Average Velocity of a particle moving in a circle over a given interval
In summary, the conversation is about finding the average velocity of a particle moving along a circular path. The equation for the velocity is c * 2 = 15.7079, and the definition of average velocity is the change in x over time. The conversation also discusses finding the displacement and direction of the particle, and determining the average velocity vector. Through a series of questions and answers, the participant is able to successfully calculate the average velocity of the particle.
IAmPat
29
d = 2.5
c = pi*d = 7.854
velocity/s ?= c * 2 = 15.7079
Since PR is 1/4 of the circle and the particle moves around the circle 2 times per second, I thought the average velocity would be 1/8th of the velocity that it's traveling. I'm really confused on this one.
EDIT: I only need to solve for (a), that's why I only have data pertaining to that. Not worried about B and C, but any intuition on those is welcome.
What is the definition of average velocity?
The change in x over time. The change in X is -1.25 right? and the time is 1/8 of a second... .125
dx/dt = -1.25/.125 = 10?
I'm not following
If someone were to show you two snapshots, the first showing the particle at P at time zero, and the second at point R at a time 1/8 second later, and you had no idea about the circular course, or what path the particle took to get from P to R, how would you go about finding the average velocity?
Why just x?
gneill said:
Why just x?
What do you mean why just x?
The change in x is -1.25 and the change in time is 0.125 seconds, right?
So the particle didn't move along the circular path, but instead traveled a straight line along the x-axis and ended up at the origin? Is point R at the origin?
It's at Y=1.25 and X=0. If I were to draw a straight line from P to R, the angles would be 45, 90 and 45 right? and the equation for the line would be:
1.25^2 + 1.25^2 = C^2
1.5625 + 1.5625 = C^2
3.125 = C^2
C = 1.767767
So ... The vector is (1.767767, 135 degrees)?
Okay! So you've got a distance vector. That gives you the displacement (magnitude of the vector) and the direction. Apparently the displacement happened in 1/8 second. So what's the average velocity vector?
So if the displacement is 1.767767 and happened in 1/8th. I assume I multiply the displacement by 8 to get the velocity per second...
So 14.1421 m/s?
Yup!
Remember though, that velocity is a vector. So you want to retain the angle information in your answer.
gneill said:
Yup!
Awesome. Your socratic method of teaching pissed me off to no end but it worked, and I'm very thankful for your help :tongue:
Heh. Bet you'll remember how to find the average velocity though!
Build a man a fire and he'll be warm for a day.
Set a man on fire and he'll be warm for the rest of his life!
What is the average velocity of a particle moving in a circle over a given interval?
The average velocity of a particle moving in a circle over a given interval is the total displacement of the particle divided by the total time taken for the motion. It is a vector quantity that describes the rate of change of position of the particle in a circular path.
How is the average velocity of a particle moving in a circle calculated?
To calculate the average velocity of a particle moving in a circle, we need to find the total displacement of the particle over the given interval and divide it by the total time taken for the motion. This can be represented as:
Average velocity = (Total displacement)/ (Total time taken)
Does the average velocity of a particle moving in a circle change?
Yes, the average velocity of a particle moving in a circle can change if the speed or direction of the particle changes. This is because the total displacement and total time taken for the motion will also change, resulting in a different average velocity.
How is the average velocity of a particle moving in a circle different from the instantaneous velocity?
The average velocity of a particle moving in a circle is the average rate of change of the particle's position over a given interval. On the other hand, instantaneous velocity is the velocity of the particle at a specific moment in time. This means that while average velocity takes into account the entire motion of the particle, instantaneous velocity only considers a single point in time.
Can the average velocity of a particle moving in a circle be negative?
Yes, the average velocity of a particle moving in a circle can be negative if the particle moves in a clockwise direction. This is because the direction of motion is taken into account when calculating average velocity, and negative velocity indicates motion in the opposite direction of a chosen positive direction.
10K
