Einstein's warping of space-time as a theory of gravity
In summary, the Gravity Probe B satellite experiment is currently being performed in a polar orbit around the Earth and if it confirms the predictions of the theory of General Relativity then it may make the curvature of space-time more than just a conceptual mapping. Those who believe space-time curvature does not really 'exist' are called Instrumentalists, while those who believe in the reality of the geometry are called Idealists.
Overdose
195
Heres what i don't understand, a massive body in space causes the space around it to warp in accordance with its shape, fine i understand that.
What i don't understand is why the massive body would warp the space beyond the close surface of it's body. Which, according to einstein it does and causes other planets near it to follow the path of this warped space.
I tried likening it to a ball placed in a bath, the water (like space) wraps itself around the ball to accommodate its shape. But the water isn't displaced beyond the ball's shape...unless the ball is rotating like a planet, in which case it would create a swirling current around it.
Maybe a bad analogy but...is this what einstein meant? that planets by rotating create ripples and swirls in space-time, and it is these that the other near by planets 'follow' and are carried along by?
Hope someone can help, as this model of gravity has never really made much sense to me... :redface:
Place a marble that weighs as much at 1 ton in the middle of a trampoline. This warps the trampoline. Now role another normal weighing marble around the edge. It will start going in circles, or rotating around the larger mass. Maybe this analogy helps a bit more.
Paden Roder
The curving of space-time due to the presence of mass is greatest near the object and weakens as one moves further away. In that sense it is similar to Newton's theory.
In neither Newton's view nor Einstein's view is the rotation or movement responsible for either the force or the curvature of space although the two theories predict different effects when rotation of a body is taken into account.
This is what i suspected, i just couldn't wrap (no pun intended) my head around why this should be the case atall, and why space shouldn't simply close itself around the surface area of the object.
I suppose my question could be re-phrased why does mass disrupt space beyond the object's position? (in relation to heavy bodies like planets)
Now that is the million dollar question! Why is anything the way it is? In Newton's picture of gravitation the fundamental question of why mass exerts a force on another mass is not answered. Einstein merely replaces the question with a new one - why does matter curve space-time? In essence, both address the question of how the world works but the question of why it works that way may or may not even be answerable!
Hi,
It isn't necessary to believe that space/time is really warped.It is only necessary to understand that the space/time coordinate system used to define space/time in the GR model is warped with both axes being curved relative to flat space/time.
juju
juju said:
Hi,
juju
Thats a pretty shocking answer but one i half expected,
For me its incredibly important to understand if space-time is warped or not, otherwise I am just dealing with a conceptual niceity that's a waste of my time. :frown:
Hi Overdose,
The concept of the actual warping of space/time is one conceptual mapping of the theory on to reality.
Other possible mappings say that the presence of mass affects the properties of the space around the mass in a different manner, but produces the same results.
Some of the properties that have been theorized to be affected are refractive index; energy density; coherence level and intensity and phase of vacuum fluctuations; and even permittivity and permeability.
These changes might change the structure of space/time in such a manner as to produce the same results as a warping of space/time.
You pays your money and you makes your choice.
juju
If the Gravity Probe B satellite experiment, being performed at this time in a polar orbit around the Earth, confirms the predictions of GR of the geodetic precession and the Lense-Thirring frame dragging precession of its four gyroscopes then it may make the curvature of space-time more than just a conceptual mapping.
Those who believe space-time curvature does not really 'exist' but is just a conceptual model that obtains the right answers are called Instrumentalists, those who actually believe in the reality of the geometry are called Idealists.
One way of distinguishing between the two is the Idealist position does not require gravitons as there is no such thing as gravitational force, just geometrodynamics.
Curved space-time seems to confuse a lot of people. Hopefully, at least some of the people confused by the idea of curved space-time would not be so confused by the idea of tidal forces. The idea is pretty simple, if gravity is attracting another body, and the force is going down as the distance is going up, there must be at any given point some "gradient" of the force, the rate at which the force changes per unit distance.
But here's the kicker - in empty space, space-time curvature and tidal forces are just two different ways of describing the same concept! This is probably the hard part to grasp, there are numerous illustrations of rubber sheets, and ants marching around apples, that try to illustrate it graphically, with varying degrees of success.
1. What is Einstein's theory of gravity?
Einstein's theory of gravity, also known as the general theory of relativity, states that gravity is not a force between masses, but rather a curvature of spacetime caused by the presence of mass and energy. This curvature affects the motion of objects and causes them to move towards each other.
2. How does Einstein's theory explain the warping of space-time?
Einstein's theory proposes that mass and energy create a curvature in the fabric of space-time, similar to how a heavy object placed on a stretched rubber sheet would cause a dip. This warping of space-time is what we perceive as gravity.
3. How does Einstein's theory differ from Newton's law of gravity?
Newton's law of gravity states that gravity is a force between masses, and it decreases with distance. On the other hand, Einstein's theory describes gravity as a curvature of space-time, with no force involved. It also takes into account the effects of time and space on gravity, whereas Newton's law does not.
4. Has Einstein's theory of gravity been proven?
Yes, Einstein's theory of gravity has been proven through numerous experiments and observations, such as the bending of light by massive objects and the precise prediction of the orbit of Mercury.
5. Are there any limitations to Einstein's theory of gravity?
While Einstein's theory of gravity has been incredibly successful in describing the behavior of gravity, it does have limitations. It does not fully incorporate quantum mechanics, and it cannot explain the behavior of gravity at the smallest scales, such as inside black holes. Scientists are still working to develop a theory that can unify gravity with the other fundamental forces of nature.
