How do we know that the stress-energy is a tensor?
  • Thread starter jdstokes
  • Tags
    Tensor
In summary, the requirement of general covariance played a significant role in motivating Einstein's field equations of general relativity. The transformation properties of the stress-energy tensor under coordinate changes were a concern, particularly in non-Cartesian coordinate systems. While textbooks on general relativity may show how the stress-energy tensor is a multilinear map and therefore coordinate invariant, there is still debate on how to show its tensor nature. Some argue that it must be postulated as an upgraded form of Lorentz covariance, while others suggest defining it in terms of tensors from the start. The stress-energy tensor appears as the right-hand side of Einstein's equations, but its transformation properties may not always be what is desired for energy conservation or Noether's law. This
jdstokes
523
Einstein used the requirement of general covariance to motivate the field equations of general relativity.
Suppose I define [itex]T^{\mu\nu}[/itex] as the component of [itex]\mu[/itex]-momentum across a surface of constant [itex]\nu[/itex], relative to some coordinate system [itex]x^\mu[/itex]. If we change coordinates to [itex]x'^\mu = x'^\mu(x)[/itex], how do we know that the components of stress energy will look like
[itex]T'^{\mu\nu} = \frac{\partial x'^\mu}{\partial x^\alpha}\frac{\partial x'^\nu}{\partial x^\beta}T^{\alpha\beta}[/itex].
I ask this because I've been thinking about how the stress-energy would look in a coordinate system other than cartesian (e.g., spherical coordinates) and it occurred to me that it is not obvious that it will transform in the desired way.
? Any good book on general relativity will show that.
I have seen a lot of textbooks on GR, and I have never seen such a derivation. Can you name one which contains it?
I'm not talking about some abstract statement like `the energy-momentum tensor is a multilinear map and is therefore coordinate invariant'. I'm looking for something along the lines of what Einstein was thinking.
The components of the stress-energy tensor only have their nice interpretation in a Cartesian (Lorentz) frame. However nabla.T=0 is a frame independent equation.
The stress-energy certainly transforms in the correct way under Lorentz transformations which you can see by examining the components of e.g., the electromagnetic stress-energy.
Are you saying that the tensor nature of the stress-energy follows from the requirement that it be covariantly conserved (i.e., that [itex]\nabla_\mu T^{\mu\nu}[/itex]?
It seems like there should be a way of showing that it is a tensor, similar to the way that one would show that [itex]A_\mu \equiv \partial A/\partial x^\mu[/itex] is a tensor (where A is a scalar).
My understanding is that in electromagnetism the stress-energy tensor is defined using the vector potential. So the tensor property should follow from there.
Einstein's field equation alone doesn't give the stress-energy tensor meaning, except tautologically. There has to be a separate equation of state that defines the matter content of the universe (eg. Maxwell's equations, perfect fluid, etc.), and also a definition of the stress-energy tensor in terms of the state variables. The stress-energy tensor appropriate for each sort of matter has to be constructed so that it is symmetric and covariantly conserved. A Lagrangian is a way of getting an equation of state which automatically has an appropriate stress-energy tensor to go into Einstein's field equation.
Maybe look at section 3 of Andersson and Comer's http://relativity.livingreviews.org/Articles/lrr-2007-1/ .
Hi atyy.
In em, the stress-energy tensor is manifestly Lorentz covariant. It is not clear, however, whether or not it is generally coordinate invariant.
It is an interesting point you raise that the stress-energy loses the interpretation in terms of fluxes if we depart from a cartesian frame. In some sense it is meaningless to ask how the stress-energy transforms from cartesian to curvilinear coordinates, since we only know how to define it relative to a cartesian frame.
My feeling now is that general coordinate transformation properties of the stress-energy cannot be derived but must be postulated as an upgraded form of Lorentz covariance. Unless, of course, we define the stress energy in terms of tensors to begin with (as is done in modern treatments) in which case general covariance follows as a corollary.
Weinberg discusses this at length in his GR book and is probably the most nuts and bolts explanation you will find out there.
"My feeling now is that general coordinate transformation properties of the stress-energy cannot be derived but must be postulated as an upgraded form of Lorentz covariance."
Mmm, it depends a little on how you go about it, there are many possible and distinct definitions and ways to get at the object (which is a *pseudo*tensor the second you turn gravity on, so *not* generally covariant). You can sometimes single it out uniquely, as Weinberg shows when you use it as a source or if you get it from an action principle.
Hi Haelfix,
Can you give a particular page/chapter reference? I have learned some GR from Weinberg but don't recall any discussion about the stress-energy tensor being a pseudo-tensor nor on the general covariance of it.
Why is the stress-energy not a tensor? Surely being the right-hand side of Einstein's equations has the same transformation properties as the Einstein tensor and is therefore generally covariant?
The matter/fluid/EM stress energy tensor by itself *is* usually a tensor (except for one possible sublety related to chiral ambiguities and signature issues). Eg the thing appearing on the right hand side of Einsteins eqns. But that's not the only way the object arises, and you have to be careful. In fact, even with the geometric interpretation of the field equation, coordinates appear in the components of the stress energy tensor. Its quite a nuissance to show everything is self consistent.
The problem is that while that of course transforms in the way you want, its not necessarily what's conserved either (say for energy conservation) or what may appear in generalized versions of Noethers law. If you want to include gravity as a source (say gravitational waves and their interactions) you either have to deal with the full nonlinear Einstein's equation directly or construct an object that also includes gravities self contribution. Thats where pseudo tensors/tensor densities often arise.
Wiki has a bit about this:
http://en.wikipedia.org/wiki/Stress-energy_tensor#Variant_definitions_of_stress-energy
or alternatively an advanced GR text like Weinberg or even Landau/Lifgarbagez.
It depends on what kind of source you're talking about. For example, if you have a gas of particles (treated as a continuum), you can deduce the transformation properties of the energy-momentum the fact that the particles are relativistic. Or if you have a classical relativistic field, then the energy-momentum tensor is defined in terms of the Lagrangian for the field and you can deduce its transformation properties from the definition. But the point is that whatever kind of source you have, if its a properly relativistic theory, the energy-momentum tensor will transform in the correct way. The theory of the material/matter/field source is not given by general relativity of course, so you can't prove anything about the energy-momentum tensor of the EM field for example from GR. This is essentially the same as the fact that Newton's theory of gravity can't prove that mass is a scalar.
Yes there is a way. The functional derivative of a SCALAR functional with respect to a rank-2 TENSOR is another rank-2 TENSOR. In any field theory, the symmetrized canonical energy-momentum tensor coincides with the functional derivative of the scalar action with respect to the metric tensor,evaluated in flat space, i.e., it can be defined by the covariant statement;
[tex]T_{ab} \equiv 2 \frac{\delta S[\phi]}{\delta g^{ab}}[/tex]
regards
sam
[tex]T_{ab} \equiv 2 \frac{\delta S[\phi]}{\delta g^{ab}}[/tex]regards
sam
Yes, but the fact that energy-momentum is the functional derivative of the scalar action with respect to the metric tensor in flat space is not a fact of general relativity, it is a fact of classical field theory. Also, the classical relativistic fields, although a very general set of things, do not encompass all possible sources.
I think you misunderstood meaning of "evaluated in flat space". When you evaluate the above generally covariant expression in flat space, it gives you the energy-momentum tensor of the MATTER (including the electromagnetic) fields in flat space.
In GR the action is the sum of the actions of the gravitational field S[g] and matter field [itex]S[\phi][/itex]. To derive the equations of the gravitational field, we use the action principle
[tex]\delta \left( S[g] + S[\phi] \right) = 0[/tex]
where
[tex]\delta S[g] = - \frac{1}{16 \pi k} \int d^{4}x G_{ab} \delta g^{ab} (-g)^{1/2}[/tex]
and
[tex]\delta S[\phi] = \frac{1}{2} \int d^{4}x T_{ab} \delta g^{ab} (-g)^{1/2}[/tex]
or
[tex](-g)^{1/2}T_{ab} = 2 \frac{\delta S[\phi]}{\delta g^{ab}}[/tex]
So, it is a "fact of general relativity". Indeed, the above covariant definition of the energy-momentum tensor was not even known before GR.
regards
sam
Hi samalkhaiat,
Thanks for your reply. I sort of independently arrived at the same answer but it's good to have reassurance.
I knew it had to be something simple like this.
Don't you find it surprising that something as fundamental as this is not discussed in any of the textbooks? E.g., there is no mention of this in Landau, D'inverno, Weinberg, Carrol, MTW... They seem to prefer to define the stress-energy as a linear function which maps basis vectors to fluxes of 4-momentum.
Although I can sympathise with their definition, I do think that it obscures Einstein's original motivation for the field equations.
I doubt that this is true. If you allow the field to form delta functions then you should be able to construct any source you want.
Again, I recommend chapter 4, Lagrangian and Hamiltonian formulations of general relativity, from the book A Relativist's Toolkit: The Mathematics of Black-Hole Mechanics by Eric Poisson. Samalkhaiat's treatment is given on page 125.
No I don't, because, as you said, the proof is simple. Once you accept the Hilbert DEFINITION
[tex]\sqrt{-g} T^{ab} \equiv 2 \ \frac{\delta S}{\delta g_{ab}} \ \ \ (1)[/tex]
the proof becomes almost trivial. It follows directly from the definition of the functional derivative
[tex]\delta S \equiv \int \ d^{4}x \ \frac{\delta S}{\delta g_{ab}} \ \delta g_{ab} = \int \left(d^{4}x \sqrt{-g}\right) \left( \frac{1}{\sqrt{-g}}\frac{\delta S}{\delta g_{ab}}\right) (\delta g_{ab} )[/tex]
We first note that ([itex]d^{4}x\sqrt{-g}[/itex]) is a scalar and ([itex]\delta g_{ab}[/itex]) is symmetric covariant tensor. Thus ( in order for [itex]\delta S[/itex] to be scalar), ([itex]\delta S / \delta g_{ab}(-g)^{-1/2}[/itex]) must be symmetric contravariant tensor.end of proof.
This looks simple enough! But don't you find it surprising that we regard Eq(1) as a DEFINITION for the matter energy-momentum tensor?
In the canonical formalism (variation principle + Noether theorem + Belinfante procedure) we identify the symmetric energy-momentum tensor by
[tex]T^{ab} = \Theta^{ab} + \partial_{c}X^{cab}[/tex]
where
[tex]\Theta^{ab} = \frac{\partial \mathcal{L}}{\partial \partial_{a}\phi} \partial^{b}\phi - \eta^{ab}\mathcal{L}[/tex]
is the canonical energy-momentum tensor and [itex]X^{cab} = - X^{acb}[/itex] is spin super-potential given by
[tex]X^{cab} - X^{cba} = i \frac{\partial \mathcal{L}}{\partial \partial_{c} \phi} \Sigma^{ab}\phi[/tex]
Therefore, in principle, we should be able to PROVE the following identity for arbitrary field theory( Mod the equation of motion);
[tex]2 \frac{\delta S}{\delta g_{ab}}|_{g = \eta} = \Theta^{ab} + \partial_{c}X^{cab}[/tex]
Can we? nope! It is rather embarrassing that we can not derive it from variation principle or any other physical principle!
regards
sam
What do you mean `we cannot prove it'? I know that this identity definitely holds for the electromagnetic field since I have checked it. I suspect very strongly that the proof generalizes to arbitrary (nonabelian) vector fields, and probably also for scalars and fermions.
By "arbitrary field theory" I mean ANY field theory:
[tex]S[\phi] = \int d^{4}x \sqrt{-g} \ \mathcal{L}(\phi , \partial \phi )[/tex]
where [itex]\phi[/itex] is a field of GENERAL (unspecified) nature, i.e., the explicit functional form of [itex]\mathcal{L}[/itex] is not given. For such ( arbitrary or model-independent) action integral, we cannot show that
[tex]2 \ \frac{\delta S}{\delta g_{ab}} = \sqrt{-g} T^{ab} \ \ \ (1)[/tex]
follows from some physical principle! I find this fact very annoying.
Consider, for example, the invariance of S under the diffeomorphism [itex]x \rightarrow x + \epsilon[/itex];
[tex]
\delta S = \int \ \delta (d^{4}x \sqrt{-g}) \ \mathcal{L} \ + \int d^{4}x \sqrt{-g} \ \delta \mathcal{L} = \int d^{4}x \sqrt{-g} \ \delta \mathcal{L}
[/tex]
(the first integral vanishes because ([itex]\sqrt{-g}d^{4}x[/itex]) is a scalar). Now with some algebra on ([itex]\delta \mathcal{L}[/itex]), we can show, after neglecting surface terms, that
[tex]\delta S[\phi] = \int d^{4}x \left( \frac{\delta S}{\delta g_{ab}} - \frac{1}{2} \sqrt{-g} T^{ab}\right) \ \delta g_{ab}[/tex]
But the ten quantities [itex]\delta g_{ab}[/itex] are not all independent, because they were brought about by only four diffeomorphisms. Therefore, the invariance of the action under diffeomorphism DOES NOT leads to Eq(1). It does though justify regarding Eq(1) as an alternative "definition" for the symmetric energy momentum tensor.
regards
sam
Interesting.
Personally, I don't find it annoying that there exist field theories which don't satisfy condition (1). I would regard such theories as pathological and use this condition as a criterion for selecting physically meaningful theories.
1. What is a tensor?
A tensor is a mathematical object that describes the relationship between different vectors and their transformations in a geometric space. It is a multidimensional array of numbers that follows specific rules for how it can be manipulated and transformed.
2. What is the stress-energy tensor?
The stress-energy tensor is a specific type of tensor that describes the distribution of energy and momentum in a given spacetime. It combines the concepts of stress (pressure) and energy into a single mathematical object, and is a fundamental concept in Einstein's theory of general relativity.
3. How do we know that the stress-energy tensor is a tensor?
The stress-energy tensor is derived from the equations of general relativity, which have been extensively tested and confirmed through various experiments and observations. These equations show that the stress-energy tensor must follow certain rules and properties, such as being symmetric and covariant under coordinate transformations, which are characteristics of tensors.
4. What are the components of the stress-energy tensor?
The stress-energy tensor has 16 components, but only 10 of them are independent. These components represent different aspects of energy and momentum, such as matter density, pressure, and shear stress. They are arranged in a 4x4 matrix, with each row and column corresponding to a different direction in spacetime.
5. Why is the stress-energy tensor important in physics?
The stress-energy tensor is a crucial concept in physics because it allows us to understand the distribution and flow of energy and momentum in the universe. It is used in many areas of physics, including cosmology, astrophysics, and particle physics, and is essential in understanding the behavior of matter and energy on a large scale through Einstein's theory of general relativity.
