How do you solve for x using the expansion method?
In summary, the given equations cannot be solved for x using the expansion method, as there are no unique solutions for x.
haengbon
38
x + y + z =1
x + y + 2z =2
x + y + 3z = 1
none
1 1 2 1 1
1 1 3 1 1
1 1 1 1 1
1 1 2 1 1
1 1 3 1 1
1 1 1 1 1
1 1 2 1 1
1 1 3 1 1
(1)(1)(3) + (1)(2)(1) + (1)(1)(1) - (3)(1)(1) + (1)(2)(1) + (1)(1)(1)
(3)+(2)+(1) - (3)(2)(1)
=6 - 6
= 0
would this be undefined then?
Hi haengbon! :smile:
I'm not familiar with the "expansion method", but simple subtraction on …
haengbon said:
x + y + z =1
x + y + 2z =2
x + y + 3z = 1
… gives both z = 1 and z = 0, so clearly there are no solutions! :wink:
tiny-tim's not alone. I haven't heard of this method, either, so the work you show is a complete mystery to me.
I think the OP is writing the system in terms of a matrix A where Ax=b and is trying to calculate the determinant of A. In this case, one gets
det A = (1)(1)(3)+(1)(2)(1)+(1)(1)(1)-(1)(1)(1)-(1)(2)(1)-(1)(1)(3) = 3+2+1-1-2-3 = 0
so there's no unique solution for x.
Perhaps "expansion method" refers to Cramer's rule.
That's the method that I learned for calculating the determinate in HS. You copy the first column over on the Right side so the diagonals are all nice and in line...then you calculate the number as shown above...forgot the + signs on the last line there.
(3)+(2)+(1) - (3)(2)(1) should have + in between the last 3 2 1.
1. How do you solve for x using the expansion method?
The expansion method is a technique used to solve for the value of x in an equation. It involves expanding the equation using algebraic manipulation and simplifying it until you are left with a single value for x.
2. What are the steps involved in using the expansion method to solve for x?
The steps for solving for x using the expansion method are as follows:
1. Distribute any parentheses in the equation
2. Combine like terms
3. Move all terms containing x to one side of the equation
4. Move all constant terms to the other side of the equation
5. Use inverse operations to isolate x on one side of the equation
6. Simplify the equation until you are left with a single value for x.
3. Can the expansion method be used to solve for x in any type of equation?
No, the expansion method is most commonly used to solve for x in linear equations (equations with only one variable), although it can also be used for some quadratic equations.
4. Are there any shortcuts or tricks to using the expansion method?
There are no shortcuts or tricks to using the expansion method, as it is a straightforward and systematic approach to solving equations. However, it does require a good understanding of algebraic principles and practice to become proficient at it.
5. What are some common mistakes to avoid when using the expansion method?
Some common mistakes to avoid when using the expansion method include:
- Not distributing parentheses correctly
- Forgetting to combine like terms
- Making errors in the simplification process
- Not isolating x on one side of the equation
- Forgetting to check your answer to ensure it satisfies the original equation.
