Angular Velocity: spinning in chair, dropping weights with arms out
by gauss44
Tags: angular, arms, chair, dropping, spinning, velocity, weights
gauss44
gauss44 is offline
#1
Feb22-14, 11:55 PM
P: 30
Would someone be willing to explain this? Here: http://www.physicsforums.com/showthread.php?t=487058
I read the entire thread and don't understand. I need one person to explain it step by step all in one place. In my case it's not a homework question. Please don't use the Socratic method! Just explain in plain English. Thank you!
(As an aside, I've never been able to learn from the Socratic method. It confuses me. With the Socratic method, I always remember the incorrect theories and never the correct ones. This question is a real doozy: http://forums.studentdoctor.net/thre...roblem.809233/ http://forums.studentdoctor.net/thre...vii-45.975274/)
Phys.Org News Partner Physics news on Phys.org
A 'quantum leap' in encryption technology
Using antineutrinos to monitor nuclear reactors
Bake your own droplet lens
256bits
256bits is offline
#2
Feb23-14, 01:24 AM
P: 1,272
It might help for you to explain what specific part of the the thread or statement within is bothering you.
Otherwise it could become an exercise of futility, discussing that which you already do understand, and then not discussing that which you do not. That would not be much help to you.
The other two links, by the way, seem to be an execise in how to promote confusion.
gauss44
gauss44 is offline
#3
Feb23-14, 03:17 AM
P: 30
Quote Quote by 256bits View Post
I have the same question as the OP. I quote, "can someone explain to me why "moment of inertia would not change for the system when the student drops the weight" since Inertia is proportional to mass x r^2 wouldn't a decrease in mass after the weight drop decrease the moment of inertia?"
jbriggs444
jbriggs444 is offline
#4
Feb23-14, 04:42 AM
P: 754
Quote Quote by gauss44 View Post
Angular momentum is conserved if you are considering a closed system with no external torques. If you have 5 kg weights first considered as being inside the system and then considered as being outside, it's obviously no longer a closed system. Angular momentum need not be conserved. Removing those weights obviously results in a decrease in angular momentum.
So don't analyze the non-closed system consisting of the student plus weights. Analyze the closed system consisting of the student alone. When the student opens his or her hands, releasing the weights, does this involve an external torque on the student? Nope. So the angular momentum of the student alone does not change as a result. When the student opens his or her hands does this involve a change in moment of inertia of the student alone? Nope. So the angular velocity of the student alone does not change either.
dauto
dauto is offline
#5
Feb23-14, 08:35 AM
P: 1,291
Yes, the moment of inertia changes. But the angular velocity doesn't. The weights take some angular momentum with them, so you can't assume that angular momentum is conserved.
Register to reply
Related Discussions
Prove a spinning yo-yo has angular velocity Introductory Physics Homework 2
Where's the torque when you retract your arms on a spinning chair? Classical Physics 26
Angular Velocity of a turntable after weights are added Introductory Physics Homework 1
Angular Velocity of the Spinning Earth! Introductory Physics Homework 19
Finding Kinetic Energy of Person Spinning on Chair w/ Weights Introductory Physics Homework 4
