Use the known area of a circle to find the value of the integral
In summary: You should find, in this case, that it is πab. You should also find that that is exactly the area enclosed by the ellipse.
gigi9
40
Someone please show me how to do the problem below, thanks very much.
1)***Use the known area of a circle to find the value of the integral
integral from -a to a of the function sqrt(a^2-x^2)dx.
2)***Then use the result of this integral to find the enclosed area of (x^2)/(a^2)+(y^2)/(b^2)= 1, a>b>0.
Plz show me how to integrate #1
Use the substitution x=asinu so that sqrt(a2-x2)=acosu.
Originally posted by gigi9
***Then use the result of this integral to find the enclosed area of (x^2)/(a^2)+(y^2)/(b^2), a>b>0.
The enclosed area of what?
integral from -a to a of the function sqrt(a^2-x^2)dx. ***
You know that the definite integral of a positive function is the area between its graph and the x-axis right? What is the graph of sqrt(a^2-x^2)?
still confused..explain more please
You seem to have serious problems with basic concepts- as illustrated by your saying "Then use the result of this integral to find the enclosed area of (x^2)/(a^2)+(y^2)/(b^2), a>b>0."
I presume that you copied this from some problem but you even copied wrong. "(x^2)/(a^2)+(y^2)/(b^2)" does not enclose anything- it is not a graph nor a function nor an equation. I suspect that you book had "(x^2)/(a^2)+(y^2)/(b^2)= 1", the equation of an ellipse.
As for the first problem: If you are expected to be able to do integrals, then you should already know that a basic interpretation of "integral" is "area under a curve". The function y= sqrt(a^2-x^2)dx is the upper half of the circle x^2+ y^2= a^2 (you can see that by squaring both sides of the given equation). Since the circle has area πa2, the semi-circle has area πa2/2 and that is the value of the integral of the function.
Now that you know that integral, solve (x^2)/(a^2)+(y^2)/(b^2)= 1 for y and apply that knowledge.
please show me how to integrate the 1st one...and how to find the enclosed area of the second one please...(maybe the first few step or something to get me started...) Thanks a lot.
Go back and read problem 1 again. Even though you typed it in here, apparently you did not understand what it was asking you to do.
You are, specifically, to use the formula for area of a circle to find the integral- NOT to "integrate the 1st one" in the usual sense.
As I said before, once you have found that integral, rewrite
x^2/a^2+ y^2/b^2= 1 as y= b√(1- x^2/a^2)= (b/a)√(a^2- x^2) (this is the top half of the ellipse) and use the integral in the first problem (or simply the formula for area of a circle) to find the area of an ellipse.
1. How can the known area of a circle be used to find the value of an integral?
The known area of a circle can be used to find the value of an integral by using the formula for the area of a circle (A = πr^2) and substituting it into the integral.
2. What is the formula for the area of a circle?
The formula for the area of a circle is A = πr^2, where r is the radius of the circle.
3. Can the known area of a circle be used for any type of integral?
Yes, the known area of a circle can be used for any type of integral as long as the integral is in the form of ∫f(x)dx and the limits of integration are in terms of the radius of the circle.
4. How does using the known area of a circle make finding the value of an integral easier?
Using the known area of a circle can make finding the value of an integral easier because it allows us to use a simple formula (A = πr^2) instead of having to evaluate a more complex function.
5. Are there any limitations to using the known area of a circle to find the value of an integral?
There are some limitations to using the known area of a circle to find the value of an integral. It can only be used for integrals that have the same limits of integration as the radius of the circle, and it may not work for more complex integrals with varying limits. Additionally, it may not be applicable to integrals in higher dimensions.
  • Calculus
  • Calculus
