Thermal Energy I don't see why my method is wrong.
In summary: But presumably you could still do it in your head, using calculus. :smile:In summary, the problem involves adding two quantities of water at different temperatures and finding the final temperature of the mixture. By using the law of conservation of total internal energy and the average temperature formula, the final temperature is calculated to be 21.36*C (294.36 K). It is important to note that this method works for the same state of the same material, but may not be applicable for different materials or states with temperature dependent heat capacities.
Null_
231
300 g of water whose temp is 25*C are added to a thin glass containing 800 g of water at 20*C. What is the final temperature of the water?
deltaE=mCdeltaT
Here's what I did:
deltaEsys=mCdeltaT
[300g (4.2 J/K/g) (Tf - 298K) ] - [800g (4.2J/K/g)(Tf- 293K) ] = 0
(300g)(Tf-298K) = (800g)(Tf-293K)
300g*Tf - 89400g*K = 800g*Tf - 234400g*K
145000g*K = 500 g*Tf
290K = Tf
The correct answer is 21.36*C (294.36 K)
If you are going to use different signs for the temperature difference then you need to add the two energy changes.
that "-" should be "+"
ehild
Ah, thank you. I was thinking about: Ef-Ei=W=0, but that is obviously not the case since there are two initials and two finals.
Hi Null_! :smile:
(have a degree: ° :wink:)
290K = Tf
Why did you use the 4.2 and the 293 ?
This is a straightforward averaging question … no point in multiplying by, or subtracting, constants that have to be eliminated later …
no wonder you made a mistake somewhere! :redface:
try it again, just finding the average temperature when 3/11 is at 25° and 8/11 is at 20° :wink:
That's correct but by making one of the dT negative you did Ef - (-Ei) = 0
Don't listen to 'tiny-tim'. While his method works in this particular case, it should be derived from the law of conservation of the total internal energy of the system (since the system is thermally isolated and there is no work done on it).
As a reminder that 'tiny-tim''s rule is incorrect in general, how would you calculate the equilibrium temperature if you had some quantity of ice at -5 oC and you pour over some quantity of hot water at 80 o?
Ah, but that's two different materials (or two different states, anyway) …
here, it's the same state of the same material, so the averaging method is correct (technically as well as practically). :smile:
What if the heat capacity is temperature dependent?
I've never come across a question involving that! :biggrin:
1. How is thermal energy different from other forms of energy?
Thermal energy is the internal energy of a system due to the motion of its particles. It is different from other forms of energy because it is specifically related to the temperature and heat of a system.
2. How is thermal energy measured?
Thermal energy is measured in units of joules (J) or calories (cal). It can be measured directly using a calorimeter or indirectly using temperature and mass measurements.
3. What are the sources of thermal energy?
Thermal energy can come from various sources, such as the sun, friction, chemical reactions, and nuclear reactions. It can also be generated by machines, such as engines and heaters.
4. How does thermal energy transfer from one object to another?
Thermal energy can transfer through three main mechanisms: conduction, convection, and radiation. Conduction is the transfer of heat through direct contact, convection is the transfer of heat through the movement of fluids, and radiation is the transfer of heat through electromagnetic waves.
5. Can thermal energy be converted into other forms of energy?
Yes, thermal energy can be converted into other forms of energy, such as mechanical energy, electrical energy, and chemical energy. This conversion can be achieved through various processes, such as steam turbines, thermocouples, and chemical reactions.
24K
