Barometric height distribution formula problem
In summary, we are considering the earth's atmosphere as a mixture of 79% N2 and 21% O2 gas at an average temperature of 10o Celsius and acceleration due to gravity of 9.81 ms-2. Using the barometric height distribution formula, we can integrate over the atmosphere's mass density to determine its effective thickness in terms of the density at sea-level. This involves finding the average height by dividing the integral of density as a function of height by the density at sea level.
8614smith
54
Consider the earth’s atmosphere assuming it is a mixture containing 79% N2 and 21% O2 gas. Furthermore, assume that the atmosphere is at an average constant temperature of 10o Celsius and that the acceleration due to gravity is g = 9.81 ms-2.
Using the barometric height distribution formula integrate over the atmosphere’s mass density
(from sea-level [height ‘0’] to very great heights [‘infinity’]) and thereby determine the earth’s atmosphere’s effective thickness [in terms of the density at sea-level].
pV=NkBT
how can a thickness be defined in terms of a density? and does mass density just mean density? I've integrated the barometric height formula between 0 and infinity and got to:
lnp(h) = -mg/kbT . h
h = -ln(p) kbT/mg = -97975m
which can't be right having researched it its around 9km
show your working
the integral will probably be over density as a function of height
[tex] I = \int_0^{infty} dh. \rho(h) [/tex]
each part of the integral effectively adding up density times height, to get the "average" thickness based on sea level density, just divide by sea level density
[tex] h_{average} = \frac{\int_0^{infty} dh. \rho(h)}{\rho_{sea level}} [/tex]
1. What is the barometric height distribution formula problem?
The barometric height distribution formula problem is a mathematical problem used in atmospheric science to determine the relationship between atmospheric pressure and altitude. It is used to calculate the change in pressure as altitude increases, and is important for understanding weather patterns and predicting changes in atmospheric conditions.
2. How is the barometric height distribution formula derived?
The barometric height distribution formula is derived from the ideal gas law, which states that the pressure of a gas is directly proportional to its temperature and the number of gas molecules in a given volume. This formula is then applied to the Earth's atmosphere, taking into account the change in temperature and number of gas molecules with increasing altitude.
3. What variables are involved in the barometric height distribution formula?
The barometric height distribution formula involves several variables, including atmospheric pressure, altitude, temperature, and the gas constant. Other variables, such as the gravitational constant and the average molecular weight of the atmosphere, may also be included depending on the specific equation being used.
4. How accurate is the barometric height distribution formula?
The accuracy of the barometric height distribution formula depends on several factors, including the specific formula being used, the atmospheric conditions, and the altitude range being calculated. In general, the formula is most accurate in the lower to mid-altitudes and may become less accurate at very high altitudes or in extreme weather conditions.
5. What are some practical applications of the barometric height distribution formula?
The barometric height distribution formula has many practical applications, including weather forecasting, aviation, and space exploration. It is also used in industries such as agriculture and construction, where changes in atmospheric pressure can affect plant growth and building stability. Additionally, the formula is used in the development of weather balloons and other instruments used to measure atmospheric conditions.
  • Mechanics
