Steam at specific volume/pressure
In summary: Temperature (T) 286.72 CSaturated Vapor (g) 37.067 kg/m3is it correct that i need to get 37.067 liters of water to 286.72 celsius to get 1 cubic meter of steam at 70atm?Yes, that's correct.
tikipu
hi all!
i'm trying to figure out how much water i need to heat and to what temperature, to end up with 1 cubic meter of steam at 70atm.
i used the calculator found here:
http://www.efunda.com/materials/water/steamtable_sat.cfm
i punched in 70atm, and got the following data:
eventually, I'm trying to find how much energy is needed for this process, but I'm guessing that's more of an engineering question.
i just want to get the quantities right first.
thanks in advance to anyone taking the time to help me with this!
tikipu said:
hi all!
It seems to me that you can get a cubic meter of steam at any temperature above the triple point. The water content of that cubic meter will then be a function of the vapor pressure, and that vapor pressure can have almost any value. Any amount of water injected into a closed container at a temperature above the triple point will give you one cubic meter of steam. The vapor expands to occupy the entire available volume.
How did you come up with those particular values of temperature and vapor pressure? Are they postulates?
Welcome to PF, tikipu! :smile:
If you approximate this with an ideal gas (assuming *only* steam), you have:
nRT = PV
So given P and V, you can choose any temperature and calculate n, the amount of matter.
Hi tikipu, welcome to the board.
tikipu said:
hi all!
The web page you pointed to provides properties of saturated gas (ie: steam) and saturated liquid water (water at the boiling point) for any pressure or temperature input. You put in the correct numbers and you have the correct answer. Saturated water vapor at 70 atm has a temperature of 286.72 C and a density of 37.067 kg/m3.
Here's where there might be an error. The volume of water you need depends on its density and the density depends on the pressure and temperature. So I'm not sure where you got the 37.067 liters of water from. That assumes 1 liter of water always weighs 1 kg. If you want to know the volume, you need to define the density which can only be done by defining pressure and temperature.
Note that the amount of energy needed to get steam at that pressure and temperature is a function of the initial conditions of the water and the way you are heating it. If for example, you heat it inside a pressurized container, that will give you a different answer than if it's done inside a cylinder fitted with a piston and there are many other ways to heat the water.
nRT = PV
If your "n" is Avogadro's Number, then your equation is correct. If is is the number of molecules per cubic meter, then the formula becomes n=P/kT. This latter formula is much easier to use, since it does away with the awkward molar volume.
first of all, klimatos, I like Serena, Q_Goest and klimatos again,
thank you all for your reply and the warm welcome!
i knew physicists party hard, now i know they also party well.
let me zoom out and give you a wider picture.
i need to pressurize 1 cubic meter of liquid from STP to 70atm.
if a vertical cylinder of 1 cubic meter volume with a piston is completely filled with the liquid at the bottom and then i start pushing steam at 70atm into the other side of the piston at the top, then the liquid should be pushed out at 70atm. right?
if so, then as the liquid gets pushed out, more steam needs to be added to the cylinder to occupy the enlarged volume. right? (or just to heat the existing steam more to increase it's volume)
if so, then by the end of the process all the liquid was pushed out at 70atm, and the cylinder is now filled with 1 cubic meter of steam at 70atm. right?
so:
the volume and pressure were derived from the above logic, the temperature and amount of water to convert to steam came to reach that end point, and that's what i want to verify.
the water used to create the steam will probably be good o'le available tap water. such water obviously weight more than 1kg per liter, but is it ok to say that the estimation of 37.067 liters at 286.72c roughly applies?
that's next on my query list. i just want to see i got that basics of the whole process right before i dive into the engineering aspects of it.
Not sure what you are saying here.
I know of 3 flavors:
PV=nRT where n is the number of moles and R is the universal gas constant
PV=mRT where m is the mass and R is the specific gas constant (for steam in this case).
PV=NkT where N is the number of molecules and k is the Boltzmann constant.
I intended the first, but it is arbitrary.
Just out of curiosity, when would the molar volume become awkward?
Still not sure what you're doing here.
Is the steam pure water, or is it saturated in air?
For reference, with steam of pure water, the formula PV=nRT combined with a molar mass of water of 18 g/mol, yields that:
At P=70 atm, V=1 m3, T=286.72 °C, you need 27 kg water which is approximately 27 liters of liquid water.
If the steam is saturated in air, you need to consult the saturated steam table.
In working with the free atmosphere, when the volume of a mass of air is unknown, but the pressure and temperature can be measured.
The formula P = nkT is the kinetic gas theory equivalent of your equations. This is sometimes written P = nmσ2 in statistical mechanics and statistical thermodynamics. In both equations, P is the pressure in Pascals per square meter, n is the molecular number density in number of molecules per cubic meter, k is Boltzmann's Constant in joules per molecule per Kelvin, T is the gas temperature in Kelvins, m is the mean molecular impulse mass (see my subsequent posting), and σ is the standard deviation of the axial distribution of molecular velocities (root-mean-square axial velocity).
This is easily derived from the equivalence n = NA / V where NA is Avogadro's Number and V is the molar volume and the equivalence R = NA * k where R is the Universal Gas Constant.
tikipu said:
hi all!
Tikipu,
1) n = P/kT = (70 x 1013.25)/(1.3806504E-23 x 559.87). This is the number of water molecules per cubic meter at the specified temperature and pressure. k is Boltzmann’s Constant.
2) mwater = 2.99144976E-26 kg. Note that this is the mean impulse mass of the water molecule, not the mean mass which is 2.99150512E-26 kg (VSMOW standard). Technically speaking, because water is a mixture of molecular masses, the impulse mass should be used in any calculation involving pressure. The difference is negligible in most calculations.
3) n mwater = the mass of one cubic meter of steam at the specified temperature and pressure.
4) Go to Engineering Toolbox and calculate how many joules it will take to heat that amount of water to that temperature and pressure.
Note A: You mention vaporizing a cubic meter of water to a cubic meter of steam. It can’t be done. It is physically impossible. You will end up with slightly more than a cubic meter of superheated water, not steam. Since water is not very compressible, you will likely end up with a ruptured container.
Note B: Having worked with water vapor for many decades, my gut tells me your steam mass of 37.067 kg is way, way, out of whack. Using the calculations shown above, I get only 2.17 grams of steam.
1. What is steam at specific volume and pressure?
Steam at specific volume and pressure refers to the physical state of water vapor at a certain volume and pressure. It is typically measured in units of cubic meters per kilogram (m3/kg) for volume and Pascals (Pa) for pressure.
2. How is steam at specific volume and pressure different from regular steam?
Regular steam is a gas that has been heated to its boiling point and is at atmospheric pressure. Steam at specific volume and pressure, on the other hand, is water vapor that has been compressed to a specific volume and pressure, resulting in a higher temperature and density.
3. Why is it important to study steam at specific volume and pressure?
Studying steam at specific volume and pressure is important in various industries, such as power generation and chemical engineering. Understanding its properties and behavior can help engineers design more efficient systems and equipment that utilize steam as a working fluid.
4. What factors affect the specific volume and pressure of steam?
The specific volume and pressure of steam are affected by temperature, pressure, and the amount of water vapor present in a given space. Other factors such as altitude and the type of fluid used can also impact these properties.
5. How is steam at specific volume and pressure measured?
Steam at specific volume and pressure can be measured using various instruments, such as steam tables, pressure gauges, and thermometers. These instruments provide information on the volume, pressure, and temperature of steam, which can then be used to calculate its specific volume and pressure.
  • Thermodynamics
  • Mechanics
  • Classical Physics
  • Classical Physics
  • Mechanics
