Exam III Practice Problems (liquids and pressures)
In summary: Well it is released and the rest of the energy is converted to heat. What was the force of friction then well i have no ideaIn summary, the conversation is about a student preparing for an exam and asking for help with various physics problems. They discuss using the Bernoulli equation, drawing free body diagrams, and solving for tension and forces. They also discuss using multiple choice questions to find the correct equations and using the formula for Archimedes' principle. The conversation also includes multiple questions about specific problems and the process of solving them, including using conservation of energy.
Alt+F4
306
hi, i got an exam soon and i need help with a couple of problems
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp05 Question 7.
How would i find the tension i know that i must use Bernoulli equation but what would i be solving for
What are the forces acting on the block?
Can you draw a free body diagram of the block?
The Bernoulli equation is for fluid flow so I'm not sure why (or how) you would use it here.
ooo well all i have been doing for the past 4 weeks is using that eqaution for HW and stuff so i thought it must be it. Anywyas, You have the Water pushing up, Wood Pushing down and String pulling down
Right. You have the buoyant force acting upwards, the weight of the block acting downwards and tension acting downwards.
Can you see how to solve for tension now?
Edit:Never mind
You are given the volume of the block and its density. Using those facts you can find its mass.
As far as the forces, like you said earlier there are only 3 forces: Tension down, weight down, and buoyancy up.
Recall Archimedes' principle that the buoyancy force is equal to the weight of the displaced fluid.
thanks, I'll be back with more in 5 min. :)
ya i got it, there are too many stuff that are same like V= Velocity but then it is Volume in that equation. Crazy
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp05 Question 15. ANy trick to finding the quick answer to these. Thanks
Well given that it's a multiple choice you can just see which one of those three equations fits your given information.
You're given that at t=0 s v=11.1 m/s.
Thanks alot, i need to ace this exam so sorry for all the questions.
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp05 Question 16
Can i use one of these equations for 15 to just plug in 1.5 and get the V which i can get Kinetic energy from
Well try it and see if you get the right answer.
:( nope well i was thinking of using X(t) = A cost(omega t) but what would A be hmmmm
Im stupid. I got it
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/sp05 Question 19. I am not getting why Pa > Pb. Thinking of it B is a more tighter area so there will be more pressue on it
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/fa04 Question 7. SO what i did was
Force of Friction - Force of compression of spring
UkMg - -kx = 0
(X)(20*9.8) = 270 * .2
What am i doing wrong.
Question 25 http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/fa04
Okay so i got the answer to 24 which was 600. FOR 25 i am going to use this formula h = (M + m)/ (Density* A)
D= M/v
600 = M/ (2*.15) or is it (2*.25)
little m is just 20*3 = 60
Density on bottom is 1000
A = .25*2
plug that it and i am not getting the answer
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/fa05 Question 10. hmmmmmmm Well wat i did was
(1000)(9.8)(.3) = (X)(9.8)(.6)
Which gave me 500 which is wrong.
http://online.physics.uiuc.edu/cgi/courses/shell/phys101/spring06/prep2a.pl?practice/exam3/fa05 Question 19. I think this should be it for a while, Thanks for everyones help.
So what i did was
Patm = P1 + .5(1000)(2^2) + (1000*9.8*2)
Which gives me
Patm - PB = 2.2*10^4 (not the answer)
Answer: 1.8*10^4
UkMg - -kx = 0
I drew out free body diagram and i still can't get it
UkMg - -kx = 0
For that one
Would it be
Force of friction - (The Total Work of spring) = 0
so
Mu mg - .5KX^2 = 0
but i can't get the answer
You can't subtract work from force. It's a meaningless expression
You need a statement of conservation of energy. What energy does the block have when it is pulled .2m, and where does that energy go?
Think about what you are doing. What you said in your expression is that the pressure due to the column of substance b is equal to the pressure of the half column of substance A on the left side. Why did you assume that is true?
Think about which pressures have to be equal.
okay so Potential Energy is .5KX^2 = 5.4 J
Energy then is converted to Kinetic which is also 5.4 J
You're right that's converted to kinetic but you forgot about friction.
Compare the two states that the block is in:
State 1: all potential energy equal to .5*k*x2
State 2: No potential energy (x=0), no kinetic energy (they told you it's not moving), so the energy must have gone into friction.
Do you know how to find work done by a force over a distance?
Honestly I think you need to think a bit more about the concepts behind the problems instead of just trying to find an equation to blindly plug numbers into and then posting on here when that equation doesn't work.
okay so are u saying that 5.4J = the energy of friction
So what then do i use to get an asnwer of .14
casue i did 5.4 = X(20*9.8)
i would if we had a book, but the lectures as u can see on the site are basics so i just gota do it by trial and error that is why there are so many exams given
Look at what you're doing.
x(20)(9.8) gives you the force of friction.
That force acts over a certain distance.
Now you want to find the work done by that force.
Do you think you can find it given a force and the distance over which it acts?
oooooooooooooooooooo Thanks so much, i forgot totally about W = F*D
  • #31
D= M/v
A = .25*2
Forget what i did upthere
this is what i did
the buyoant force has to balance the weight
Fb = m*9.8
(1000)(9.8)(X) = (300+60)(9.8)
X=.36
.15-.36 = .21 m which is not answer
  • #32
this is what i did
Fb = m*9.8
X=.36
Two problems:
(1) Why do you think the mass of the wood is 300 kg?
(2) The "X" in your equation stands for volume displaced, not depth.
  • #33
Doc Al said:
Two problems:
cause i got a density of 600
So what i did was
D= M/V
600 = M/ (2*.25) which gave me 300
  • #34
Doc Al said:
Two problems:
well i was thinking since it is already at .15, whatever the number i will get will have the .15 added to it
  • #35
So what i did was
D= M/V
Volume requires all three dimesions. You multiplied length by height, but what about width? (If you include units in your calculations, you'll be less likely to make this kind of error.)
9K
  • STEM Academic Advising
