkinson's disease.
How does deep brain stimulation work for Parkinson's disease?
DBS works by targeting specific areas of the brain that are responsible for controlling movement. Parkinson's disease is caused by a lack of dopamine in the brain, which affects movement and can cause tremors, stiffness, and difficulty with balance. DBS can help improve these symptoms by delivering electrical impulses to these areas of the brain, essentially overriding the abnormal signals that cause the symptoms.
What are the potential benefits of deep brain stimulation for Parkinson's disease?
The potential benefits of DBS for Parkinson's disease include improved motor function, reduced tremors and stiffness, and better overall quality of life. DBS can also help reduce the need for medication and may delay the progression of the disease.
What are the risks and side effects of deep brain stimulation?
As with any surgical procedure, there are risks associated with DBS, including infection, bleeding, and stroke. In addition, some potential side effects of DBS for Parkinson's disease include speech and language problems, balance issues, and mood changes. However, these risks and side effects are generally rare and can often be managed with proper medical care.
Is deep brain stimulation a cure for Parkinson's disease?
No, DBS is not a cure for Parkinson's disease. It can help alleviate symptoms and improve quality of life, but it does not treat the underlying cause of the disease. Parkinson's disease is a progressive neurological disorder, so symptoms will continue to worsen over time, even with DBS. However, DBS can significantly improve symptoms and may delay the progression of the disease.
  • Biology and Medical
