Voltage Increases When Connecting Multiple Batteries
In summary: Thanks!I've seen the drift velocity formula and it's proportional to the current instead of voltage but why?Doesn't more energy mean more speed available?Ideas about drift velocity tend to be based on intuitive 'mechanical' thinking - water wheels and the like.
  • #36
You are correct that moving a charge across a lower PD ( field) absorbes or releases less energy then in a higher PD ( field). In all cases energy is needed ( source ) and is transferred to something else. "Energy needed" "consumed" etc are all a matter of perspective (are you the circuit or the battery)- for this a rechargeable battery is a good model - you have to ADD energy to the battery to charge it - and it delivers energy when it discharges. This is a basic physics model.
The point of the battery is that it generates a voltage, this voltage acts on all of the electrons in the conductor the same way - there is not more action near one terminal of the battery.
It is the presence of the voltage that acts instantly ( technically some speed slightly slower then the speed of light across a conductor) - this voltage make (pushes/pulls) all of the electrons in the conductor at the same time.
Thinking of how the electrons move in an conductor - is 2 -3 levels or more than is required to discuss the OP. When you put 2 batteries in series the voltages add - this is a basic circuit question. How electrons flow in a conductor when a voltage is applied, is physical science ( still an electrical engineering discipline ) - but is not directly related to how a battery operates. Part of the beauty of Electrical Engineering is how well the real world application matches the theory AND how well the theory can be broken into very simple elements. So mixing the discussion between the three or four concepts in this thread - is really only making is much more difficult. Batteries/Energy/EMF/Electron flow - each requires their own study - then you can better understand how they interact - but in reality you almost never need to think of them all at the same time to solve any problem.
  • #37
The force that act on electrons is provided by the positive charges, so teorically if i connect a piece of wire only to the positive pole, is there a possibility that some electrons of the wire go to the +?
Thank you!
  • #38
Windadct said:
IMHO - the "Negative Energy" term is really just confusing this issue. Energy moves (converted) from one system to another, a positive or negative reference only applies to the point of observation or the difference in two or more states ( top of the waterfall vs bottom of the waterfall, battery before the current flows vs after the current flows) They have less energy, but they do not negative energy.
Yes, I have to agree with you there. It may be true bit it isn't really relevant.
This thread is a great example of one which is being driven by a diehard misconception about electrical energy transfer. The Schoolboy model of electrons along wires is so attractive and 'pictorial' that it makes people hang onto it long past the point where they should be looking for something deeper.
The fact is that Electrical Energy transfer is a very sophisticated process. There is no satisfactory description at an elementary level. Along with all the other difficult concepts in Physics (QM, Relativity etc,) , if you think you've 'got it', then you probably haven't.
I had a huge advantage in being 'taught' Electricity without the use of noddy electron picture models. You go straight into a simple mathematical treatment and it yields all the measurable behavior of circuits and emerge with confidence about those tangible things. Later on you talk about conduction and electron motion in a vacuum and the QM aspects of it all. At no stage was there any need to 'demand' an 'understandable' model.
The way things are going seems to be little more than the blind leading the blind (delivery of the Electricity Curriculum in School, for instance) and with no one being prepared to get down and dirty with some serious basic theory. "In my day" conversations like this were short and sweet because people accepted that they don't really get you anywhere.
  • #39
Thank you!
You are describing what is referred to as an Incomplete Circuit. No steady current will flow, of course. But when the wire is first connected, there will be a small (and just detectable) charge flow, until the fields balance out. If, instead of a wire, you use a pair of plates, closely spaced and with a large area (same thing conceptually) then you get a Capacitor and a very significant charge will flow which will 'charge' the capacitor until, again, the fields balance out.
  • #40
So if I just connect a wire to the positive pole (creating an incomplete circuit) there will be no steady current because the protons of the wire will not permitt the wire electrons to move away to the positive pole of the battery?
So, if the positive of the battery would have a very big potential difference and for example the wire is heated, is it possible to remove electrons from the wire?
Thank you!
  • Electrical Engineering
  • Electromagnetism
