Questions about the drag equation and aerodynamics
In summary, the conversation discusses the use of the drag equation and aerodynamics for calculating atmospheric drag on a streamlined body at high speeds and altitudes. The optimal shape for volume to drag ratio is mentioned as the Sears-Haack body, but there is a lack of empirical data for drag at speeds above Mach 12. The purpose of this discussion is for a high school science project that explores the possibility of launching satellites into orbit from the upper atmosphere using a balloon. The issue of heating and the need for a massive rocket are also mentioned.
Bobcent
31
Hello!
I have some questions about the drag equation and aerodynamics:
[itex]F = \frac{1}{2}ρv^2CA[/itex]
I'm trying to calculate the atmospheric drag on a streamlined body (the drag coefficient will be a very small number) with a velocity of about 8 km/s at about 38,000 meters altitude, where the atmospheric density is only about [itex]5.4\times10^-3[/itex][itex]kg/m^3[/itex]. So my question is; is the drag equation valid even for these extreme values, or is there a better equation that I can use?
Secondly, which is the optimal geometrical shape for [itex]\frac{Volume}{Drag}[/itex]? Is it a streamlined body shape? If it is a streamlined body shape, what is the equation for calculating its volume, and what is the equation for calculating its reference area? Can't find it!
Really appreciate any help on this!
Above the speed of sound, and in particular if heating becomes important, that formula will need some corrections.
NASA and other space agencies should know something about atmospheric drag at those velocities, they might have published something.
Streamlined bodies come in a variety of shapes. In order to calculate something, you would need a description of the particular shape.
Drag at supersonic speeds gets complicated. In order to use the standard equation for drag, the coefficient of drag becomes a function of speed (usually complicated enough to require a table and interpolation). A related wiki article:
http://en.wikipedia.org/wiki/External_ballistics
Thanks for your replies!
I have now found out that the optimum shape for [itex]\frac{Volume}{Drag}[/itex] at high hypersonic speeds is the Sears-Haack body, and the equations for calculating the volume and reference area of the Sears-Haack body are on the wikipidea page, so now that bit is solved. See below if interested:
http://en.wikipedia.org/wiki/Sears–Haack_body
However, I still have a big problem. As "rcgldr" points out, in order to use the standard equation for drag (and I still havn't found any better equation), the drag coefficient becomes a function of speed, and the drag coefficient is based on empirical data for drag at different speeds for the specific shape.
This is a big problem since I can't find any empirical data for drag on the Sears-Haack body at around mach 25 (which is about 8 km/s at 38,000 meters altutude). Does anyone know if any experiments even have been conducted at these speeds for the Sears-Haack body, or for any other shape for that matter?
The highest speeds I've found data on for drag on the Sears-Haack body is mach 12 in a scientific article published by NASA in 1967, has no one really conducted experiments for higher speeds since? See article below:
http://ntrs.nasa.gov/archive/nasa/ca...1967030792.pdf
If anyone wonders what this is for, it is for my high school science project where I'm investigating the possibility to fling satellites into orbit around the Earth from the upper atmosphere instead of launching them by rockets. The upper atmosphere would be reached using a huge helium baloon.
I realize of course that it probably won't work, presumably because of too powerful centrifugal forces, crushing the satellite as it rotates during acceleration before it is released in its trajectory to orbit around the earth. But its still a fun project.
Very grateful for help!
Those experiments would require a massive rocket, and heating is a really serious problem with those parameters.
With a circular motion? You would need a cable which is thicker than the actual spacecraft . Attached to the spacecraft with the same strength as within the cable...
Hi! I am not so sure heating will be a problem in my case, since it will only be seconds before the spacecraft has reached a high enough altitude for the atmospheric drag to be negligible. But I havn't done the calculations yet, so I don't know. Atmospheric density rapidly decreases with altitude, see graph below:
http://www.wolframalpha.com/input/?i=Atmospheric+density+38000+meters+altitude
The graph shows the range of 0...1000km, you can hardly see the relevant range of 30..100km. Sure, atmospheric density drops with height quickly (otherwise concept like the StarTram would be impossible), but the density at 38km is not negligible.
How do you accelerate a spacecraft from 0 to 8km/s in seconds? That would require an extreme acceleration and power output.
What is the drag equation?
The drag equation is a formula used to calculate the drag force on an object moving through a fluid. It states that drag force is directly proportional to the density of the fluid, the velocity of the object, the reference area of the object, and the drag coefficient.
How is the drag coefficient determined?
The drag coefficient is determined through experiments and testing in a wind tunnel. It takes into account the shape and surface characteristics of the object as well as the properties of the fluid it is moving through. It is a dimensionless quantity and can vary depending on the conditions and Reynolds number.
What factors affect the drag force on an object?
The drag force on an object is affected by the density of the fluid, the velocity of the object, the reference area of the object, and the drag coefficient. Other factors that can influence drag include the shape and surface characteristics of the object, the roughness of the surface, and the angle of attack.
How does the drag force affect the motion of an object?
The drag force acts in the direction opposite to the motion of the object, slowing it down. This is because the force is caused by the friction and pressure differences between the fluid and the object. As the object moves faster, the drag force increases and can eventually balance out the applied force, resulting in a constant velocity.
What is the relationship between the drag force and the velocity of an object?
The drag force is directly proportional to the velocity of the object. This means that as the velocity increases, the drag force also increases. This relationship is described by the drag equation, which includes the velocity as one of its variables.
  • Mechanics
11K
  • Mechanics
