Question about enthelpy of reaction
  • Thread starter gokuls
  • Tags
    Reaction
In summary, the "per mol" in the unit for ΔH represents the enthalpy change per mole of the reaction as it is written, or the enthalpy change when 1 mole of the reaction (or process) occurs. This is based on the stoichiometry of the reaction and can vary depending on the substances involved. It is important to clarify which substances the "per mol" refers to in order to accurately interpret the enthalpy change.
gokuls
35
I think enthalpy of reaction is the amount of energy released when that reaction takes place (correct me if I'm wrong), but enthalpy of reaction is often written as per mole of something. As in kJ released per mol. What does the per mol represent? There are probably many reactants and products, so what is the "per mol" referring to?
Thanks!
Chemistry news on Phys.org
Thanks!
Per mole of reaction.
If we have the reaction
[itex]H_2O (s) \rightarrow H_2O (l) \ \Delta H = 6.01 kJ/mol[/itex]
the reaction happening for one molecule of water is obviously not going to cause an enthalpy change of 6.01 kJ. However, if a mole of water molecules undergoes this, the change in enthalpy will be 6.01 kJ.
Say there were multiple reactants and products, then which one would it be referring to?
The reaction happening ≈6.022 X 1023 times.
No, what I'm saying is, say the enthalpy of reaction for the following reaction is x kJ/mol.
HCl + NaOH -> NaCl + H20.
Then what would the per mol refer to? To the HCl, or the NaOH, or something else?
Per mol of reaction. Not anything in the equation.
If the reaction were to occur 6.022 X 1023 times, the change in enthalpy would be x kJ.
It is usually clear from the stoichiometry of the reaction.
Here are some examples, all using heats of combustion that may make this clear.
Burning 32g of sulphur, 12g of carbon or 2g of hydrogen have the following reactions and heats of reaction
S + O2= SO2 : ΔH = -297 kJ/mol
1mole of sulphur + 1mole of oxygen = 1mole of sulphur dioxide
C + O2= CO2 : ΔH = -393 kJ/mol
H2 + 1/2O2= H2O : ΔH = -286 kJ/mol
1mole of hydrogen + half mole of oxygen = 1 mole of water
Not exactly.
You need to specify the reaction more clearly and fully and also specify the state and condition of the products as this also has abearing.
The per mol is per mol of the principal reactant as named in the reaction so for instance in the soltion of ammonium nitrate in water the heat of solution (reaction) does not even specify a particular number of water molecules, just a general number n, so long as n is large.
NH4NO3(solid) + nH2) =NH4NO3.nH2O
ΔH per mole of ammonium nitrate is 29 J/mol
The amount of water is not specified or fixed.
Thanks, I finally kind of get it!
per mol of reaction?
but which reaction?
Look at my oxygen/hydrogen example
The heat of reaction of 1 mol of oxygen with hydrogen is twice that of the heat of reaction of 1 mol of hydrogen with oxygen.
but which reaction?
I see your argument, but then I still don't understand how to interpret the mol part. Is it just the mol of the main product.
"per mol" in this context is ambiguous, if the source of the data is serious it should clarify what convention is used.
That's exactly what I was trying to put over. The source will (should) tell you more than just
per mol.
So the reaction of (1mol) hydrogen with oxygen requires 1/2 mol of oxygen to produce 1 mol of water, at the enthalpy of reaction I stated earlier per mol (of hydrogen)
The reaction of (1mol) of oxygen with hydrogen requires 2mols of hydrogen and produces 2 moles of water and twice the enthalpy of reaction per mol (of oxygen)
Studiot said:
Not exactly. [...]
Quoting from the 9th edition of Chemistry from Raymond Chang, on page 236.
"The 'per mole' in the unit for ΔH means that this is the enthalpy change per mole of the reaction (or process) as it is written [italics are in the text, but emphasize my point all the same], that is, when 1 mole of ice is converted to 1 mole of liquid water [referring to the example I gave]."
So now, I need clarification too, because I thought I was right. :confused:
The book precisely explains what they mean by 1 mole of the reaction. You take the reaction as it is WRITTEN. So, if they wrote H2+1/2O2->H2O that's what they mean, if they write 2H2+O2->2H2O - that's what they mean.
Note that in both cases we deal with 6.02x1023 reactions.
Well you were right, and the comment about Avogadro's number of repeats is very good.
However, it was incomplete. 'The equation as written'
Going back to the reaction between oxygen and hydrogen.
As written
H2 + 1/2O2 = H2O
or
O2 + 2 H2 = 2H2O
Does this clear things up?
I am used to the convention that we use the first substance mentioned as our basis.
Edit Borek is obviously quicker on the draw than I am, so remind me never to have a shoot out at the OK corral with him
As written
H2 + + 1/2O2 = H2O
or
O2 + 2 H2 = 2H2O
Quicker, yes, but you explained my "mistake" better. Thank you.
How is it that in both cases we deal with 1 mol worth of reactions? In the first equation you wrote, it would be 1 mol worth of reactions because you produce 1 mol of water, but in the second equation, you must have 2 mols of reactions, since you produce 2 mol of water, n'est pas?
No, it depends on what you consider a "reaction". That's why it is so important to remember it is "reaction as WRITTEN".
As written . This example is right out of the book:
N2 (g) + 3H2 (g) --> 2NH3 (g)
This reaction involves splitting one mole of N2 triple bond requiring 945 kJ/m
And 3 moles of H2 single bond, requiring 3(436) kJ
And the formation of 6 moles of N-H bonds releasing 6(391) kJ
The enthalpy change is 2253 kJ reactants - 2346 kJ products = - 93 kJ
That is twice the molar enthalpy of one mole of ammonia formation
As written . This example is right out of the book:......
...That is twice the molar enthalpy of one mole of ammonia formation
And is entirely consistent with my convention and what Borek has been saying.
Take the first named substance
The enthalpy of this reaction is 93kJ per mole of nitrogen
If you want the figure per mole of ammonia you have to divide this figure by 2 and if you want it per mole of hydrogen you have to divide it by 3.
This is where the older use of gram-mole makes life easier than sitting up late at night counting molecules.
1. What is enthalpy of reaction?
The enthalpy of reaction, also known as the heat of reaction, is the amount of heat energy released or absorbed during a chemical reaction.
2. How is enthalpy of reaction calculated?
The enthalpy of reaction can be calculated using the following formula: ΔH = ΣH(products) - ΣH(reactants), where ΔH is the change in enthalpy, ΣH represents the sum of the enthalpies of the products and reactants.
3. What is the significance of enthalpy of reaction?
The enthalpy of reaction is important because it helps determine if a reaction is exothermic or endothermic. It also provides information about the amount of energy involved in a chemical reaction, which can be useful in various industrial and environmental applications.
4. How does temperature affect enthalpy of reaction?
Temperature has a direct impact on the enthalpy of reaction. As temperature increases, the enthalpy of reaction also increases. This is because higher temperatures provide more energy for the reactants to overcome the activation energy barrier and thus, increase the rate of the reaction.
5. Can enthalpy of reaction be negative?
Yes, the enthalpy of reaction can be negative. A negative enthalpy of reaction indicates that the reaction is exothermic, meaning that energy is released during the reaction. On the other hand, a positive enthalpy of reaction indicates an endothermic reaction where energy is absorbed during the reaction.
  • Biology and Chemistry Homework Help
  • Thermodynamics
