'Constant' vector field is equivalent to some scalar field
In summary, a scalar field corresponds to the magnitudes of a vector field, and can be specified by only the magnitudes of the field vectors since the directions are constants. The dot product of a scalar field and a vector field can define both a scalar field and a vector field, but it may not be of practical use. The only scalar-valued first-order differential operator is divergence, and it is a necessary consequence rather than an arbitrary construct. There is no duality between scalar and vector potentials. A scalar field is almost never path-independent, as it requires curl F = 0 which is a vector field property.
JanEnClaesen
59
To every scalar field s(x,y) there corresponds a 'constant' vector field x = A s(x,y) and y = B s(x,y), where A,B are direction cosines. The vector field is only partially constant since only the directions, and not the magnitudes, which are equal to |f(x,y)|, of the field vectors are constant.
The scalar field corresponds to the magnitudes of a vector field, that can be specified by only the magnitudes of the field vectors since the directions are constants A,B.
Is this correct?
This came up when evaluating a line integral f . dr , and splitting it up in the dx,dy components of dr. Can the dot product of a scalar field and a vector field define a scalar field as well as a vector field (since a(x,y)=(ax,ay))?
In more concrete terms: does it make sense to speak of the potential of a scalar field?
The dot product is only defined for a pair of vectors, and the result is a scalar.
Yes, but it's of no practical use. The only scalar-valued first-order differential operator is divergence, so the potential would be a vector. But then if [itex]\phi = \nabla \cdot \mathbf{f}[/itex] for some vector potential [itex]\mathbf{f}[/itex] and the original scalar PDE for [itex]\phi[/itex] is [tex]\mathcal{L}(\phi) = 0[/tex] then we now have [tex]\mathcal{L}(\nabla \cdot \mathbf{f}) = 0[/tex] which is replacing one equation in one unknown with one equation in three unknowns, which seems pointless. We can impose the condition [tex]\nabla \times \mathbf{f} = 0[/tex] by replacing [itex]\mathbf{f}[/itex] with [itex]\mathbf{f}' = \mathbf{f} + \mathbf{g}[/itex] where [itex]\mathbf{g}[/itex] satisfies [tex]\nabla \cdot \mathbf{g} = 0 \\ \nabla \times \mathbf{g} = -\nabla \times \mathbf{f}[/tex] so that [itex]\nabla \cdot \mathbf{f}' = \nabla \cdot \mathbf{f}[/itex] and [itex]\nabla \times \mathbf{f}' = 0[/itex], but then we immediately have [itex]\mathbf{f}' = \nabla \theta[/itex] and we end up with the scalar equation [tex]\mathcal{L}(\nabla^2 \theta) = 0[/tex] and the obvious way to solve that is to set [itex]\phi = \nabla^2 \theta[/itex] and first solve for [itex]\phi[/itex].
It's interesting that you call divergence the only scalar-valued first-order differential operator. This means that divergence is a necessary consequence, as opposed to an arbitary construct. Is there a way to see why divergence is the only possible first-order differential operator? Vector differential operators always seemed a bit arbitrary to me.
The vector potential of a scalar field isn't by any chance the scalar potential of that vector field (duality)?
So it doesn't make sense to think of a scalar field as being 'conservative', in that the line integral between two points is path-independent?
EDIT: a scalar field is probably almost never path-independent, unless it zero everywhere.
1. What is a constant vector field?
A constant vector field is a vector field in which the magnitude and direction of the vectors at each point in space remain constant. This means that the field does not change in any direction and remains the same throughout.
2. How is a constant vector field different from a scalar field?
A scalar field is a field that only has a magnitude at each point in space, while a vector field has both magnitude and direction. A constant vector field is equivalent to a scalar field because the magnitude of the vectors in the field is constant, making it behave like a scalar field.
3. Can a constant vector field exist in real life?
Yes, a constant vector field can exist in real life. An example of this would be a uniform electric field between two parallel plates, where the magnitude and direction of the electric field remain constant throughout the space between the plates.
4. What are some applications of constant vector fields?
Constant vector fields are used in various fields of science and engineering, such as electromagnetics, fluid mechanics, and quantum mechanics. They are particularly useful in studying the behavior of physical systems and making predictions about their behavior.
5. How is a constant vector field represented mathematically?
A constant vector field can be represented using vector notation as F = k, where k is a constant vector. In terms of components, the vector field would have constant values for all of its x, y, and z components at every point in space.
  • Classical Physics
  • General Math
  • Differential Geometry
  • Classical Physics
  • Classical Physics
