Confusion about continuity and differentiability(In partial differential)
In summary: Differentiability is a stronger condition than the existence of partial derivatives. Intuitively, partial derivatives only sample the function along "coordinate directions" but this is not enough to satisfy the condition of differentiability at a point because the function's behavior along coordinate directions may not represent it's behavior along other directions in higher dimensions. Partial derivatives continuous at a point is not sufficient.
athrun200
277
Example 8 in photo 1 shows that differentiability doesn't implies continuity.
But photo 2 shows a Theorem that contradict to photo 1.
I wonder what is going on here.
Does the textbook get it wrong?
existence of partial derivatives does not imply "differentiability". in some sense, differentiability in higher dimensional spaces is a stronger condition than existence of partial derivatives. intuitively, partial derivatives only sample the function along "coordinate directions" but this is not enough to satisfy the condition of differentiability at a point because the function's behavior along coordinate directions may not represent it's behavior along other directions in higher dimensions. for functions defined on the real line, you do not encounter such problems because there is only one dimension to move around in.
look at http://mathinsight.org/differentiability_multivariable_subtleties" for a detailed example.
i hope this is helpful.
Your example 8 shows that the existence of partial derivatives does not imply continuity. However, as rjvsngh says, the existence of partial derivatives also does not imply "differentiability" so your statement is wrong. Differentiability (whicy is much stronger than the existence of partial derivatives) does imply continuity.
Thx a lot!
I understand it now!
Just to add to what has been said (some nice insights, BTW), a sufficient (but not
necessary) condition for the derivative to exist is that the partials exist and that the
partials are continuous.
Actually, even if the directional derivatives exist in all directions, that is still not a sufficient condition for differentiability.
Any chance you (or anyone else) have an example, lugita15 ?
How about an example of partials existing and partials continuous not
being necessary for derivative to exist?
Recall that if the partial derivatives exist and continuous at (a,b) then the function is differentiable at (a,b),
your example does not contradict this fact.
No, my example was to show that the existence of directional derivatives in all directions is still not sufficient to establish differentiability.
lugita15 said:
From this Wikipedia page, [itex]f(x,y) = \begin{cases}\frac{y^3}{x^2+y^2} \text{ if }(x,y) \ne (0,0) \\ 0 \text{ if }(x,y) = (0,0)\end{cases}[/itex].
Can anyone explain why this function is not differentiable at (0,0)?
Consider the directional derivative in the direction of the vector (1, 1). Computed using the definition of the derivative (no shortcuts, since we do not know whether the function is differentiable here), we get 1/2.
However, the Jacobian matrix for f at the point (0, 0) is [0, 0], since both partials vanish along the axes. A standard theorem in vector calculus states that if f is differentiable at (0, 0) then the directional derivative of f at (0, 0) in the direction of the vector (1, 1) is equal to the product of the Jacobian matrix with the vector. However, that product is 0, which is not the directional derivative of f in the direction of (1, 1) at the point (0, 0), as we derived in the previous paragraph. Thus, f is not differentiable at (0, 0).
Visually, you can take directional derivatives in several directions at (0, 0); in particular, take directional derivatives in the directions (cos(t), sin(t)) for various t and you will get different derivatives. There cannot be a unique tangent plane that is tangent to all of these curves.
See here (pages 4-6).
Check the continuity of the function at (0,0). Find different curves approaching (0,0) to show that f is not continuous there.
If the partial derivatives exist and are continuous in some neighborhood of a point then the function is differentiable. Partial derivatives continuous at a point is not sufficient.
1. What is the difference between continuity and differentiability?
Continuity and differentiability are two important concepts in calculus. Continuity refers to the smoothness of a function, meaning that there are no abrupt changes or gaps in the graph. Differentiability, on the other hand, refers to the existence of a derivative at a given point. In simpler terms, a function is continuous if it can be drawn without lifting your pencil from the paper, while a function is differentiable if it has a well-defined slope at a given point.
2. Can a function be continuous but not differentiable?
Yes, a function can be continuous but not differentiable. This means that the function has no abrupt changes or gaps, but it does not have a well-defined slope at a certain point. An example of such a function is the absolute value function, which is continuous but not differentiable at the point where the graph changes direction.
3. How do you determine if a function is differentiable?
A function is differentiable if it has a well-defined derivative at every point in its domain. To determine if a function is differentiable, you can use the definition of a derivative or the differentiability rules, such as the power rule, product rule, and quotient rule. If a function satisfies these rules, it is considered differentiable.
4. What is the importance of continuity and differentiability in calculus?
Continuity and differentiability are essential concepts in calculus as they allow us to analyze the behavior of functions and solve problems related to rates of change. Continuity ensures that a function is well-behaved and can be easily studied, while differentiability allows us to find the slope of a function at a given point, which is crucial in optimization and curve sketching.
5. Can a function be differentiable at a point but not continuous?
No, a function cannot be differentiable at a point but not continuous. This is because differentiability requires continuity at a given point. If a function is not continuous at a certain point, it cannot have a well-defined slope at that point, making it not differentiable. Therefore, a function must be continuous at a point to be differentiable at that point.
  • Topology and Analysis
  • Science and Math Textbooks
