2 questions related to mathematical vectors
In summary, the conversation discusses finding the volume of a prism with given points A, B, and C, and proving a vector rule using components. The conversation also mentions seeking help in understanding the problem.
AmrAmin
I hope I can find a solutions for those questions with your help.
1. If you know that: A=(5,-4,3) B=(2,3,-1) C=(-3,2,5) .Find the volume of the prism whose sides are [tex]\underline{OA}[/tex], [tex]\underline{OB}[/tex], [tex]\underline{OC}[/tex] .
2. Prove using vector components that:
[tex]\underline{a}[/tex] [tex]\times[/tex] [tex]\left([/tex][tex]\underline{b}[/tex] [tex]\times[/tex] [tex]\underline{c}[/tex]) = ([tex]\underline{a}[/tex] . [tex]\underline{c}[/tex])[tex]\underline{b}[/tex] - ([tex]\underline{a}[/tex] . [tex]\underline{b}[/tex])[tex]\underline{c}[/tex]
and using this rule prove that :
[tex]\underline{a}[/tex] [tex]\times[/tex] ([tex]\underline{b}[/tex] [tex]\times[/tex] [tex]\underline{c}[/tex]) + [tex]\underline{b}[/tex] [tex]\times[/tex] ([tex]\underline{c}[/tex] [tex]\times[/tex] [tex]\underline{a}[/tex]) + [tex]\underline{c}[/tex] [tex]\times[/tex] ([tex]\underline{a}[/tex] x [tex]\underline{b}[/tex]) = 0
Well? You want to give us some ideas about where you're stuck? We're not going to do it for you. We're here to help you along.
1. To find the volume of the prism, we can use the formula V = |(\underline{OA} \times \underline{OB}) . \underline{OC}|, where \underline{OA} \times \underline{OB} is the cross product of the vectors \underline{OA} and \underline{OB}.
Using the given values, we can calculate \underline{OA} \times \underline{OB} as:
\underline{OA} \times \underline{OB} = (5,-4,3) \times (2,3,-1) = (-4,17,23)
Then, substituting this into the formula, we get:
V = |(-4,17,23) . (-3,2,5)| = |(-12,-34,11)| = \sqrt{12^2 + 34^2 + 11^2} = \sqrt{1553}
Therefore, the volume of the prism is \sqrt{1553} cubic units.
2. To prove the given vector identity, we can use the fact that the cross product is distributive, meaning that:
\underline{a} \times (\underline{b} \times \underline{c}) = (\underline{a} \times \underline{b}) \times \underline{c} - (\underline{a} \times \underline{c}) \times \underline{b}
Using this, we can rewrite the left side of the given identity as:
\underline{a} \times (\underline{b} \times \underline{c}) = ((\underline{a} \times \underline{b}) \times \underline{c}) + ((\underline{a} \times \underline{c}) \times \underline{b})
Then, using the given identity, we can rewrite the right side as:
(\underline{a} . \underline{c})\underline{b} - (\underline{a} . \underline{b})\underline{c} = ((\underline{a} \times \underline{b}) \times \underline{c}) + ((\underline{a} \times \underline{c}) \times \underline{b})
Since both sides are equal, the given identity is proven.
To prove the second part, we can use the same distributive property and the given identity to rewrite the expression as:
1. What is a vector in mathematics?
A vector in mathematics is a mathematical object that has both magnitude and direction. It is often represented by an arrow pointing in a specific direction, with the length of the arrow representing the magnitude of the vector. Vectors can be used to represent physical quantities such as velocity, force, and displacement.
2. How do you add or subtract vectors?
To add or subtract vectors, you must first ensure that they are of the same dimension. Then, you can either add or subtract the corresponding components of the vectors to get the resulting vector. For example, if you have two vectors A = (a1, a2, a3) and B = (b1, b2, b3), their sum would be A + B = (a1 + b1, a2 + b2, a3 + b3). Similarly, to subtract A - B, you would subtract the corresponding components.
3. What is the difference between a vector and a scalar?
A vector has both magnitude and direction, while a scalar only has magnitude. For example, the velocity of an object is a vector because it has both speed (magnitude) and direction, while the mass of an object is a scalar because it only has magnitude.
4. How are vectors represented in mathematical notation?
Vectors are typically represented using bold letters (e.g. v) or by placing an arrow on top of the letter (e.g. →v). In some cases, vectors may also be represented by a line segment with an arrow pointing in the direction of the vector.
5. What is the dot product of two vectors?
The dot product of two vectors is a mathematical operation that results in a scalar. It is calculated by multiplying the corresponding components of the vectors and then adding the products together. The dot product is used to calculate the angle between two vectors and can also be used to determine if two vectors are perpendicular to each other.
  • Science and Math Textbooks
  • Differential Geometry
